frustin
Slow speed test
I just ran a speedtest.net to maidenhead and got 40Mb (from my 100Mb) so there's some contention.
But I joined Carinae server (94.229.74.90, UDP), located in United Kingdom - Maidenhead, since 13m 4s ago.
Speedtest shows approximately 7Mb.
Here's my log:
26/03/2013 - 20:09 AirVPN client version: 1.8
26/03/2013 - 20:09 Reading options from C:\Users\Justin\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
26/03/2013 - 20:09 OpenVPN bundle version: OpenVPN 2.3.0
26/03/2013 - 20:09 OpenVPN current version: OpenVPN 2.3.0
26/03/2013 - 20:09 Login...
26/03/2013 - 20:09 Login success.
26/03/2013 - 20:09 Contacting service...
26/03/2013 - 20:09 Connecting...
26/03/2013 - 20:09 OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
26/03/2013 - 20:09 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
26/03/2013 - 20:09 Socket Buffers: R=[8192->8192] S=[8192->8192]
26/03/2013 - 20:09 UDPv4 link local: [undef]
26/03/2013 - 20:09 UDPv4 link remote: [AF_INET]94.229.74.90:443
26/03/2013 - 20:09 TLS: Initial packet from [AF_INET]94.229.74.90:443, sid=81ef6382 d8e4e2d9
26/03/2013 - 20:09 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
26/03/2013 - 20:09 VERIFY OK: nsCertType=SERVER
26/03/2013 - 20:09 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
26/03/2013 - 20:09 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
26/03/2013 - 20:09 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
26/03/2013 - 20:09 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
26/03/2013 - 20:09 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
26/03/2013 - 20:09 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
26/03/2013 - 20:09 [server] Peer Connection Initiated with [AF_INET]94.229.74.90:443
26/03/2013 - 20:09 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
26/03/2013 - 20:09 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.18.226 10.4.18.225'
26/03/2013 - 20:09 OPTIONS IMPORT: timers and/or timeouts modified
26/03/2013 - 20:09 OPTIONS IMPORT: LZO parms modified
26/03/2013 - 20:09 OPTIONS IMPORT: --ifconfig/up options modified
26/03/2013 - 20:09 OPTIONS IMPORT: route options modified
26/03/2013 - 20:09 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
26/03/2013 - 20:09 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
26/03/2013 - 20:09 open_tun, tt->ipv6=0
26/03/2013 - 20:09 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{4A818AEB-9077-41FF-B441-7E8BE3622039}.tap
26/03/2013 - 20:09 TAP-Windows Driver Version 9.9
26/03/2013 - 20:09 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.18.226/255.255.255.252 on interface {4A818AEB-9077-41FF-B441-7E8BE3622039} [DHCP-serv: 10.4.18.225, lease-time: 31536000]
26/03/2013 - 20:09 Successful ARP Flush on interface [21] {4A818AEB-9077-41FF-B441-7E8BE3622039}
26/03/2013 - 20:10 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
26/03/2013 - 20:10 C:\Windows\system32\route.exe ADD 94.229.74.90 MASK 255.255.255.255 10.0.0.1
26/03/2013 - 20:10 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
26/03/2013 - 20:10 Route addition via IPAPI succeeded [adaptive]
26/03/2013 - 20:10 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.18.225
26/03/2013 - 20:10 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
26/03/2013 - 20:10 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.18.225
26/03/2013 - 20:10 C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.18.225
26/03/2013 - 20:10 Initialization Sequence Completed
26/03/2013 - 20:10 Starting Management Interface...
26/03/2013 - 20:10 Checking...
26/03/2013 - 20:10 Retrieve statistics...
26/03/2013 - 20:10 Connected.
this is resolved to a point. It seems to matter what time of the day and which server i connect to.
