bathysphere 0 Posted ... AirVPN + Tunnelblick + OSX 10.7.5 was previously working fine for me. I reinstalled my OS (still 10.7.5), downloaded the latest Tunnelblick client (3.3beta32) and used the latest AirVPN configuration builder and now it doesn't work. Tunnelblick connects, downloads configuration, then immediately disconnects. Below is a typical log file. Any ideas what I can do to fix this? Thanks! 2013-02-23 10:54:23 OpenVPN 2.3-alpha1 i386-apple-darwin10.8.0 [sSL (OpenSSL)] [LZO2] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110522-1 (2.2.0)] built on Oct 20 2012 2013-02-23 10:54:23 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337 2013-02-23 10:54:23 Need hold release from management interface, waiting... 2013-02-23 10:54:23 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337 2013-02-23 10:54:23 MANAGEMENT: CMD 'pid' 2013-02-23 10:54:23 MANAGEMENT: CMD 'state on' 2013-02-23 10:54:23 MANAGEMENT: CMD 'state' 2013-02-23 10:54:23 MANAGEMENT: CMD 'bytecount 1' 2013-02-23 10:54:23 MANAGEMENT: CMD 'hold release' 2013-02-23 10:54:23 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 2013-02-23 10:54:23 Socket Buffers: R=[42080->65536] S=[9216->65536] 2013-02-23 10:54:23 UDPv4 link local: [undef] 2013-02-23 10:54:23 UDPv4 link remote: [AF_INET]69.163.36.66:443 2013-02-23 10:54:23 MANAGEMENT: >STATE:1361645663,WAIT,,, 2013-02-23 10:54:23 MANAGEMENT: >STATE:1361645663,AUTH,,, 2013-02-23 10:54:23 TLS: Initial packet from [AF_INET]69.163.36.66:443, sid=d599e6ae ab5bb4d7 2013-02-23 10:54:23 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 2013-02-23 10:54:23 VERIFY OK: nsCertType=SERVER 2013-02-23 10:54:23 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 2013-02-23 10:54:23 *Tunnelblick: openvpnstart starting OpenVPN: * /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3-alpha1/openvpn --cd /Library/Application Support/Tunnelblick/Users/philipmorg/AirVPN US Vega - UDP 443.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Library/Application Support/Tunnelblick/Users/philipmorg/AirVPN US Vega - UDP 443.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Sphilipmorg-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN US Vega -- UDP 443.tblk-SContents-SResources-Sconfig.ovpn.1_0_1_0_305.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --up-restart --route-pre-down /Applications/Tunnelblick.app/Contents/Resources/client.route-pre-down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw 2013-02-23 10:54:29 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-02-23 10:54:29 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-02-23 10:54:29 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-02-23 10:54:29 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-02-23 10:54:29 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 2013-02-23 10:54:29 [server] Peer Connection Initiated with [AF_INET]69.163.36.66:443 2013-02-23 10:54:30 MANAGEMENT: >STATE:1361645670,GET_CONFIG,,, 2013-02-23 10:54:31 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2013-02-23 10:54:33 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.0.106 10.4.0.105' 2013-02-23 10:54:33 OPTIONS IMPORT: timers and/or timeouts modified 2013-02-23 10:54:33 OPTIONS IMPORT: LZO parms modified 2013-02-23 10:54:33 OPTIONS IMPORT: --ifconfig/up options modified 2013-02-23 10:54:33 OPTIONS IMPORT: route options modified 2013-02-23 10:54:33 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 2013-02-23 10:54:33 ROUTE_GATEWAY 192.168.101.1/255.255.255.0 IFACE=en0 HWADDR=c8:2a:14:55:30:49 2013-02-23 10:54:33 TUN/TAP device /dev/tun0 opened 2013-02-23 10:54:33 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 2013-02-23 10:54:33 MANAGEMENT: >STATE:1361645673,ASSIGN_IP,,10.4.0.106, 2013-02-23 10:54:33 /sbin/ifconfig tun0 delete ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address 2013-02-23 10:54:33 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure 2013-02-23 10:54:33 /sbin/ifconfig tun0 10.4.0.106 10.4.0.105 mtu 1500 netmask 255.255.255.255 up 2013-02-23 10:54:33 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw tun0 1500 1558 10.4.0.106 10.4.0.105 init launchctl: Dubious ownership on file (skipping): /Library/Application Support/Tunnelblick/LeaseWatch.plist nothing found to load 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and SMB server(s) [ ] and using default domain name [ openvpn ] 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_CONFIG = No such key 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_CONFIG = No such key 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_CONFIG = <dictionary> { ServerAddresses : <array> { 192.168.101.1 } } 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_CONFIG = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_DNS_DN = openvpn; DYN_DNS_SA = 10.4.0.1; DYN_DNS_SD = 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_SMB_NN = ; DYN_SMB_WG = ; DYN_SMB_WA = 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_DN = ; MAN_DNS_SA = ; MAN_DNS_SD = 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_NN = ; MAN_SMB_WG = ; MAN_SMB_WA = 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_DN = ; CUR_DNS_SA = 192.168.101.1; CUR_DNS_SD = 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_NN = ; CUR_SMB_WG = ; CUR_SMB_WA = 192.168.101.1 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: ServerAddresses were not aggregated because running on OS X 10.6 or higher 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: Setting search domains to 'openvpn' because running under OS X 10.6 or higher and the search domains were not set manually and 'Prepend domain name to search domains' was not selected 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_DNS_DN = openvpn; FIN_DNS_SA = 10.4.0.1; FIN_DNS_SD = openvpn 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_SMB_NN = ; FIN_SMB_WG = ; FIN_SMB_WA = 192.168.101.1 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: OS X 10.7 and neither ServerAddresses nor SearchDomains were set manually, so will modify DNS settings using only State: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_DNS = ; SKP_DNS_SA = ; SKP_DNS_SD = ; SKP_DNS_DN = 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SETUP_DNS = # 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SMB = #; SKP_SMB_NN = #; SKP_SMB_WG = #; SKP_SMB_WA = # 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configuration changes: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: ServerAddresses 10.4.0.1 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: SearchDomains openvpn 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: DomainName openvpn 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: #ADD Setup: ServerAddresses 10.4.0.1 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: #ADD Setup: SearchDomains openvpn 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: #ADD Setup: DomainName openvpn 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: NetBIOSName 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: Workgroup 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: WINSAddresses 192.168.101.1 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:35 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Pause for configuration changes to be propagated to State:/Network/Global/DNS and .../SMB 2013-02-23 10:54:36 MANAGEMENT: Client disconnected 2013-02-23 10:54:36 WARNING: Failed running command (--up/--down): external program exited with error status: 1 2013-02-23 10:54:36 Exiting due to fatal error 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configurations as read back after changes: 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } } 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../SMB = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../DNS = No such key 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../SMB = No such key 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } } 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/SMB = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Expected by process-network-changes: 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } } 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/SMB = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 10:54:36 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and SMB configurations for later use Quote Share this post Link to post
Staff 10386 Posted ... AirVPN + Tunnelblick + OSX 10.7.5 was previously working fine for me. I reinstalled my OS (still 10.7.5), downloaded the latest Tunnelblick client (3.3beta32) and used the latest AirVPN configuration builder and now it doesn't work. Tunnelblick connects, downloads configuration, then immediately disconnects. Below is a typical log file. Any ideas what I can do to fix this? Thanks!Hello!Can you please try to switch to Tunnelblick 3.3beta21b or 3.2.8?Kind regards Quote Share this post Link to post
bathysphere 0 Posted ... OK, I've switched to 3.3beta21b, and i"m getting a similar result. Here's the log file, and thanks in advance for any help: 2013-02-23 15:50:13 OpenVPN 2.3-alpha1 i386-apple-darwin10.8.0 [sSL (OpenSSL)] [LZO2] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110522-1 (2.2.0)] built on Oct 27 2012 2013-02-23 15:50:13 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337 2013-02-23 15:50:13 Need hold release from management interface, waiting... 