Not connected, Your IP: 216.73.216.169
odnamra
[SOLVED] constant disconnection and reconnection looping
I just resubscribed to airvpn. Disappointed to see that I'm having problems already. Tunnelblick is constantly connecting successfully, but then losing connection in about a 19 second interval.
please help
please help
What are your OS X and Tunnelblick versions? Can you please send us Tunnelblick logs just after the problem occurs?
Tunnelblick 3.2.8 (build 2891.3099) - OpenVPN 2.2.1
OS X 10.8.3
I tired redownloading my configuration file twice, just in case.
2013-04-02 20:30:22 *Tunnelblick: OS X 10.8.3; Tunnelblick 3.2.8 (build 2891.3099)
2013-04-02 20:30:31 *Tunnelblick: Attempting connection with AirVPN_United States_UDP-443; Set nameserver = 1; monitoring connection
2013-04-02 20:30:31 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start AirVPN_United\ States_UDP-443.ovpn 1337 1 0 0 0 49 -atDASNGWrdasngw
2013-04-02 20:30:31 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/odnamra/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/odnamra/Library/Application Support/Tunnelblick/Configurations/AirVPN_United States_UDP-443.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Sodnamra-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN_United States_UDP--443.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart
2013-04-02 20:30:32 *Tunnelblick: openvpnstart message: Loading tun.kext
2013-04-02 20:30:32 *Tunnelblick: Established communication with OpenVPN
2013-04-02 20:30:32 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Aug 10 2012
2013-04-02 20:30:32 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2013-04-02 20:30:32 Need hold release from management interface, waiting...
2013-04-02 20:30:32 MANAGEMENT: Client connected from 127.0.0.1:1337
2013-04-02 20:30:32 MANAGEMENT: CMD 'pid'
2013-04-02 20:30:32 MANAGEMENT: CMD 'state on'
2013-04-02 20:30:32 MANAGEMENT: CMD 'state'
2013-04-02 20:30:32 MANAGEMENT: CMD 'hold release'
2013-04-02 20:30:32 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:30:32 LZO compression initialized
2013-04-02 20:30:32 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:30:32 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:30:32 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:30:32 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:30:32 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:30:32 UDPv4 link local: [undef]
2013-04-02 20:30:32 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:30:32 MANAGEMENT: >STATE:1364956232,WAIT,,,
2013-04-02 20:30:32 MANAGEMENT: >STATE:1364956232,AUTH,,,
2013-04-02 20:30:32 TLS: Initial packet from 94.100.23.162:443, sid=b9670ddc 9eb8d6b9
2013-04-02 20:30:32 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:30:32 VERIFY OK: nsCertType=SERVER
2013-04-02 20:30:32 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:30:33 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:30:33 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:30:33 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:30:33 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:30:33 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:30:33 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:30:34 MANAGEMENT: >STATE:1364956234,GET_CONFIG,,,
2013-04-02 20:30:35 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:30:35 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:30:35 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:30:35 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:30:35 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:30:35 OPTIONS IMPORT: route options modified
2013-04-02 20:30:35 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:30:35 ROUTE default_gateway=10.0.0.1
2013-04-02 20:30:35 TUN/TAP device /dev/tun0 opened
2013-04-02 20:30:35 MANAGEMENT: >STATE:1364956235,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:30:35 /sbin/ifconfig tun0 delete
ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
2013-04-02 20:30:35 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:30:35 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:30:35 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:30:37 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:30:38 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:30:38 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
add net 94.100.23.162: gateway 10.0.0.1
2013-04-02 20:30:38 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
add net 0.0.0.0: gateway 10.4.24.89
2013-04-02 20:30:38 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
add net 128.0.0.0: gateway 10.4.24.89
2013-04-02 20:30:38 MANAGEMENT: >STATE:1364956238,ADD_ROUTES,,,
2013-04-02 20:30:38 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
add net 10.4.0.1: gateway 10.4.24.89
2013-04-02 20:30:38 Initialization Sequence Completed
2013-04-02 20:30:38 MANAGEMENT: >STATE:1364956238,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:30:38 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:30:38 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:30:38 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:30:43 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:30:43 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 28627) to restart the connection.
