geeknurse
Step-By-Step Instruction for using uTorrent with AirVPN and Comodo
I had a hard time using the instructions provided by AirVPN for preventing leaks using uTorrent and the most current version of Comodo, so I pieced together my own system using already existing tutorials on the internet.
Please make corrections if you find errors in my method.
A. Create a network zone, Get the MAC for the TAP-Win adapter
1. (XP) Start / Run and type CMD, press enter
(Win7) Start and type CMD, press enter
2. You should see a black box called a DOS box with a blinking cursor
3. Type IPCONFIG /ALL
4. Look in the section that says TAP-Win32
5. You need the part that says Physical Address . . . . . . 00-??-??-??-??-??
6. Leave this window open for now
B. Create Network Zone for AirVPN
1. In Comodo, goto Tasks / Firewall Tasks / Open Advanced Settings / Network Zones
2. Right-Click / Add / New Network Zone
3. Name it AirVPN (press OK)
4. Select AirVPN
5. Double-Click (add addresses here) / MAC Address
6. Enter the 00-??-??-??-??-?? address from the DOS box
7. Press OK
C. Make a Ruleset
1. Open Rulesets
3. Enter a Name, AirVPN
4. Right-Click / Add
Action: Allow
Protocol: IP
Direction: In
Source Address: Any
Destination Address: Network Zone / AirVPN
Click OK
5. Right-Click / Add
Action: Allow
Protocol: IP
Direction: Out
Source Address: Network Zone / AirVPN
Destination Address: Any
Click OK
6. Right-Click / Add
Action: Block
Protocol: IP
Direction: In/Out
Source Address: Any
Click OK
D: Apply rule to Applications 9uTorrent or any other application you want to work only with AirVPN
1. Open Application Rules
2. Choose the application that should only work with AirVPN activeor add an new one. You can do this several ways If uTorrent isn't listed, Right-Click / Add / pull down "Browse" / Files or Running Processes (if uTorrent is active)
3. Click on the pull down "Copy from" / Ruleset / AirVPN
4. If there are other rules already, they will be removed. To keep any existing settings, you'll have to improvise here
5. Click OK
6. Click OK
E. Disable IPv6 in Windows 7 otherwise DHT, Local Peer Discovery and Peer Exchange will continue to connect even when AirVPN isn't active
Click / Start and type CMD, press enter. and apply the following at a command prompt: (just copy and paste)
netsh interface ipv6 set privacy state=disable
netsh interface ipv6 6to4 set state state=disabled
netsh interface ipv6 isatap set state state=disabled
netsh interface ipv6 set teredo disabled
This will disable all IPv6 tunnelling interfaces on Windows 7.
Credits:
http://www.bolehvpn.net/forum/index.php?topic=5798.0 (http://www.bolehvpn.net/forum/index.php?PHPSESSID=3c44e9hhquaovml4uk94bhh393&action=profile;u=4720)
http://forums.comodo.com/firewall-help-cis/stop-utorrent-when-vpn-connection-lost-t79114.0.html;msg566986#msg566986 (http://forums.comodo.com/profiles/radaghast-u103004.html)
