andytattoo 0 Posted ... air vpn client logs in gives me choice of server and connects but absolutely no internet...as in zero...can only connect when air client is logged off!!! Quote Share this post Link to post
Staff 10336 Posted ... air vpn client logs in gives me choice of server and connects but absolutely no internet...as in zero...can only connect when air client is logged off!!!Hello!Can you please send us, just after your system has connected to the VPN, your client connection logs and the output of the commands (issued from a command prompt):ping 10.4.0.1tracert google.comtracert 8.8.8.8Kind regards Quote Share this post Link to post
andytattoo 0 Posted ... 27/02/2013 - 22:06 AirVPN client version: 1.8 27/02/2013 - 22:06 Reading options from C:\Users\Merlin\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 27/02/2013 - 22:06 OpenVPN bundle version: OpenVPN 2.3.0 27/02/2013 - 22:06 OpenVPN current version: OpenVPN 2.3.0 27/02/2013 - 22:06 Ready. 27/02/2013 - 22:06 Login... 27/02/2013 - 22:06 Login success. 27/02/2013 - 22:06 Contacting service... 27/02/2013 - 22:06 Connecting... 27/02/2013 - 22:06 OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 27/02/2013 - 22:06 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 27/02/2013 - 22:06 Socket Buffers: R=[8192->8192] S=[8192->8192] 27/02/2013 - 22:06 Attempting to establish TCP connection with [AF_INET]31.193.12.74:53 27/02/2013 - 22:06 TCP connection established with [AF_INET]31.193.12.74:53 27/02/2013 - 22:06 TCPv4_CLIENT link local: [undef] 27/02/2013 - 22:06 TCPv4_CLIENT link remote: [AF_INET]31.193.12.74:53 27/02/2013 - 22:06 TLS: Initial packet from [AF_INET]31.193.12.74:53, sid=ad7478ff a732ccda 27/02/2013 - 22:06 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 27/02/2013 - 22:06 VERIFY OK: nsCertType=SERVER 27/02/2013 - 22:06 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 27/02/2013 - 22:06 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 27/02/2013 - 22:06 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 27/02/2013 - 22:06 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 27/02/2013 - 22:06 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 27/02/2013 - 22:06 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 27/02/2013 - 22:06 [server] Peer Connection Initiated with [AF_INET]31.193.12.74:53 27/02/2013 - 22:06 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 27/02/2013 - 22:06 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.9.0.1,comp-lzo no,route 10.9.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.9.0.174 10.9.0.173' 27/02/2013 - 22:06 OPTIONS IMPORT: timers and/or timeouts modified 27/02/2013 - 22:06 OPTIONS IMPORT: LZO parms modified 27/02/2013 - 22:06 OPTIONS IMPORT: --ifconfig/up options modified 27/02/2013 - 22:06 OPTIONS IMPORT: route options modified 27/02/2013 - 22:06 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 27/02/2013 - 22:06 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 27/02/2013 - 22:06 open_tun, tt->ipv6=0 27/02/2013 - 22:06 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{ACE4C446-A472-4DBB-8DD2-493F6507D1CD}.tap 27/02/2013 - 22:06 TAP-Windows Driver Version 9.9 27/02/2013 - 22:06 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.0.174/255.255.255.252 on interface {ACE4C446-A472-4DBB-8DD2-493F6507D1CD} [DHCP-serv: 10.9.0.173, lease-time: 31536000] 27/02/2013 - 22:06 Successful ARP Flush on interface [12] {ACE4C446-A472-4DBB-8DD2-493F6507D1CD} 27/02/2013 - 22:06 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 27/02/2013 - 22:06 C:\Windows\system32\route.exe ADD 31.193.12.74 MASK 255.255.255.255 192.168.0.1 27/02/2013 - 22:06 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 27/02/2013 - 22:06 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:06 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.0.173 27/02/2013 - 22:06 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:06 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:06 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.0.173 27/02/2013 - 22:06 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:06 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:06 C:\Windows\system32\route.exe ADD 10.9.0.1 MASK 255.255.255.255 10.9.0.173 27/02/2013 - 22:06 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:06 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:06 Initialization Sequence Completed 27/02/2013 - 22:06 Starting Management Interface... 27/02/2013 - 22:06 Checking... 27/02/2013 - 22:06 Retrieve statistics... 27/02/2013 - 22:06 Connected. its the dns...will not work with air vpn address or comodo...i have to set it to automatically obtain dns..from my isp..... how do i ping 10.4.01?? Quote Share this post Link to post