2013-04-02 20:30:44 event_wait : Interrupted system call (code=4)
2013-04-02 20:30:44 TCP/UDP: Closing socket
2013-04-02 20:30:44 /sbin/route delete -net 10.4.0.1 10.4.24.89 255.255.255.255
delete net 10.4.0.1: gateway 10.4.24.89
2013-04-02 20:30:44 /sbin/route delete -net 94.100.23.162 10.0.0.1 255.255.255.255
delete net 94.100.23.162: gateway 10.0.0.1
2013-04-02 20:30:44 /sbin/route delete -net 0.0.0.0 10.4.24.89 128.0.0.0
delete net 0.0.0.0: gateway 10.4.24.89
2013-04-02 20:30:44 /sbin/route delete -net 128.0.0.0 10.4.24.89 128.0.0.0
delete net 128.0.0.0: gateway 10.4.24.89
2013-04-02 20:30:44 Closing TUN/TAP interface
2013-04-02 20:30:44 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
2013-04-02 20:30:44 SIGUSR1[hard,] received, process restarting
2013-04-02 20:30:44 MANAGEMENT: >STATE:1364956244,RECONNECTING,SIGUSR1,,
2013-04-02 20:30:44 MANAGEMENT: CMD 'hold release'
2013-04-02 20:30:44 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:30:44 LZO compression initialized
2013-04-02 20:30:44 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:30:44 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:30:44 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:30:44 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:30:44 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:30:44 UDPv4 link local: [undef]
2013-04-02 20:30:44 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:30:44 MANAGEMENT: >STATE:1364956244,WAIT,,,
2013-04-02 20:30:44 MANAGEMENT: >STATE:1364956244,AUTH,,,
2013-04-02 20:30:44 TLS: Initial packet from 94.100.23.162:443, sid=538025e6 1aeb9988
2013-04-02 20:30:44 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-04-02 20:30:44 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-04-02 20:30:45 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:30:45 VERIFY OK: nsCertType=SERVER
2013-04-02 20:30:45 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:30:45 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:30:45 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:30:45 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:30:45 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:30:45 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:30:45 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:30:46 MANAGEMENT: >STATE:1364956246,GET_CONFIG,,,
2013-04-02 20:30:47 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:30:47 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:30:47 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:30:47 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:30:47 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:30:47 OPTIONS IMPORT: route options modified
2013-04-02 20:30:47 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:30:47 ROUTE default_gateway=10.0.0.1
2013-04-02 20:30:47 TUN/TAP device /dev/tun0 opened
2013-04-02 20:30:47 MANAGEMENT: >STATE:1364956247,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:30:47 /sbin/ifconfig tun0 delete
2013-04-02 20:30:47 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:30:47 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:30:47 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:30:50 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:30:50 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:30:50 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:30:50 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:30:50 MANAGEMENT: >STATE:1364956250,ADD_ROUTES,,,
2013-04-02 20:30:50 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:30:50 Initialization Sequence Completed
2013-04-02 20:30:50 MANAGEMENT: >STATE:1364956250,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:30:50 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:30:50 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:30:50 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:30:50 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:30:55 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:30:55 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 28627) to restart the connection.
