asere27 0 Posted ... 05/04/2013 - 12.26 AirVPN client version: 1,8 05/04/2013 - 12.26 Reading options from C:\Documents and Settings\Administrator\Dati applicazioni\AirVPN\Air\1.0.0.0\AirVPN.xml 05/04/2013 - 12.26 OpenVPN bundle version: OpenVPN 2.3.0 05/04/2013 - 12.26 OpenVPN current version: OpenVPN 2.3.0 05/04/2013 - 12.26 Ready. 05/04/2013 - 12.26 Login... 05/04/2013 - 12.26 Already connected. Quote Share this post Link to post
Staff 10298 Posted ... 05/04/2013 - 12.26 AirVPN client version: 1,8 05/04/2013 - 12.26 Reading options from C:\Documents and Settings\Administrator\Dati applicazioni\AirVPN\Air\1.0.0.0\AirVPN.xml 05/04/2013 - 12.26 OpenVPN bundle version: OpenVPN 2.3.0 05/04/2013 - 12.26 OpenVPN current version: OpenVPN 2.3.0 05/04/2013 - 12.26 Ready. 05/04/2013 - 12.26 Login... 05/04/2013 - 12.26 Already connected.Hello!Everything seems just fine with your account (connected and exchanging data successfully), if the problem occurs again please check you panel (menu "Member Area"->"Your details") to know the exact reason of the last failed connection attempt and report back at your convenience.Kind regards Quote Share this post Link to post