andytattoo 0 Posted ... its the dns for sure...just had an update windows 7 sp 1...strange thing is...would not connect after update with either comodo dns or your address 10.4.0.1...then after a little time i entered comodo dns again...same address and it now works...i should not have to enter dns address before every connection if i've chosen the dns.. Quote Share this post Link to post
andytattoo 0 Posted ... Microsoft Windows [Version 6.1.7601] Copyright © 2009 Microsoft Corporation. All rights reserved. C:\Users\Merlin>ping 10.4.0.1 Pinging 10.4.0.1 with 32 bytes of data: Reply from 10.4.0.1: bytes=32 time=283ms TTL=64 Reply from 10.4.0.1: bytes=32 time=40ms TTL=64 Reply from 10.4.0.1: bytes=32 time=40ms TTL=64 Reply from 10.4.0.1: bytes=32 time=40ms TTL=64 Ping statistics for 10.4.0.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 40ms, Maximum = 283ms, Average = 100ms C:\Users\Merlin>tracert google.com Tracing route to google.com [173.194.70.138] over a maximum of 30 hops: 1 40 ms 40 ms 39 ms 1.0.9.10.in-addr.arpa [10.9.0.1] 2 46 ms 40 ms 41 ms 31-193-12-73.static.hostnoc.net [31.193.12.73] 3 41 ms 41 ms 41 ms ec0-64.gwy02.mnuk01.hostnoc.eu [178.238.128.37] 4 47 ms 47 ms 47 ms xe1-04.gwy01.lnuk01.hostnoc.eu [178.238.128.30] 5 48 ms 48 ms 48 ms 125.224.66.195.in-addr.arpa [195.66.224.125] 6 50 ms 48 ms 48 ms 61.240.85.209.in-addr.arpa [209.85.240.61] 7 48 ms 55 ms 48 ms 90.253.85.209.in-addr.arpa [209.85.253.90] 8 53 ms 53 ms 53 ms 28.240.85.209.in-addr.arpa [209.85.240.28] 9 59 ms 60 ms 60 ms 227.241.85.209.in-addr.arpa [209.85.241.227] 10 73 ms 60 ms 60 ms 116.254.85.209.in-addr.arpa [209.85.254.116] 11 * * * Request timed out. 12 60 ms 59 ms 60 ms fa-in-f138.1e100.net [173.194.70.138] Trace complete. C:\Users\Merlin>tracert 8.8.8.8 Tracing route to google-public-dns-a.google.com [8.8.8.8] over a maximum of 30 hops: 1 40 ms 40 ms 40 ms 1.0.9.10.in-addr.arpa [10.9.0.1] 2 41 ms 41 ms 41 ms 31-193-12-73.static.hostnoc.net [31.193.12.73] 3 49 ms 41 ms 41 ms ec0-63.gwy01.mnuk01.hostnoc.eu [178.238.128.33] 4 48 ms 48 ms 48 ms xe1-04.gwy01.lnuk01.hostnoc.eu [178.238.128.2] 5 48 ms 51 ms 49 ms 125.224.66.195.in-addr.arpa [195.66.224.125] 6 48 ms 48 ms 48 ms 63.240.85.209.in-addr.arpa [209.85.240.63] 7 100 ms 49 ms 49 ms 196.253.85.209.in-addr.arpa [209.85.253.196] 8 62 ms 56 ms 54 ms 28.240.85.209.in-addr.arpa [209.85.240.28] 9 58 ms 58 ms 58 ms 38.49.239.216.in-addr.arpa [216.239.49.38] 10 * * * Request timed out. 11 56 ms 58 ms 57 ms google-public-dns-a.google.com [8.8.8.8] Trace complete. found it...this is after i changed dns to comodo secure dns... will restart pc and see if i can reconnect.. Quote Share this post Link to post
andytattoo 0 Posted ... same thing happened again...this time i think its because of udp ports...only letting me connect with tcp... do you want me to connect with udp to get the logs for the failed connection? Quote Share this post Link to post
andytattoo 0 Posted ... here is my log...i connected got back online with port 53 tcp...disconnected,then reconnected with port 53 udp...unable to use internet...now im back online with port 53tcp. 27/02/2013 - 22:41 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:41 C:\Windows\system32\route.exe ADD 10.8.0.1 MASK 255.255.255.255 10.8.1.41 27/02/2013 - 22:41 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:41 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:41 Initialization Sequence Completed 27/02/2013 - 22:41 Starting Management Interface... 27/02/2013 - 22:41 Checking... 27/02/2013 - 22:41 Retrieve statistics... 27/02/2013 - 22:41 Connected. 27/02/2013 - 22:42 Disconnecting... 27/02/2013 - 22:42 SIGTERM received, sending exit notification to peer 27/02/2013 - 22:42 C:\Windows\system32\route.exe DELETE 10.8.0.1 MASK 255.255.255.255 10.8.1.41 27/02/2013 - 22:42 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:42 C:\Windows\system32\route.exe DELETE 31.193.12.74 MASK 255.255.255.255 192.168.0.1 27/02/2013 - 22:42 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:42 C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.8.1.41 27/02/2013 - 22:42 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:42 C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.8.1.41 27/02/2013 - 22:42 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:42 Closing TUN/TAP interface 27/02/2013 - 22:42 SIGTERM[hard,] received, process exiting 27/02/2013 - 22:42 Disconnected. 