Bob.Dole 0 Posted ... Hi there Ok so I love this VPN service, been using it for a good few months now and am convinced I made the right choice, but one thing that never happened for me was being able to dodge my ISP (TalkTalk in the UK) traffic shaping policy. Tried getting help with it at first but looks like my ISP is throttling all encrypted traffic, or at least VPN traffic. Anyway, noticed there are a couple of new options for attempting to male VPN traffic indistinguishable from other SSL traffic and thought that was worth trying in case it screwed up their throttling... but as always with linux my noobyness has got me stumped and I need to ask a question that I should be able to answer myself by now: For command line (root NOT required): stunnel "AirVPN <..> - SSL <..>.ssl" From another command line (as root): openvpn "AirVPN <..> - SSL <..>.ovpn" I don't know how to write these commands properly. I have 2 files, *.ssl and *.ovpn, where do I put them in these commands? Do I leave the "AirVPN" and "SSL" text in the commands or should that be removed and replaced with filenames? What goes in the "<..>"? So far each variation I have tried hasn't worked Maybe I have done it right one of the times and it's something else that needs done, I noticed a line saying to update openssl libraries... not sure how to do that either tbh and googling hasn't helped. Thank in advance. Quote Share this post Link to post
Staff 10427 Posted ... Hello!Let's make a practical example.Let's assume that, after you have installed the stunnel package, you want to connect over OpenVPN over SSL to Bootis and also that you do not select the option "Separate keys/certs from .ovpn file". After you have used the configuration generator, you will have two files, as you have noticed:AirVPN_GB-Bootis_SSL-443.ovpnAirVPN_GB-Bootis_SSL-443.sslPut them in any directory you like.Now, open two shells: one as normal user, the other as root.If you don't have a "root shell", in the second shell elevate to root with the command "su". If you have an Ubuntu distribution su is not available by default, so you will have to use the command "sudo" (see below).In the first shell, as normal user, go to the directory where you put the files (cd ) and issue the command:stunnel AirVPN_GB-Bootis_SSL-443.sslNow switch to the second shell, where you are root, go to the same directory and issue the command:openvpn AirVPN_GB-Bootis_SSL-443.ovpnIf you have Ubuntu and you're not root on the second shell, the command is:sudo openvpn AirVPN_GB-Bootis_SSL-443.ovpnOpenVPN should connect to Bootis over SSL. Check that the connection is successfully established by browsing to our web site and making sure that the central bottom box is green and displays "Connected!".In case of issues please copy the output of both commands and paste them in a message.Kind regards Quote Share this post Link to post
Bob.Dole 0 Posted ... Thanks for the reply Ok here's the outputs I am getting: No limit detected for the number of clients signal_pipe: FD=4 allocated (non-blocking mode) signal_pipe: FD=5 allocated (non-blocking mode) stunnel 4.42 on x86_64-pc-linux-gnu platform Compiled with OpenSSL 1.0.0e 6 Sep 2011 Running with OpenSSL 1.0.1 14 Mar 2012 Update OpenSSL shared libraries or rebuild stunnel Threading:PTHREAD SSL:ENGINE Auth:LIBWRAP Sockets:POLL,IPv6 Reading configuration from descriptor 3 PRNG seeded successfully Line 1: End of section stunnel: SSL server needs a certificate str_stats: 48 block(s), 1962 byte(s) and Sun Mar 24 16:38:09 2013 OpenVPN 2.3.0 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Jan 8 2013 Sun Mar 24 16:38:09 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Sun Mar 24 16:38:09 2013 Socket Buffers: R=[87380->131072] S=[16384->131072] Sun Mar 24 16:38:09 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:1413 [nonblock] Sun Mar 24 16:38:09 2013 TCP: connect to [AF_INET]127.0.0.1:1413 failed, will try again in 5 seconds: Connection refused Quote Share this post Link to post
Bob.Dole 0 Posted ... Oh I got it to work. I had to change "stunnel" to "stunnel4" in the command. It still says update libraries, but it seems to be working, showing as connected to the vpn. sudo stunnel4 '/home/tony/VPN Servers/SSL/AirVPN/AirVPN_NL-Leporis_SSL-443.ssl' 2013.03.24 17:40:31 LOG5[28520:139746749650688]: stunnel 4.42 on x86_64-pc-linux-gnu platform 2013.03.24 17:40:31 LOG5[28520:139746749650688]: Compiled with OpenSSL 1.0.0e 6 Sep 2011 2013.03.24 17:40:31 LOG5[28520:139746749650688]: Running with OpenSSL 1.0.1 14 Mar 2012 2013.03.24 17:40:31 LOG5[28520:139746749650688]: Update OpenSSL shared libraries or rebuild stunnel 2013.03.24 17:40:31 LOG5[28520:139746749650688]: Threading:PTHREAD SSL:ENGINE Auth:LIBWRAP Sockets:POLL,IPv6 2013.03.24 17:40:31 LOG5[28520:139746749650688]: Reading configuration from file /home/tony/VPN Servers/SSL/AirVPN/AirVPN_NL-Leporis_SSL-443.ssl 2013.03.24 17:40:31 LOG6[28520:139746749650688]: Initializing SSL context for service openvpn 2013.03.24 17:40:31 LOG6[28520:139746749650688]: SSL context initialized 2013.03.24 17:40:31 LOG5[28520:139746749650688]: Configuration successful 2013.03.24 17:40:47 LOG5[28520:139746749806336]: Service openvpn accepted connection from 127.0.0.1:36461 2013.03.24 17:40:47 LOG6[28520:139746749806336]: connect_blocking: connecting 95.211.191.42:443 2013.03.24 17:40:47 LOG5[28520:139746749806336]: connect_blocking: connected 95.211.191.42:443 2013.03.24 17:40:47 LOG5[28520:139746749806336]: Service openvpn connected remote server from 192.168.1.3:51544 2013.03.24 17:40:47 LOG6[28520:139746749806336]: SSL connected: new session negotiated 2013.03.24 17:40:47 LOG6[28520:139746749806336]: Negotiated ciphers: RC4-SHA SSLv3 Kx=RSA Au=RSA Enc=RC4(128) Mac=SHA1 Quote Share this post Link to post