2013-02-23 15:50:13 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337 2013-02-23 15:50:13 MANAGEMENT: CMD 'pid' 2013-02-23 15:50:13 MANAGEMENT: CMD 'state on' 2013-02-23 15:50:13 MANAGEMENT: CMD 'state' 2013-02-23 15:50:13 MANAGEMENT: CMD 'bytecount 1' 2013-02-23 15:50:13 MANAGEMENT: CMD 'hold release' 2013-02-23 15:50:13 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 2013-02-23 15:50:13 Socket Buffers: R=[42080->65536] S=[9216->65536] 2013-02-23 15:50:13 UDPv4 link local: [undef] 2013-02-23 15:50:13 UDPv4 link remote: [AF_INET]69.163.36.66:443 2013-02-23 15:50:13 MANAGEMENT: >STATE:1361663413,WAIT,,, 2013-02-23 15:50:13 MANAGEMENT: >STATE:1361663413,AUTH,,, 2013-02-23 15:50:13 TLS: Initial packet from [AF_INET]69.163.36.66:443, sid=92f94eab d90e07f7 2013-02-23 15:50:13 *Tunnelblick: openvpnstart starting OpenVPN: * /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3-alpha1/openvpn --cd /Users/philipmorg/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/philipmorg/Library/Application Support/Tunnelblick/Configurations/AirVPN US Vega - UDP 443.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Sphilipmorg-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN US Vega -- UDP 443.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atADGNWradsgnw --up-restart --route-pre-down /Applications/Tunnelblick.app/Contents/Resources/client.route-pre-down.tunnelblick.sh -m -w -d -atADGNWradsgnw 2013-02-23 15:50:19 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 2013-02-23 15:50:19 VERIFY OK: nsCertType=SERVER 2013-02-23 15:50:19 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 2013-02-23 15:50:20 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-02-23 15:50:20 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-02-23 15:50:20 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-02-23 15:50:20 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-02-23 15:50:20 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 2013-02-23 15:50:20 [server] Peer Connection Initiated with [AF_INET]69.163.36.66:443 2013-02-23 15:50:21 MANAGEMENT: >STATE:1361663421,GET_CONFIG,,, 2013-02-23 15:50:22 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2013-02-23 15:50:24 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.0.106 10.4.0.105' 2013-02-23 15:50:24 OPTIONS IMPORT: timers and/or timeouts modified 2013-02-23 15:50:24 OPTIONS IMPORT: LZO parms modified 2013-02-23 15:50:24 OPTIONS IMPORT: --ifconfig/up options modified 2013-02-23 15:50:24 OPTIONS IMPORT: route options modified 2013-02-23 15:50:24 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 2013-02-23 15:50:24 ROUTE_GATEWAY 192.168.101.1/255.255.255.0 IFACE=en0 HWADDR=c8:2a:14:55:30:49 2013-02-23 15:50:24 TUN/TAP device /dev/tun0 opened 2013-02-23 15:50:24 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 2013-02-23 15:50:24 MANAGEMENT: >STATE:1361663424,ASSIGN_IP,,10.4.0.106, 2013-02-23 15:50:24 /sbin/ifconfig tun0 delete ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address 2013-02-23 15:50:24 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure 2013-02-23 15:50:24 /sbin/ifconfig tun0 10.4.0.106 10.4.0.105 mtu 1500 netmask 255.255.255.255 up 2013-02-23 15:50:24 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atADGNWradsgnw tun0 1500 1558 10.4.0.106 10.4.0.105 init launchctl: Dubious ownership on file (skipping): /Library/Application Support/Tunnelblick/LeaseWatch.plist nothing found to load 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and SMB server(s) [ ] and using default domain name [ openvpn ] 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_CONFIG = No such key 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_CONFIG = No such key 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_CONFIG = <dictionary> { ServerAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_CONFIG = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_DNS_DN = openvpn; DYN_DNS_SA = 10.4.0.1; DYN_DNS_SD = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_SMB_NN = ; DYN_SMB_WG = ; DYN_SMB_WA = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_DN = ; MAN_DNS_SA = ; MAN_DNS_SD = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_NN = ; MAN_SMB_WG = ; MAN_SMB_WA = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_DN = ; CUR_DNS_SA = 192.168.101.1; CUR_DNS_SD = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_NN = ; CUR_SMB_WG = ; CUR_SMB_WA = 192.168.101.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: ServerAddresses were not aggregated because running on OS X 10.6 or higher 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: Setting search domains to 'openvpn' because running under OS X 10.6 or higher and the search domains were not set manually and 'Prepend domain name to search domains' was not selected 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_DNS_DN = openvpn; FIN_DNS_SA = 10.4.0.1; FIN_DNS_SD = openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_SMB_NN = ; FIN_SMB_WG = ; FIN_SMB_WA = 192.168.101.