27/02/2013 - 22:42 Login... 27/02/2013 - 22:42 Login success. 27/02/2013 - 22:42 Contacting service... 27/02/2013 - 22:42 Connecting... 27/02/2013 - 22:42 OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 27/02/2013 - 22:42 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 27/02/2013 - 22:42 Socket Buffers: R=[8192->8192] S=[8192->8192] 27/02/2013 - 22:42 UDPv4 link local: [undef] 27/02/2013 - 22:42 UDPv4 link remote: [AF_INET]31.193.12.74:443 27/02/2013 - 22:42 TLS: Initial packet from [AF_INET]31.193.12.74:443, sid=97f008c9 a3d8852d 27/02/2013 - 22:42 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 27/02/2013 - 22:42 VERIFY OK: nsCertType=SERVER 27/02/2013 - 22:42 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 27/02/2013 - 22:42 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 27/02/2013 - 22:42 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 27/02/2013 - 22:42 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 27/02/2013 - 22:42 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 27/02/2013 - 22:42 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 27/02/2013 - 22:42 [server] Peer Connection Initiated with [AF_INET]31.193.12.74:443 27/02/2013 - 22:42 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 27/02/2013 - 22:42 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.32.206 10.4.32.205' 27/02/2013 - 22:42 OPTIONS IMPORT: timers and/or timeouts modified 27/02/2013 - 22:42 OPTIONS IMPORT: LZO parms modified 27/02/2013 - 22:42 OPTIONS IMPORT: --ifconfig/up options modified 27/02/2013 - 22:42 OPTIONS IMPORT: route options modified 27/02/2013 - 22:42 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 27/02/2013 - 22:42 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 27/02/2013 - 22:42 open_tun, tt->ipv6=0 27/02/2013 - 22:42 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{ACE4C446-A472-4DBB-8DD2-493F6507D1CD}.tap 27/02/2013 - 22:42 TAP-Windows Driver Version 9.9 27/02/2013 - 22:42 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.32.206/255.255.255.252 on interface {ACE4C446-A472-4DBB-8DD2-493F6507D1CD} [DHCP-serv: 10.4.32.205, lease-time: 31536000] 27/02/2013 - 22:42 Successful ARP Flush on interface [12] {ACE4C446-A472-4DBB-8DD2-493F6507D1CD} 27/02/2013 - 22:42 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 27/02/2013 - 22:42 C:\Windows\system32\route.exe ADD 31.193.12.74 MASK 255.255.255.255 192.168.0.1 27/02/2013 - 22:42 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 27/02/2013 - 22:42 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:42 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.32.205 27/02/2013 - 22:42 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:42 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:42 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.32.205 27/02/2013 - 22:42 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:42 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:42 C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.32.205 27/02/2013 - 22:42 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:42 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:42 Initialization Sequence Completed 27/02/2013 - 22:42 Starting Management Interface... 27/02/2013 - 22:42 Checking... 27/02/2013 - 22:42 Retrieve statistics... 27/02/2013 - 22:42 Connected. 27/02/2013 - 22:50 Disconnecting... 27/02/2013 - 22:50 SIGTERM received, sending exit notification to peer 27/02/2013 - 22:50 C:\Windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.32.205 27/02/2013 - 22:50 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:50 C:\Windows\system32\route.exe DELETE 31.193.12.74 MASK 255.255.255.255 192.168.0.1 27/02/2013 - 22:50 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:50 C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.32.205 27/02/2013 - 22:50 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:50 C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.32.205 27/02/2013 - 22:50 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:50 Closing TUN/TAP interface 27/02/2013 - 22:50 SIGTERM[hard,] received, process exiting 27/02/2013 - 22:50 Disconnected. 27/02/2013 - 22:50 Login... 27/02/2013 - 22:50 Login success. 27/02/2013 - 22:50 Contacting service... 27/02/2013 - 22:50 Connecting... 