2013-04-02 20:30:56 event_wait : Interrupted system call (code=4)
2013-04-02 20:30:56 TCP/UDP: Closing socket
2013-04-02 20:30:56 /sbin/route delete -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:30:56 /sbin/route delete -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:30:56 /sbin/route delete -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:30:56 /sbin/route delete -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:30:56 Closing TUN/TAP interface
2013-04-02 20:30:56 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
2013-04-02 20:30:56 SIGUSR1[hard,] received, process restarting
2013-04-02 20:30:56 MANAGEMENT: >STATE:1364956256,RECONNECTING,SIGUSR1,,
2013-04-02 20:30:56 MANAGEMENT: CMD 'hold release'
2013-04-02 20:30:56 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:30:56 LZO compression initialized
2013-04-02 20:30:56 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:30:56 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:30:56 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:30:56 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:30:56 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:30:56 UDPv4 link local: [undef]
2013-04-02 20:30:56 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:30:56 MANAGEMENT: >STATE:1364956256,WAIT,,,
2013-04-02 20:30:56 MANAGEMENT: >STATE:1364956256,AUTH,,,
2013-04-02 20:30:56 TLS: Initial packet from 94.100.23.162:443, sid=0a0304c6 857f8bd6
2013-04-02 20:30:56 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-04-02 20:30:56 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-04-02 20:30:57 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:30:57 VERIFY OK: nsCertType=SERVER
2013-04-02 20:30:57 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:30:57 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:30:57 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:30:57 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:30:57 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:30:57 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:30:57 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:30:59 MANAGEMENT: >STATE:1364956259,GET_CONFIG,,,
2013-04-02 20:31:00 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:31:00 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:31:00 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:31:00 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:31:00 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:31:00 OPTIONS IMPORT: route options modified
2013-04-02 20:31:00 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:31:00 ROUTE default_gateway=10.0.0.1
2013-04-02 20:31:00 TUN/TAP device /dev/tun0 opened
2013-04-02 20:31:00 MANAGEMENT: >STATE:1364956260,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:31:00 /sbin/ifconfig tun0 delete
2013-04-02 20:31:00 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:31:00 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:31:00 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:31:02 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:31:02 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:31:02 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:02 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:02 MANAGEMENT: >STATE:1364956262,ADD_ROUTES,,,
2013-04-02 20:31:02 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:31:02 Initialization Sequence Completed
2013-04-02 20:31:02 MANAGEMENT: >STATE:1364956262,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:31:02 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:31:02 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:31:02 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:31:02 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:31:08 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:31:08 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 28627) to restart the connection.
2013-04-02 20:31:09 event_wait : Interrupted system call (code=4)
2013-04-02 20:31:09 TCP/UDP: Closing socket
2013-04-02 20:31:09 /sbin/route delete -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:31:09 /sbin/route delete -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:31:09 /sbin/route delete -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:09 /sbin/route delete -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:09 Closing TUN/TAP interface
2013-04-02 20:31:09 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
2013-04-02 20:31:09 SIGUSR1[hard,] received, process restarting
2013-04-02 20:31:09 MANAGEMENT: >STATE:1364956269,RECONNECTING,SIGUSR1,,
2013-04-02 20:31:09 MANAGEMENT: CMD 'hold release'
2013-04-02 20:31:09 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:31:09 LZO compression initialized
2013-04-02 20:31:09 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:31:09 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:31:09 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:31:09 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:31:09 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:31:09 UDPv4 link local: [undef]
2013-04-02 20:31:09 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:31:09 MANAGEMENT: >STATE:1364956269,WAIT,,,
2013-04-02 20:31:09 MANAGEMENT: >STATE:1364956269,AUTH,,,
2013-04-02 20:31:09 TLS: Initial packet from 94.100.23.162:443, sid=910dc2ef 302219aa
2013-04-02 20:31:09 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:31:09 VERIFY OK: nsCertType=SERVER
2013-04-02 20:31:09 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:31:09 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-04-02 20:31:09 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-04-02 20:31:10 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:31:10 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:31:10 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:31:10 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:31:10 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:31:10 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:31:11 MANAGEMENT: >STATE:1364956271,GET_CONFIG,,,
2013-04-02 20:31:12 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:31:12 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:31:12 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:31:12 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:31:12 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:31:12 OPTIONS IMPORT: route options modified
2013-04-02 20:31:12 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:31:12 ROUTE default_gateway=10.0.0.1
2013-04-02 20:31:12 TUN/TAP device /dev/tun0 opened
2013-04-02 20:31:12 MANAGEMENT: >STATE:1364956272,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:31:12 /sbin/ifconfig tun0 delete
2013-04-02 20:31:12 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:31:12 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:31:12 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:31:14 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:31:14 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:31:14 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:14 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:14 MANAGEMENT: >STATE:1364956274,ADD_ROUTES,,,
2013-04-02 20:31:14 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:31:14 Initialization Sequence Completed
2013-04-02 20:31:14 MANAGEMENT: >STATE:1364956274,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:31:14 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:31:14 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:31:14 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:31:14 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:31:50 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:31:50 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 28627) to restart the connection.
