dajasc 0 Posted ... Hello, never used a VPN before. I have it set up on a Mint (Ubuntu) desktop. I have the vpn connected, I am entering this post from that machine with it connected to Air VPN right now. I verified that the Transmission client is using the same port that I am forwarding from Air VPN and I put torrents for a couple of popular linux distros in Transmission for a test. No downloading, no peers. The only other thing, besides connecting to Air VPN that I have done is this: pi@sam-berry ~ $ sudo iptables -A OUTPUT -m owner --uid-owner debian-transmission -d 192.168.0.100 -j ACCEPT pi@sam-berry ~ $ sudo iptables -A OUTPUT -m owner --uid-owner debian-transmission \! -o tun0 -j REJECT which I got from: http://www.botcyb.org/2012/11/force-application-to-use-vpn-using.html (with my name and local machine instead of his) I know absolutely nothing about IP tables, so possibly it is obvious from this what I have done wrong. Any help is appreciated. Quote Share this post Link to post
Staff 10487 Posted ... Hello, never used a VPN before. I have it set up on a Mint (Ubuntu) desktop. I have the vpn connected, I am entering this post from that machine with it connected to Air VPN right now. I verified that the Transmission client is using the same port that I am forwarding from Air VPN and I put torrents for a couple of popular linux distros in Transmission for a test. No downloading, no peers.The only other thing, besides connecting to Air VPN that I have done is this: pi@sam-berry ~ $ sudo iptables -A OUTPUT -m owner --uid-owner debian-transmission -d 192.168.0.100 -j ACCEPT pi@sam-berry ~ $ sudo iptables -A OUTPUT -m owner --uid-owner debian-transmission \! -o tun0 -j REJECT which I got from: http://www.botcyb.org/2012/11/force-application-to-use-vpn-using.html (with my name and local machine instead of his)I know absolutely nothing about IP tables, so possibly it is obvious from this what I have done wrong. Any help is appreciated.Hello!Please check that the interface name is correct (type "ifconfig" and check that it is tun0, not tun1 or anything else) and that in the iptables rule the names and "debian-transmission" are correct (use the command "ps aux | grep transmission" to check that). What is that 192.168.0.100?Kind regards Quote Share this post Link to post
dajasc 0 Posted ... Yes, it is tun0. Output of that portion of ifconfig is: tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 inet addr:10.5.2.238 P-t-P:10.5.2.237 Mask:255.255.255.255 UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1 RX packets:3880 errors:0 dropped:0 overruns:0 frame:0 TX packets:3940 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:100 RX bytes:2345406 (2.3 MB) TX bytes:674466 (674.4 KB) Now that I look at it I really don't get what 10.5.2.238 is. It is not my public IP as visible through Air VPN, it is not my real IP address. What is it, what should it be? Actually I used 192.168.0.11 not 192.168.0.100, but it is a local network machine that I would like to always be able to connect to the web interface of transmission with. Quote Share this post Link to post
dajasc 0 Posted ... Sorry, forgot the iptables rules checking. Here that is: hain INPUT (policy ACCEPT) target prot opt source destination Chain FORWARD (policy ACCEPT) target prot opt source destination Chain OUTPUT (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere dajsc004.local owner UID match debian-transmission REJECT all -- anywhere anywhere owner UID match debian-transmission reject-with icmp-port-unreachable I checked in htop as well to verify that debian-transmission is really the user of Transmission, which it is. Quote Share this post Link to post
Staff 10487 Posted ... Yes, it is tun0. Output of that portion of ifconfig is: tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 inet addr:10.5.2.238 P-t-P:10.5.2.237 Mask:255.255.255.255 UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1 RX packets:3880 errors:0 dropped:0 overruns:0 frame:0 TX packets:3940 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:100 RX bytes:2345406 (2.3 MB) TX bytes:674466 (674.4 KB) Now that I look at it I really don't get what 10.5.2.238 is. It is not my public IP as visible through Air VPN, it is not my real IP address. What is it, what should it be?Hello!It is your VPN IP address, it has been DHCP-pushed by our server to your client.About the rest we don't see any clear mistake. Can you check that the iptables rules have been properly created (check with "iptables -L")?Kind regards Quote Share this post Link to post
Staff 10487 Posted ... Hello!The problem seems to be here;REJECT all -- anywhere anywhere owner UID match debian-transmission reject-with icmp-port-unreachable Kind regards Quote Share this post Link to post
dajasc 0 Posted ... Ok, shouldn't have listened to that post I found. I think I have it working now using a post on this forum for how to prevent leaks on linux with iptables. My rules are now: Chain INPUT (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere anywhere ACCEPT all -- 255.255.255.255 anywhere ACCEPT all -- 192.168.0.0/16 192.168.0.0/16 Chain FORWARD (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere anywhere ACCEPT all -- anywhere anywhere Chain OUTPUT (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere anywhere ACCEPT all -- anywhere 255.255.255.255 ACCEPT all -- 192.168.0.0/16 192.168.0.0/16 DROP all -- anywhere !hosted-by.leaseweb.com Thanks for the help. Quote Share this post Link to post
Staff 10487 Posted ... Ok, shouldn't have listened to that post I found. I think I have it working now using a post on this forum for how to prevent leaks on linux with iptables. My rules are now: Chain INPUT (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere anywhere ACCEPT all -- 255.255.255.255 anywhere ACCEPT all -- 192.168.0.0/16 192.168.0.0/16 Chain FORWARD (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere anywhere ACCEPT all -- anywhere anywhere Chain OUTPUT (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere anywhere ACCEPT all -- anywhere 255.255.255.255 ACCEPT all -- 192.168.0.0/16 192.168.0.0/16 DROP all -- anywhere !hosted-by.leaseweb.com Thanks for the help.Hello!Thank YOU for sharing!Just out of curiosity, readers can compare your rules with those suggested in our guide "Prevent Leaks with Linux & iptables":https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=1713&limit=6&limitstart=30&Itemid=142#2010Kind regards Quote Share this post Link to post