27/02/2013 - 22:50 OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 27/02/2013 - 22:50 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 27/02/2013 - 22:50 Socket Buffers: R=[8192->8192] S=[8192->8192] 27/02/2013 - 22:50 Attempting to establish TCP connection with [AF_INET]31.193.12.74:53 27/02/2013 - 22:50 TCP connection established with [AF_INET]31.193.12.74:53 27/02/2013 - 22:50 TCPv4_CLIENT link local: [undef] 27/02/2013 - 22:50 TCPv4_CLIENT link remote: [AF_INET]31.193.12.74:53 27/02/2013 - 22:50 TLS: Initial packet from [AF_INET]31.193.12.74:53, sid=f197c406 23f2e287 27/02/2013 - 22:50 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 27/02/2013 - 22:50 VERIFY OK: nsCertType=SERVER 27/02/2013 - 22:50 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 27/02/2013 - 22:50 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 27/02/2013 - 22:50 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 27/02/2013 - 22:50 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 27/02/2013 - 22:50 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 27/02/2013 - 22:50 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 27/02/2013 - 22:50 [server] Peer Connection Initiated with [AF_INET]31.193.12.74:53 27/02/2013 - 22:50 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 27/02/2013 - 22:50 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.9.0.1,comp-lzo no,route 10.9.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.9.0.174 10.9.0.173' 27/02/2013 - 22:50 OPTIONS IMPORT: timers and/or timeouts modified 27/02/2013 - 22:50 OPTIONS IMPORT: LZO parms modified 27/02/2013 - 22:50 OPTIONS IMPORT: --ifconfig/up options modified 27/02/2013 - 22:50 OPTIONS IMPORT: route options modified 27/02/2013 - 22:50 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 27/02/2013 - 22:50 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 27/02/2013 - 22:50 open_tun, tt->ipv6=0 27/02/2013 - 22:50 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{ACE4C446-A472-4DBB-8DD2-493F6507D1CD}.tap 27/02/2013 - 22:50 TAP-Windows Driver Version 9.9 27/02/2013 - 22:50 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.0.174/255.255.255.252 on interface {ACE4C446-A472-4DBB-8DD2-493F6507D1CD} [DHCP-serv: 10.9.0.173, lease-time: 31536000] 27/02/2013 - 22:50 Successful ARP Flush on interface [12] {ACE4C446-A472-4DBB-8DD2-493F6507D1CD} 27/02/2013 - 22:50 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 27/02/2013 - 22:50 C:\Windows\system32\route.exe ADD 31.193.12.74 MASK 255.255.255.255 192.168.0.1 27/02/2013 - 22:50 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 27/02/2013 - 22:50 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:50 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.0.173 27/02/2013 - 22:50 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:50 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:50 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.0.173 27/02/2013 - 22:50 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:50 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:50 C:\Windows\system32\route.exe ADD 10.9.0.1 MASK 255.255.255.255 10.9.0.173 27/02/2013 - 22:50 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:50 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:50 Initialization Sequence Completed 27/02/2013 - 22:50 Starting Management Interface... 27/02/2013 - 22:50 Checking... 27/02/2013 - 22:51 Retrieve statistics... 27/02/2013 - 22:51 Connected. 27/02/2013 - 22:55 Disconnecting... 27/02/2013 - 22:55 C:\Windows\system32\route.exe DELETE 10.9.0.1 MASK 255.255.255.255 10.9.0.173 27/02/2013 - 22:55 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:55 C:\Windows\system32\route.exe DELETE 31.193.12.74 MASK 255.255.255.255 192.168.0.1 27/02/2013 - 22:55 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:55 C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.9.0.173 27/02/2013 - 22:55 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:55 C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.9.0.173 27/02/2013 - 22:55 Route deletion via IPAPI succeeded [adaptive] 27/02/2013 - 22:55 Closing TUN/TAP interface 27/02/2013 - 22:55 SIGTERM[hard,] received, process exiting 27/02/2013 - 22:55 Disconnected. 27/02/2013 - 22:55 Login... 27/02/2013 - 22:55 Login success. 27/02/2013 - 22:55 Contacting service... 27/02/2013 - 22:55 Connecting... 