#!@root88
Linux, Deluge and port forwarding
Hi, I'm trying to get the Deluge P2P client up and running on Linux. I've set up a port in the members area, but when I check it I get the following error.
Not reachable on server IP over the external port 18304, tcp protocol. Error : 110 - Connection timed out
In Deluge, I have set the incoming port to 18304 in Preferences/Network (from: and to: fields), so I'm not sure if I need to do anything else?
Any help appreciated.
Thanks.