2013-04-02 20:31:51 event_wait : Interrupted system call (code=4)
2013-04-02 20:31:51 TCP/UDP: Closing socket
2013-04-02 20:31:51 /sbin/route delete -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:31:51 /sbin/route delete -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:31:51 /sbin/route delete -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:51 /sbin/route delete -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:51 Closing TUN/TAP interface
2013-04-02 20:31:51 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
2013-04-02 20:31:51 SIGUSR1[hard,] received, process restarting
2013-04-02 20:31:51 MANAGEMENT: >STATE:1364956311,RECONNECTING,SIGUSR1,,
2013-04-02 20:31:51 MANAGEMENT: CMD 'hold release'
2013-04-02 20:31:51 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:31:51 LZO compression initialized
2013-04-02 20:31:51 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:31:51 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:31:51 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:31:51 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:31:51 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:31:51 UDPv4 link local: [undef]
2013-04-02 20:31:51 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:31:51 MANAGEMENT: >STATE:1364956311,WAIT,,,
2013-04-02 20:31:51 MANAGEMENT: >STATE:1364956311,AUTH,,,
2013-04-02 20:31:51 TLS: Initial packet from 94.100.23.162:443, sid=7b69a2a0 aa2148f5
2013-04-02 20:31:51 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:31:51 VERIFY OK: nsCertType=SERVER
2013-04-02 20:31:51 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:31:51 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-04-02 20:31:51 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-04-02 20:31:52 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:31:52 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:31:52 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:31:52 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:31:52 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:31:52 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:31:53 MANAGEMENT: >STATE:1364956313,GET_CONFIG,,,
2013-04-02 20:31:54 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:31:54 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:31:54 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:31:54 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:31:54 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:31:54 OPTIONS IMPORT: route options modified
2013-04-02 20:31:54 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:31:54 ROUTE default_gateway=10.0.0.1
2013-04-02 20:31:54 TUN/TAP device /dev/tun0 opened
2013-04-02 20:31:54 MANAGEMENT: >STATE:1364956314,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:31:54 /sbin/ifconfig tun0 delete
2013-04-02 20:31:54 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:31:54 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:31:54 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:31:56 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:31:57 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:31:57 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:31:57 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:57 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:31:57 MANAGEMENT: >STATE:1364956317,ADD_ROUTES,,,
2013-04-02 20:31:57 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:31:57 Initialization Sequence Completed
2013-04-02 20:31:57 MANAGEMENT: >STATE:1364956317,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:31:57 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:31:57 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:31:57 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:32:02 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:32:02 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 28627) to restart the connection.
2013-04-02 20:32:03 event_wait : Interrupted system call (code=4)
2013-04-02 20:32:03 TCP/UDP: Closing socket
2013-04-02 20:32:03 /sbin/route delete -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:32:03 /sbin/route delete -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:32:03 /sbin/route delete -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:03 /sbin/route delete -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:03 Closing TUN/TAP interface
2013-04-02 20:32:03 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
2013-04-02 20:32:03 SIGUSR1[hard,] received, process restarting
2013-04-02 20:32:03 MANAGEMENT: >STATE:1364956323,RECONNECTING,SIGUSR1,,
2013-04-02 20:32:03 MANAGEMENT: CMD 'hold release'
2013-04-02 20:32:03 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:32:03 LZO compression initialized
2013-04-02 20:32:03 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:32:03 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:32:03 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:32:03 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:32:03 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:32:03 UDPv4 link local: [undef]
2013-04-02 20:32:03 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:32:03 MANAGEMENT: >STATE:1364956323,WAIT,,,
2013-04-02 20:32:03 MANAGEMENT: >STATE:1364956323,AUTH,,,
2013-04-02 20:32:03 TLS: Initial packet from 94.100.23.162:443, sid=c680e48e 3c1c1c4e
2013-04-02 20:32:03 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-04-02 20:32:03 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-04-02 20:32:04 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:32:04 VERIFY OK: nsCertType=SERVER
2013-04-02 20:32:04 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:32:04 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:04 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:04 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:04 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:04 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:32:04 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:32:05 MANAGEMENT: >STATE:1364956325,GET_CONFIG,,,
2013-04-02 20:32:07 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:32:07 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:32:07 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:32:07 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:32:07 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:32:07 OPTIONS IMPORT: route options modified
2013-04-02 20:32:07 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:32:07 ROUTE default_gateway=10.0.0.1
2013-04-02 20:32:07 TUN/TAP device /dev/tun0 opened
2013-04-02 20:32:07 MANAGEMENT: >STATE:1364956327,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:32:07 /sbin/ifconfig tun0 delete
2013-04-02 20:32:07 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:32:07 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:32:07 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:32:09 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:32:09 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:32:09 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:09 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:09 MANAGEMENT: >STATE:1364956329,ADD_ROUTES,,,
2013-04-02 20:32:09 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:32:09 Initialization Sequence Completed
2013-04-02 20:32:09 MANAGEMENT: >STATE:1364956329,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:32:09 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:32:09 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:32:09 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:32:09 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:32:14 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:32:14 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 28627) to restart the connection.