27/02/2013 - 22:55 OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 27/02/2013 - 22:55 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 27/02/2013 - 22:55 Socket Buffers: R=[8192->8192] S=[8192->8192] 27/02/2013 - 22:55 UDPv4 link local: [undef] 27/02/2013 - 22:55 UDPv4 link remote: [AF_INET]31.193.12.74:53 27/02/2013 - 22:55 TLS: Initial packet from [AF_INET]31.193.12.74:53, sid=ba1d130d fcb68972 27/02/2013 - 22:55 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 27/02/2013 - 22:55 VERIFY OK: nsCertType=SERVER 27/02/2013 - 22:55 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 27/02/2013 - 22:55 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 27/02/2013 - 22:55 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 27/02/2013 - 22:55 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 27/02/2013 - 22:55 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 27/02/2013 - 22:55 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 27/02/2013 - 22:55 [server] Peer Connection Initiated with [AF_INET]31.193.12.74:53 27/02/2013 - 22:55 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 27/02/2013 - 22:55 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.8.0.1,comp-lzo no,route 10.8.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.8.1.42 10.8.1.41' 27/02/2013 - 22:55 OPTIONS IMPORT: timers and/or timeouts modified 27/02/2013 - 22:55 OPTIONS IMPORT: LZO parms modified 27/02/2013 - 22:55 OPTIONS IMPORT: --ifconfig/up options modified 27/02/2013 - 22:55 OPTIONS IMPORT: route options modified 27/02/2013 - 22:55 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 27/02/2013 - 22:55 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 27/02/2013 - 22:55 open_tun, tt->ipv6=0 27/02/2013 - 22:55 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{ACE4C446-A472-4DBB-8DD2-493F6507D1CD}.tap 27/02/2013 - 22:55 TAP-Windows Driver Version 9.9 27/02/2013 - 22:55 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.1.42/255.255.255.252 on interface {ACE4C446-A472-4DBB-8DD2-493F6507D1CD} [DHCP-serv: 10.8.1.41, lease-time: 31536000] 27/02/2013 - 22:55 Successful ARP Flush on interface [12] {ACE4C446-A472-4DBB-8DD2-493F6507D1CD} 27/02/2013 - 22:55 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 27/02/2013 - 22:55 C:\Windows\system32\route.exe ADD 31.193.12.74 MASK 255.255.255.255 192.168.0.1 27/02/2013 - 22:55 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 27/02/2013 - 22:55 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:55 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.1.41 27/02/2013 - 22:55 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:55 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:55 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.1.41 27/02/2013 - 22:55 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:55 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:55 C:\Windows\system32\route.exe ADD 10.8.0.1 MASK 255.255.255.255 10.8.1.41 27/02/2013 - 22:55 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 27/02/2013 - 22:55 Route addition via IPAPI succeeded [adaptive] 27/02/2013 - 22:55 Initialization Sequence Completed 27/02/2013 - 22:55 Starting Management Interface... 27/02/2013 - 22:55 Checking... 27/02/2013 - 22:55 Retrieve statistics... 27/02/2013 - 22:55 Connected. i hope we can fix this...because i want to renew membership...many thanks. Quote Share this post Link to post
Staff 10336 Posted ... its the dns for sure...just had an update windows 7 sp 1...strange thing is...would not connect after update with either comodo dns or your address 10.4.0.1...then after a little time i entered comodo dns again...same address and it now works...i should not have to enter dns address before every connection if i've chosen the dns..Hello!No problems at all are showed by all the data you sent us.Try to set 10.4.0.1 as primary (preferred) DNS IP address in your physical network card. Leave the secondary (alternate) DNS IP to your favorite DNS in order to allow names resolution when disconnected from the VPN.Kind regards Quote Share this post Link to post
andytattoo 0 Posted ... set primary as 10.4.0.1 and still won't work with udp connection...just tcp..is it a security risk not being able to use udp connections?? if not vpn still works on tcp, but still don't know why my client doesnt work with udp..... Quote Share this post Link to post
