picaro1
'Failed to Start' Problem
I can login but eventually get a 'failed to start' message.
I need help immediately.
Here's the log for your inspection:
3/14/2013 - 1:55 PM AirVPN client version: 1.7
3/14/2013 - 1:55 PM Reading options from C:\Users\Kwasi_Lap\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
3/14/2013 - 1:55 PM OpenVPN bundle version: OpenVPN 2.2.2
3/14/2013 - 1:55 PM OpenVPN current version: OpenVPN 2.2.2
3/14/2013 - 1:55 PM Login...
3/14/2013 - 1:55 PM Login success.
3/14/2013 - 1:55 PM Contacting service...
3/14/2013 - 1:55 PM Connecting...
3/14/2013 - 1:55 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
3/14/2013 - 1:55 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
3/14/2013 - 1:55 PM LZO compression initialized
3/14/2013 - 1:55 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
3/14/2013 - 1:55 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
3/14/2013 - 1:55 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
3/14/2013 - 1:55 PM Local Options hash (VER=V4): '22188c5b'
3/14/2013 - 1:55 PM Expected Remote Options hash (VER=V4): 'a8f55717'
3/14/2013 - 1:55 PM UDPv4 link local: [undef]
3/14/2013 - 1:55 PM UDPv4 link remote: 95.110.200.16:443
3/14/2013 - 1:55 PM TLS: Initial packet from 95.110.200.16:443, sid=254d3331 77bafbc0
3/14/2013 - 1:55 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
3/14/2013 - 1:55 PM VERIFY OK: nsCertType=SERVER
3/14/2013 - 1:55 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
3/14/2013 - 1:55 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
3/14/2013 - 1:55 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
3/14/2013 - 1:55 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
3/14/2013 - 1:55 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
3/14/2013 - 1:55 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
3/14/2013 - 1:55 PM [server] Peer Connection Initiated with 95.110.200.16:443
3/14/2013 - 1:55 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
3/14/2013 - 1:55 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.6.242 10.4.6.241'
3/14/2013 - 1:55 PM OPTIONS IMPORT: timers and/or timeouts modified
3/14/2013 - 1:55 PM OPTIONS IMPORT: LZO parms modified
3/14/2013 - 1:55 PM OPTIONS IMPORT: --ifconfig/up options modified
3/14/2013 - 1:55 PM OPTIONS IMPORT: route options modified
3/14/2013 - 1:55 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
3/14/2013 - 1:55 PM ROUTE default_gateway=192.168.1.1
3/14/2013 - 1:55 PM There are no TAP-Win32 adapters on this system. You should be able to create a TAP-Win32 adapter by going to Start -> All Programs -> OpenVPN -> Add a new TAP-Win32 virtual ethernet adapter.
3/14/2013 - 1:55 PM Exiting
3/14/2013 - 1:55 PM Failed to start.
The TAP-Win32 adapter is the tun/tap virtual network interface used by OpenVPN. Without it OpenVPN can't work.
The problem is that there are no TAP-Win32 adapters on your system. Maybe something went wrong during the installation. Try to add an adapter as suggested in the above quoted piece of your logs (the utility to add it is inside ..."OpenVPN"->"Utilities").
If the operation fails probably the adapter driver has not been installed properly. In this case, please uninstall OpenVPN completely and re-install it, making sure to authorize the installation of any driver.