2013-04-02 20:32:15 event_wait : Interrupted system call (code=4)
2013-04-02 20:32:15 TCP/UDP: Closing socket
2013-04-02 20:32:15 /sbin/route delete -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:32:15 /sbin/route delete -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:32:15 /sbin/route delete -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:15 /sbin/route delete -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:15 Closing TUN/TAP interface
2013-04-02 20:32:15 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
2013-04-02 20:32:15 SIGUSR1[hard,] received, process restarting
2013-04-02 20:32:15 MANAGEMENT: >STATE:1364956335,RECONNECTING,SIGUSR1,,
2013-04-02 20:32:15 MANAGEMENT: CMD 'hold release'
2013-04-02 20:32:15 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:32:15 LZO compression initialized
2013-04-02 20:32:15 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:32:15 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:32:15 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:32:15 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:32:15 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:32:15 UDPv4 link local: [undef]
2013-04-02 20:32:15 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:32:15 MANAGEMENT: >STATE:1364956335,WAIT,,,
2013-04-02 20:32:15 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-04-02 20:32:15 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-04-02 20:32:16 MANAGEMENT: >STATE:1364956336,AUTH,,,
2013-04-02 20:32:16 TLS: Initial packet from 94.100.23.162:443, sid=e13c6a50 01bdc3b6
2013-04-02 20:32:16 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:32:16 VERIFY OK: nsCertType=SERVER
2013-04-02 20:32:16 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:32:22 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:22 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:22 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:22 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:22 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:32:22 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:32:23 MANAGEMENT: >STATE:1364956343,GET_CONFIG,,,
2013-04-02 20:32:24 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:32:24 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:32:24 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:32:24 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:32:24 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:32:24 OPTIONS IMPORT: route options modified
2013-04-02 20:32:24 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:32:24 ROUTE default_gateway=10.0.0.1
2013-04-02 20:32:24 TUN/TAP device /dev/tun0 opened
2013-04-02 20:32:24 MANAGEMENT: >STATE:1364956344,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:32:24 /sbin/ifconfig tun0 delete
2013-04-02 20:32:24 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:32:24 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:32:24 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:32:26 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:32:26 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:32:26 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:26 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:26 MANAGEMENT: >STATE:1364956346,ADD_ROUTES,,,
2013-04-02 20:32:26 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:32:26 Initialization Sequence Completed
2013-04-02 20:32:26 MANAGEMENT: >STATE:1364956346,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:32:26 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:32:26 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:32:26 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:32:26 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:32:32 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:32:32 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 28627) to restart the connection.