Staff 10336 Posted ... set primary as 10.4.0.1 and still won't work with udp connection...just tcp..is it a security risk not being able to use udp connections?? if not vpn still works on tcp, but still don't know why my client doesnt work with udp.....Hello!A possible cause might be a packet filtering program in your system that wrongly identifies the UDP traffic flow from our VPN servers as an UDP attack. When you connect to an UDP port, your system receives exclusively UDP packets on your physical network card, regardless of the underlying "real" packet header which is still encrypted when arrives to your system physical network card. If you receive a lot of traffic, some misconfigured or excessively prudent packet filtering program might think of it as an UDP flood and start dropping packets.Kind regards Quote Share this post Link to post
andytattoo 0 Posted ... hi...reformatted pc...fresh install...windows 7.. first program installed after anti virus was air vpn.. (apart from windows update)...but i check with various sites that stated that udp ports...443,80,53 were closed.. used cmd prompt netstat...no udp ports listening... so unless windows update has somehow blocked udp...now udp ports are closed when i check without air client running..i want to fix udp issues as various forums state that dns over tcp is not as secure as udp..do you know how to open udp ports on windows 7?? Quote Share this post Link to post
andytattoo 0 Posted ... pc has been restored...only program apart from air client is anti virus...now previous windows installation allowed udp...so cant figure out if its windows or my isp...any help would be appreciated... Quote Share this post Link to post
Staff 10336 Posted ... hi...reformatted pc...fresh install...windows 7.. first program installed after anti virus was air vpn.. (apart from windows update)...but i check with various sites that stated that udp ports...443,80,53 were closed.. used cmd prompt netstat...no udp ports listening... so unless windows update has somehow blocked udp...now udp ports are closed when i check without air client running..i want to fix udp issues as various forums state that dns over tcp is not as secure as udp..do you know how to open udp ports on windows 7??Hello!You don't need to open any inbound port on your system to access our service (why did you think so...?). On the contrary it may be good that those ports are closed. Can you please try with both your firewall and antivirus disabled? Can you please send us your client logs?Kind regards Quote Share this post Link to post
andytattoo 0 Posted ... 01/03/2013 - 03:37 AirVPN client version: 1.8 01/03/2013 - 03:37 Reading options from C:\Users\!!!\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 01/03/2013 - 03:37 OpenVPN bundle version: OpenVPN 2.3.0 01/03/2013 - 03:37 OpenVPN current version: OpenVPN 2.3.0 01/03/2013 - 03:37 Ready. 01/03/2013 - 03:38 Login... 01/03/2013 - 03:38 Login success. 01/03/2013 - 03:38 Contacting service... 01/03/2013 - 03:38 Connecting... 01/03/2013 - 03:38 OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 01/03/2013 - 03:38 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 01/03/2013 - 03:38 Socket Buffers: R=[8192->8192] S=[8192->8192] 01/03/2013 - 03:38 UDPv4 link local: [undef] 01/03/2013 - 03:38 UDPv4 link remote: [AF_INET]31.193.12.74:53 01/03/2013 - 03:38 TLS: Initial packet from [AF_INET]31.193.12.74:53, sid=50643b79 9ca86a12 01/03/2013 - 03:38 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 01/03/2013 - 03:38 VERIFY OK: nsCertType=SERVER 01/03/2013 - 03:38 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 01/03/2013 - 03:38 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 01/03/2013 - 03:38 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 01/03/2013 - 03:38 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 01/03/2013 - 03:38 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 01/03/2013 - 03:38 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 01/03/2013 - 03:38 [server] Peer Connection Initiated with [AF_INET]31.193.12.74:53 01/03/2013 - 03:38 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 01/03/2013 - 03:38 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.8.0.1,comp-lzo no,route 10.8.