jimbojonesvpn
Disconnect if DNS is updated tunnelblick
Im using tunnelblick, and after first setting it up it would connect then disconnect after 5-6 seconds, i changed the setting to "do not set nameserver" and it connects and stays connected, ive set up a new network location so i can manually change DNS easily, but its a pain, can anyone suggest a solution?
I can post a log if it helps.
cheers.
cheers.
Which Tunnelblick version and which OS X version are you running?
I'm having the same problem. Running Tunnelblick 3.2.8 to connect to Pavonis. After 6 seconds the following log entry occurs:
Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
As a result, the connection is restarted. This is continuously occuring, bouncing my connection.
Which OS X version are you running?