2013-04-02 20:32:33 event_wait : Interrupted system call (code=4)
2013-04-02 20:32:33 TCP/UDP: Closing socket
2013-04-02 20:32:33 /sbin/route delete -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:32:33 /sbin/route delete -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:32:33 /sbin/route delete -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:33 /sbin/route delete -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:33 Closing TUN/TAP interface
2013-04-02 20:32:33 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
2013-04-02 20:32:33 SIGUSR1[hard,] received, process restarting
2013-04-02 20:32:33 MANAGEMENT: >STATE:1364956353,RECONNECTING,SIGUSR1,,
2013-04-02 20:32:33 MANAGEMENT: CMD 'hold release'
2013-04-02 20:32:33 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:32:33 LZO compression initialized
2013-04-02 20:32:33 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:32:33 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:32:33 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:32:33 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:32:33 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:32:33 UDPv4 link local: [undef]
2013-04-02 20:32:33 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:32:33 MANAGEMENT: >STATE:1364956353,WAIT,,,
2013-04-02 20:32:33 MANAGEMENT: >STATE:1364956353,AUTH,,,
2013-04-02 20:32:33 TLS: Initial packet from 94.100.23.162:443, sid=d72ff250 e1e37b6e
2013-04-02 20:32:33 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:32:33 VERIFY OK: nsCertType=SERVER
2013-04-02 20:32:33 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:32:33 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-04-02 20:32:33 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-04-02 20:32:34 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:34 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:34 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:34 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:34 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:32:34 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:32:35 MANAGEMENT: >STATE:1364956355,GET_CONFIG,,,
2013-04-02 20:32:36 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:32:36 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:32:36 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:32:36 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:32:36 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:32:36 OPTIONS IMPORT: route options modified
2013-04-02 20:32:36 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:32:36 ROUTE default_gateway=10.0.0.1
2013-04-02 20:32:36 TUN/TAP device /dev/tun0 opened
2013-04-02 20:32:36 MANAGEMENT: >STATE:1364956356,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:32:36 /sbin/ifconfig tun0 delete
2013-04-02 20:32:36 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:32:36 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:32:36 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:32:38 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:32:38 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:32:38 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:38 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:38 MANAGEMENT: >STATE:1364956358,ADD_ROUTES,,,
2013-04-02 20:32:38 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:32:38 Initialization Sequence Completed
2013-04-02 20:32:38 MANAGEMENT: >STATE:1364956358,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:32:38 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:32:38 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:32:38 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:32:38 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:32:44 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:32:44 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 28627) to restart the connection.
2013-04-02 20:32:45 event_wait : Interrupted system call (code=4)
2013-04-02 20:32:45 TCP/UDP: Closing socket
2013-04-02 20:32:45 /sbin/route delete -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:32:45 /sbin/route delete -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:32:45 /sbin/route delete -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:45 /sbin/route delete -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:45 Closing TUN/TAP interface
2013-04-02 20:32:45 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
2013-04-02 20:32:45 SIGUSR1[hard,] received, process restarting
2013-04-02 20:32:45 MANAGEMENT: >STATE:1364956365,RECONNECTING,SIGUSR1,,
2013-04-02 20:32:45 MANAGEMENT: CMD 'hold release'
2013-04-02 20:32:45 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:32:45 LZO compression initialized
2013-04-02 20:32:45 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:32:45 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:32:45 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:32:45 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:32:45 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:32:45 UDPv4 link local: [undef]
2013-04-02 20:32:45 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:32:45 MANAGEMENT: >STATE:1364956365,WAIT,,,
2013-04-02 20:32:45 MANAGEMENT: >STATE:1364956365,AUTH,,,
2013-04-02 20:32:45 TLS: Initial packet from 94.100.23.162:443, sid=865dd73e 8cb6a9c9
2013-04-02 20:32:45 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:32:45 VERIFY OK: nsCertType=SERVER
2013-04-02 20:32:45 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:32:45 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-04-02 20:32:45 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-04-02 20:32:46 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:46 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:46 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:46 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:46 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:32:46 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:32:47 MANAGEMENT: >STATE:1364956367,GET_CONFIG,,,
2013-04-02 20:32:48 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:32:48 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:32:48 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:32:48 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:32:48 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:32:48 OPTIONS IMPORT: route options modified
2013-04-02 20:32:48 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:32:48 ROUTE default_gateway=10.0.0.1
2013-04-02 20:32:48 TUN/TAP device /dev/tun0 opened
2013-04-02 20:32:48 MANAGEMENT: >STATE:1364956368,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:32:48 /sbin/ifconfig tun0 delete
2013-04-02 20:32:48 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:32:48 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:32:48 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:32:51 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:32:51 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:32:51 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:51 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:51 MANAGEMENT: >STATE:1364956371,ADD_ROUTES,,,
2013-04-02 20:32:51 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:32:51 Initialization Sequence Completed
2013-04-02 20:32:51 MANAGEMENT: >STATE:1364956371,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:32:51 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:32:51 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:32:51 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:32:51 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:32:56 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:32:56 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 28627) to restart the connection.
