bobber6
Opera geolocation
In firefox i can watch bbc , in opera i am recognized as not being in the uk .
same server, romania,
geolocation is disabled.
coockies deleted and restarted opera.
Now firefox also is unable to access bbc tv.
FF updated today to 20.0, nothing els has changed on my side .
using airvpn dns server, dnsleak .com: no leaks
With geoiptool.com i get german ads........ both in ff and opera
result from geoiptool.com in firefox:
Host Name: hosted-by.leaseweb.com
IP Address: 95.211.138.27
Country: Netherlands netherlands
result from geoiptool.com in opera
Host Name: lh20638.voxility.net
IP Address: 109.163.226.153
Country: Romania
Country code: RO (ROU)
reult from dnsleak.com:
IP: 109.163.226.153
Hostname: lh20638.voxility.net
ISP: Voxility S.R.L.
Country: Romania
Currently BBC iPlayer is accessible from every server except Phoenicis, where an error is returned by the BBC (it does not appear as a geo-location problem). About YouTube, YouTube recognizes the Phoenicis IP address as a german one (a database error), so use another server as well if you want to access YouTube contents not accessible from Germany (except German servers, of course!). Therefore your setup should be fine, just don't connect to Phoenicis.
this the problem, i have been using Phoenicis and never had any problems with BBC iPlayer. are you planning to find out what the problem is with this server?
I want to use this server , and access BBC iPlayer.
" About YouTube, YouTube recognizes the Phoenicis IP address as a german one (a database error)"
this is not what i wrote , i said:"With geoiptool.com i get german ads........ both in ff and opera
has geoiptool.com also database problems?
Don't forget that this service is experimental and not advertised. We'll look into the issue but we don't guarantee anything.
That was an additional information, we tested YouTube as well.
Yes, obviously. It's not a database with problem, it's a database with wrong data. Phoenicis is in Bucharest, Romania. A service that correctly geo-locates Phoenicis IP addresses is http://ip2location.com.
this the problem' date=' i have been using Phoenicis and never had any problems with BBC iPlayer. are you planning to find out what the problem is with this server?
I want to use this server , and access BBC iPlayer.[/quote']
I did not realize this, but i hope the problem can be solved.
Cheers
Cheers
Problem solved: BBC and iPlayer are again accessible from Phoenicis (Romania).
Great work, thanks!