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.8.1.42 10.8.1.41' 01/03/2013 - 03:38 OPTIONS IMPORT: timers and/or timeouts modified 01/03/2013 - 03:38 OPTIONS IMPORT: LZO parms modified 01/03/2013 - 03:38 OPTIONS IMPORT: --ifconfig/up options modified 01/03/2013 - 03:38 OPTIONS IMPORT: route options modified 01/03/2013 - 03:38 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 01/03/2013 - 03:38 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 01/03/2013 - 03:38 open_tun, tt->ipv6=0 01/03/2013 - 03:38 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{8A77E731-0E75-465B-9C32-9C59EFB0ECAC}.tap 01/03/2013 - 03:38 TAP-Windows Driver Version 9.9 01/03/2013 - 03:38 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.1.42/255.255.255.252 on interface {8A77E731-0E75-465B-9C32-9C59EFB0ECAC} [DHCP-serv: 10.8.1.41, lease-time: 31536000] 01/03/2013 - 03:38 Successful ARP Flush on interface [23] {8A77E731-0E75-465B-9C32-9C59EFB0ECAC} 01/03/2013 - 03:38 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 01/03/2013 - 03:38 C:\Windows\system32\route.exe ADD 31.193.12.74 MASK 255.255.255.255 192.168.0.1 01/03/2013 - 03:38 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 01/03/2013 - 03:38 Route addition via IPAPI succeeded [adaptive] 01/03/2013 - 03:38 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.1.41 01/03/2013 - 03:38 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 01/03/2013 - 03:38 Route addition via IPAPI succeeded [adaptive] 01/03/2013 - 03:38 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.1.41 01/03/2013 - 03:38 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 01/03/2013 - 03:38 Route addition via IPAPI succeeded [adaptive] 01/03/2013 - 03:38 C:\Windows\system32\route.exe ADD 10.8.0.1 MASK 255.255.255.255 10.8.1.41 01/03/2013 - 03:38 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 01/03/2013 - 03:38 Route addition via IPAPI succeeded [adaptive] 01/03/2013 - 03:38 Initialization Sequence Completed 01/03/2013 - 03:38 Starting Management Interface... 01/03/2013 - 03:38 Checking... 01/03/2013 - 03:38 Retrieve statistics... 01/03/2013 - 03:38 Connected. 01/03/2013 - 03:48 Disconnecting... 01/03/2013 - 03:48 SIGTERM received, sending exit notification to peer 01/03/2013 - 03:48 C:\Windows\system32\route.exe DELETE 10.8.0.1 MASK 255.255.255.255 10.8.1.41 01/03/2013 - 03:48 Route deletion via IPAPI succeeded [adaptive] 01/03/2013 - 03:48 C:\Windows\system32\route.exe DELETE 31.193.12.74 MASK 255.255.255.255 192.168.0.1 01/03/2013 - 03:48 Route deletion via IPAPI succeeded [adaptive] 01/03/2013 - 03:48 C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.8.1.41 01/03/2013 - 03:48 Route deletion via IPAPI succeeded [adaptive] 01/03/2013 - 03:48 C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.8.1.41 01/03/2013 - 03:48 Route deletion via IPAPI succeeded [adaptive] 01/03/2013 - 03:48 Closing TUN/TAP interface 01/03/2013 - 03:48 SIGTERM[hard,] received, process exiting 01/03/2013 - 03:48 Disconnected. 01/03/2013 - 03:48 Login... 01/03/2013 - 03:48 Login success. 01/03/2013 - 03:48 Contacting service... 01/03/2013 - 03:48 Connecting... 01/03/2013 - 03:48 OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 01/03/2013 - 03:48 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 01/03/2013 - 03:48 Socket Buffers: R=[8192->8192] S=[8192->8192] 01/03/2013 - 03:48 Attempting to establish TCP connection with [AF_INET]31.193.12.74:53 01/03/2013 - 03:48 TCP connection established with [AF_INET]31.193.12.74:53 01/03/2013 - 03:48 TCPv4_CLIENT link local: [undef] 01/03/2013 - 03:48 TCPv4_CLIENT link remote: [AF_INET]31.193.12.74:53 01/03/2013 - 03:48 TLS: Initial packet from [AF_INET]31.193.12.74:53, sid=6e8ca53d 82fc950c 01/03/2013 - 03:48 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 01/03/2013 - 03:48 VERIFY OK: nsCertType=SERVER 01/03/2013 - 03:48 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 01/03/2013 - 03:48 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 01/03/2013 - 03:48 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 01/03/2013 - 03:48 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 01/03/2013 - 03:48 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 01/03/2013 - 03:48 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 01/03/2013 - 03:48 [server] Peer Connection Initiated with [AF_INET]31.193.12.74:53 01/03/2013 - 03:48 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 01/03/2013 - 03:48 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.9.0.1,comp-lzo no,route 10.9.