2013-04-02 20:32:57 event_wait : Interrupted system call (code=4)
2013-04-02 20:32:57 TCP/UDP: Closing socket
2013-04-02 20:32:57 /sbin/route delete -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:32:57 /sbin/route delete -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:32:57 /sbin/route delete -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:57 /sbin/route delete -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:32:57 Closing TUN/TAP interface
2013-04-02 20:32:57 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
2013-04-02 20:32:57 SIGUSR1[hard,] received, process restarting
2013-04-02 20:32:57 MANAGEMENT: >STATE:1364956377,RECONNECTING,SIGUSR1,,
2013-04-02 20:32:57 MANAGEMENT: CMD 'hold release'
2013-04-02 20:32:57 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-04-02 20:32:57 LZO compression initialized
2013-04-02 20:32:57 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-04-02 20:32:57 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-04-02 20:32:57 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-04-02 20:32:57 Local Options hash (VER=V4): '22188c5b'
2013-04-02 20:32:57 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-04-02 20:32:57 UDPv4 link local: [undef]
2013-04-02 20:32:57 UDPv4 link remote: 94.100.23.162:443
2013-04-02 20:32:57 MANAGEMENT: >STATE:1364956377,WAIT,,,
2013-04-02 20:32:57 MANAGEMENT: >STATE:1364956377,AUTH,,,
2013-04-02 20:32:57 TLS: Initial packet from 94.100.23.162:443, sid=149445ca da3b83b9
2013-04-02 20:32:57 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-04-02 20:32:57 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-04-02 20:32:58 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-04-02 20:32:58 VERIFY OK: nsCertType=SERVER
2013-04-02 20:32:58 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-04-02 20:32:58 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:58 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:58 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-04-02 20:32:58 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-04-02 20:32:58 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-04-02 20:32:58 [server] Peer Connection Initiated with 94.100.23.162:443
2013-04-02 20:32:59 MANAGEMENT: >STATE:1364956379,GET_CONFIG,,,
2013-04-02 20:33:00 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-04-02 20:33:00 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.24.90 10.4.24.89'
2013-04-02 20:33:00 OPTIONS IMPORT: timers and/or timeouts modified
2013-04-02 20:33:00 OPTIONS IMPORT: LZO parms modified
2013-04-02 20:33:00 OPTIONS IMPORT: --ifconfig/up options modified
2013-04-02 20:33:00 OPTIONS IMPORT: route options modified
2013-04-02 20:33:00 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-04-02 20:33:00 ROUTE default_gateway=10.0.0.1
2013-04-02 20:33:00 TUN/TAP device /dev/tun0 opened
2013-04-02 20:33:00 MANAGEMENT: >STATE:1364956380,ASSIGN_IP,,10.4.24.90,
2013-04-02 20:33:00 /sbin/ifconfig tun0 delete
2013-04-02 20:33:01 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-04-02 20:33:01 /sbin/ifconfig tun0 10.4.24.90 10.4.24.89 mtu 1500 netmask 255.255.255.255 up
2013-04-02 20:33:01 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.24.90 10.4.24.89 init
No such key
2013-04-02 20:33:03 *Tunnelblick: Flushed the DNS cache
2013-04-02 20:33:03 /sbin/route add -net 94.100.23.162 10.0.0.1 255.255.255.255
2013-04-02 20:33:03 /sbin/route add -net 0.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:33:03 /sbin/route add -net 128.0.0.0 10.4.24.89 128.0.0.0
2013-04-02 20:33:03 MANAGEMENT: >STATE:1364956383,ADD_ROUTES,,,
2013-04-02 20:33:03 /sbin/route add -net 10.4.0.1 10.4.24.89 255.255.255.255
2013-04-02 20:33:03 Initialization Sequence Completed
2013-04-02 20:33:03 MANAGEMENT: >STATE:1364956383,CONNECTED,SUCCESS,10.4.24.90,94.100.23.162
2013-04-02 20:33:03 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-04-02 20:33:03 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-04-02 20:33:03 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-04-02 20:33:03 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-04-02 20:33:08 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-04-02 20:33:08 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN