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: OS X 10.7 and neither ServerAddresses nor SearchDomains were set manually, so will modify DNS settings using only State: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_DNS = ; SKP_DNS_SA = ; SKP_DNS_SD = ; SKP_DNS_DN = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SETUP_DNS = # 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SMB = #; SKP_SMB_NN = #; SKP_SMB_WG = #; SKP_SMB_WA = # 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configuration changes: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: ServerAddresses 10.4.0.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: SearchDomains openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: DomainName openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: #ADD Setup: ServerAddresses 10.4.0.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: #ADD Setup: SearchDomains openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: #ADD Setup: DomainName openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: NetBIOSName 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: Workgroup 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: WINSAddresses 192.168.101.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Pause for configuration changes to be propagated to State:/Network/Global/DNS and .../SMB 2013-02-23 15:50:27 MANAGEMENT: Client disconnected 2013-02-23 15:50:27 WARNING: Failed running command (--up/--down): external program exited with error status: 1 2013-02-23 15:50:27 Exiting due to fatal error 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configurations as read back after changes: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../SMB = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../DNS = No such key 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../SMB = No such key 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/SMB = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Expected by process-network-changes: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/SMB = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and SMB configurations for later use Quote Share this post Link to post
bathysphere 0 Posted ... I did a thorough uninstall, and installed 3.3beta21b, and the behavior is pretty much the same. Here's the new log file, and thanks in advance for any help! 2013-02-23 15:50:13 OpenVPN 2.3-alpha1 i386-apple-darwin10.8.0 [sSL (OpenSSL)] [LZO2] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110522-1 (2.2.0)] built on Oct 27 2012 2013-02-23 15:50:13 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337 2013-02-23 15:50:13 Need hold release from management interface, waiting... 2013-02-23 15:50:13 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337 2013-02-23 15:50:13 MANAGEMENT: CMD 'pid' 2013-02-23 15:50:13 MANAGEMENT: CMD 'state on' 2013-02-23 15:50:13 MANAGEMENT: CMD 'state' 2013-02-23 15:50:13 MANAGEMENT: CMD 'bytecount 1' 2013-02-23 15:50:13 MANAGEMENT: CMD 'hold release' 2013-02-23 15:50:13 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 2013-02-23 15:50:13 Socket Buffers: R=[42080->65536] S=[9216->65536] 2013-02-23 15:50:13 UDPv4 link local: [undef] 2013-02-23 15:50:13 UDPv4 link remote: [AF_INET]69.163.36.66:443 2013-02-23 15:50:13 MANAGEMENT: >STATE:1361663413,WAIT,,, 2013-02-23 15:50:13 MANAGEMENT: >STATE:1361663413,AUTH,,, 2013-02-23 15:50:13 TLS: Initial packet from [AF_INET]69.163.36.66:443, sid=92f94eab d90e07f7 2013-02-23 15:50:13 *Tunnelblick: openvpnstart starting OpenVPN: * /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3-alpha1/openvpn --cd /Users/philipmorg/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/philipmorg/Library/Application Support/Tunnelblick/Configurations/AirVPN US Vega - UDP 443.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Sphilipmorg-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN US Vega -- UDP 443.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atADGNWradsgnw --up-restart --route-pre-down /Applications/Tunnelblick.app/Contents/Resources/client.route-pre-down.tunnelblick.sh -m -w -d -atADGNWradsgnw 2013-02-23 15:50:19 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 2013-02-23 15:50:19 VERIFY OK: nsCertType=SERVER 2013-02-23 15:50:19 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 2013-02-23 15:50:20 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-02-23 15:50:20 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-02-23 15:50:20 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 2013-02-23 15:50:20 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 2013-02-23 15:50:20 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 2013-02-23 15:50:20 [server] Peer Connection Initiated with [AF_INET]69.163.36.66:443 2013-02-23 15:50:21 MANAGEMENT: >STATE:1361663421,GET_CONFIG,,, 2013-02-23 15:50:22 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2013-02-23 15:50:24 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.0.106 10.4.0.105' 2013-02-23 15:50:24 OPTIONS IMPORT: timers and/or timeouts modified 2013-02-23 15:50:24 OPTIONS IMPORT: LZO parms modified 2013-02-23 15:50:24 OPTIONS IMPORT: --ifconfig/up options modified 2013-02-23 15:50:24 OPTIONS IMPORT: route options modified 2013-02-23 15:50:24 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 2013-02-23 15:50:24 ROUTE_GATEWAY 192.168.101.1/255.255.255.0 IFACE=en0 HWADDR=c8:2a:14:55:30:49 2013-02-23 15:50:24 TUN/TAP device /dev/tun0 opened 2013-02-23 15:50:24 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 2013-02-23 15:50:24 MANAGEMENT: >STATE:1361663424,ASSIGN_IP,,10.4.0.106, 2013-02-23 15:50:24 /sbin/ifconfig tun0 delete ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address 2013-02-23 15:50:24 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure 2013-02-23 15:50:24 /sbin/ifconfig tun0 10.4.0.106 10.4.0.105 mtu 1500 netmask 255.255.255.255 up 2013-02-23 15:50:24 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atADGNWradsgnw tun0 1500 1558 10.4.0.106 10.4.0.105 init launchctl: Dubious ownership on file (skipping): /Library/Application Support/Tunnelblick/LeaseWatch.plist nothing found to load 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and SMB server(s) [ ] and using default domain name [ openvpn ] 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_CONFIG = No such key 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_CONFIG = No such key 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_CONFIG = <dictionary> { ServerAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_CONFIG = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_DNS_DN = openvpn; DYN_DNS_SA = 10.4.0.1; DYN_DNS_SD = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_SMB_NN = ; DYN_SMB_WG = ; DYN_SMB_WA = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_DN = ; MAN_DNS_SA = ; MAN_DNS_SD = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_NN = ; MAN_SMB_WG = ; MAN_SMB_WA = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_DN = ; CUR_DNS_SA = 192.168.101.1; CUR_DNS_SD = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_NN = ; CUR_SMB_WG = ; CUR_SMB_WA = 192.168.101.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: ServerAddresses were not aggregated because running on OS X 10.6 or higher 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: Setting search domains to 'openvpn' because running under OS X 10.6 or higher and the search domains were not set manually and 'Prepend domain name to search domains' was not selected 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_DNS_DN = openvpn; FIN_DNS_SA = 10.4.0.1; FIN_DNS_SD = openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_SMB_NN = ; FIN_SMB_WG = ; FIN_SMB_WA = 192.168.101.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: OS X 10.7 and neither ServerAddresses nor SearchDomains were set manually, so will modify DNS settings using only State: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_DNS = ; SKP_DNS_SA = ; SKP_DNS_SD = ; SKP_DNS_DN = 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SETUP_DNS = # 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SMB = #; SKP_SMB_NN = #; SKP_SMB_WG = #; SKP_SMB_WA = # 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configuration changes: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: ServerAddresses 10.4.0.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: SearchDomains openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: DomainName openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: #ADD Setup: ServerAddresses 10.4.0.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: #ADD Setup: SearchDomains openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: #ADD Setup: DomainName openvpn 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: NetBIOSName 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: Workgroup 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: WINSAddresses 192.168.101.1 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:26 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Pause for configuration changes to be propagated to State:/Network/Global/DNS and .../SMB 2013-02-23 15:50:27 MANAGEMENT: Client disconnected 2013-02-23 15:50:27 WARNING: Failed running command (--up/--down): external program exited with error status: 1 2013-02-23 15:50:27 Exiting due to fatal error 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configurations as read back after changes: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../SMB = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../DNS = No such key 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../SMB = No such key 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/SMB = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Expected by process-network-changes: 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/SMB = <dictionary> { WINSAddresses : <array> { 192.168.101.1 } } 2013-02-23 15:50:27 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and SMB configurations for later use Quote Share this post Link to post