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.9.0.174 10.9.0.173' 01/03/2013 - 03:48 OPTIONS IMPORT: timers and/or timeouts modified 01/03/2013 - 03:48 OPTIONS IMPORT: LZO parms modified 01/03/2013 - 03:48 OPTIONS IMPORT: --ifconfig/up options modified 01/03/2013 - 03:48 OPTIONS IMPORT: route options modified 01/03/2013 - 03:48 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 01/03/2013 - 03:48 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 01/03/2013 - 03:48 open_tun, tt->ipv6=0 01/03/2013 - 03:48 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{8A77E731-0E75-465B-9C32-9C59EFB0ECAC}.tap 01/03/2013 - 03:48 TAP-Windows Driver Version 9.9 01/03/2013 - 03:48 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.0.174/255.255.255.252 on interface {8A77E731-0E75-465B-9C32-9C59EFB0ECAC} [DHCP-serv: 10.9.0.173, lease-time: 31536000] 01/03/2013 - 03:48 Successful ARP Flush on interface [23] {8A77E731-0E75-465B-9C32-9C59EFB0ECAC} 01/03/2013 - 03:48 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 01/03/2013 - 03:48 C:\Windows\system32\route.exe ADD 31.193.12.74 MASK 255.255.255.255 192.168.0.1 01/03/2013 - 03:48 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 01/03/2013 - 03:48 Route addition via IPAPI succeeded [adaptive] 01/03/2013 - 03:48 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.0.173 01/03/2013 - 03:48 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 01/03/2013 - 03:48 Route addition via IPAPI succeeded [adaptive] 01/03/2013 - 03:48 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.0.173 01/03/2013 - 03:48 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 01/03/2013 - 03:48 Route addition via IPAPI succeeded [adaptive] 01/03/2013 - 03:48 C:\Windows\system32\route.exe ADD 10.9.0.1 MASK 255.255.255.255 10.9.0.173 01/03/2013 - 03:48 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 01/03/2013 - 03:48 Route addition via IPAPI succeeded [adaptive] 01/03/2013 - 03:48 Initialization Sequence Completed 01/03/2013 - 03:48 Starting Management Interface... 01/03/2013 - 03:48 Checking... 01/03/2013 - 03:49 Retrieve statistics... 01/03/2013 - 03:49 Connected. now i've been looking at the log..and there is a slight difference from when i connect with udp and tcp...with tcp connection it says (attempting to establish tcp connection with etc etc)...and (tcp connection established with etc etc) but with udp part of log...it never says attempting connection, or established connection.. its just after Socket Buffers: R=[8192->8192] S=[8192->8192]... Quote Share this post Link to post
Staff 10336 Posted ... Hello! The logs you posted are just fine, they show a fully successful connection to port 53 UDP and a fully successful connection to port 53 TCP of some server of ours. Considering all the information you gave us and assuming that you're 100% sure that nothing in your system prevents UDP packets to go to outbound port 443, chances are that your ISP is dropping packets to outbound port 443 UDP in which case you can continue connecting to port 53 UDP. Kind regards Quote Share this post Link to post
andytattoo 0 Posted ... no i can't...all connections using udp, ports 443,80,53 connect with air vpn but cant browse internet while connected to these ports! port 443tcp works...port 80 tcp works...port 53 tcp works...but anything with udp does not... Quote Share this post Link to post
andytattoo 0 Posted ... using cmd.exe on desktop... netstat -a shows udp connections are getting to local address but not foreign address.. Quote Share this post Link to post
Staff 10336 Posted ... using cmd.exe on desktop... netstat -a shows udp connections are getting to local address but not foreign address..Hello!So the problem is not on your ISP side, but in your system (please note however that to speak correctly, there are no such things as UDP connections, UDP is connectionless, so don't be fooled, just in case...).In order to locate the "culprit" try to monitor your network activities and progressively deactivate any possible interfering program, starting from firewall, "security" tools, antivirus, packet filtering programs of any kind.Kind regards Quote Share this post Link to post
andytattoo 0 Posted ... Thanks for all your help...but i found the problem...it was the router that wasn't allowing udp connections to leave the network...although the nat firewall on router was configured to allow all outgoing connections it was blocking all udp.....so UDP is now working...many thanks for your assistance.. Quote Share this post Link to post
andytattoo 0 Posted ... the reason my router was blocking udp was because of a hydra attack on my router... when browsing internet i got a webpage with hydra on it... now im experiencing slow browsing and have a page from google stating unusual traffic...and i'm having to fill in captcha form...every time i try to go to and other page on internet..has my network been hacked again? i'm now using comodo firewall but on network detection page, when i click on home network (192.168.1.137/24 it doesn't do anything... Quote Share this post Link to post
