Not connected, Your IP: 216.73.216.124
zebulon
DNS not reinstated at exit with network lock using systemd-resolved in stub mode
I have an issue after I switched from manual mode to stub mode using systemd-resolved. My /etc/resolv.conf file is a symlink to /run/systemd/resolve/stub-resolv.conf as described in https://wiki.archlinux.org/title/Systemd-resolved#DNS.
Before I run eddie-ui v2.24.6, my resolvectl status shows:
$ resolvectl
Global
           Protocols: +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
    resolv.conf mode: stub
Fallback DNS Servers: 9.9.9.9#dns.quad9.net 2620:fe::9#dns.quad9.net 1.1.1.1#cloudflare-dns.com 2606:4700:4700::1111#cloudflare-dns.com 8.8.8.8#dns.google
                      2001:4860:4860::8888#dns.google
Link 2 (enp12s0)
    Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 mDNS/IPv4 mDNS/IPv6
         Protocols: +DefaultRoute +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
Current DNS Server: 192.168.0.1
       DNS Servers: 192.168.0.1 2a02:8070:d483:bf20:2e00:abff:fe88:c64
     Default Route: yes
Link 4 (wlan0)
    Current Scopes: none
         Protocols: -DefaultRoute +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
     Default Route: no
192.168.0.1 is the address of my router, which uses my ISP DNS (I know, I should fix this...)
If I activate Network Lock, I get:
Global
Link 2 (enp12s0)
     Default Route: yes
Link 4 (wlan0)
       DNS Servers: 10.128.0.1 fd7d:76ee:e68f:a993::1
     Default Route: no
Note it changes the DNS for Link 4 (wlan0), wlthough Wifi is deactivated on that machine (I use wired Ethernet, plugged to the router).
I can deactivate Network lock and connect to the Internet again.
However, if I join a VPN server (connect to a recommended server):
Global
    resolv.conf mode: foreign
  Current DNS Server: fd7d:76ee:e68f:a993::1
Link 2 (enp12s0)
Current DNS Server: 10.128.0.1
     Default Route: no
Link 4 (wlan0)
     Default Route: no
Link 6 (Eddie)
    Current Scopes: DNS
     Default Route: no
I can access Internet, my DNS is then 10.128.0.1.
The problem occurs when I exit Eddie-ui, or if I disconnect to network and unlock Network lock.
Global
Link 2 (enp12s0)
     Default Route: yes
Link 4 (wlan0)
     Default Route: no
Here Link2 still has 10.128.0.1 as DNS server, but I am blocked because I am disconnected from the VPN server.
Only a restart of systemd-resolved allows me to return to correct DNS:
$ sudo systemctl restart systemd-resolved
$ resolvectl
Global
Link 2 (enp12s0)
     Default Route: yes
Link 4 (wlan0)
     Default Route: no
Interestingly, if before I restart systemd-resolved I run Eddie-ui again, if I try to activate the network lock then it is stuck with "Activate Network lock via nftables". I am unsure if this is related.
It seems there is an issue on my system where Edie cannot reinstate DNS properly. Any idea? Am I doing something wrong?
Note I am happy to provide logs, but while performing tests it seems to be stuck until I restart systemd-resolved. So I am afraid the log itself is tainted. that said, here you can find it attached:
eddie-log-20260123.txt
@zebulon
Please note that Network Lock has nothing to do with DNS settings.
Now, the problem seems here:
Quote
. 2026.01.23 13:42:11 - DNS of the system restored - via /etc/resolv.conf) <-- something goes wrong here
. 2026.01.23 13:38:26 - DNS of the interface 'enp12s0' restored to '192.168.0.1 2a02:8070:d483:bf20:2e00:abff:fe88:c64' - via systemd-resolved <-- correct
. 2026.01.23 13:38:26 - Default Route of the interface 'enp12s0' restored to 'yes' - via systemd-resolved <-- correct as wlan0 is down
. 2026.01.23 13:38:26 - DNS of the interface 'wlan0' restored to '10.128.0.1 fd7d:76ee:e68f:a993::1' - via systemd-resolved <-- another problem
In other words, the previous DNS setting for wlan0 were 10.128.0.1 and fd7d:76ee:e68f:a993::1 according to Eddie. So it's possible that Eddie restores the system DNS settings as expected, but with the same VPN DNS, even for /etc/resolv.conf. Somehow in a previous session the proper DNS settings were not restored and Eddie takes (now correctly, the error must have occurred in a previous session) those settings as the original system settings in subsequent sessions.
Please try this: set all the correct DNS (globally and for each interface) while Eddie is not running, delete Eddie configuration file ~/.config/eddie/default.profile, make sure that only WiFi or only Ethernet is connected, re-start Eddie and try again.
Hi, thanks for your support. Unfortunately it does not work: I set up 9.9.9.9 for all interfaces using NetworkManager. I also deleted  .config/eddie/default.profile
$ resolvectl
Global
  Current DNS Server: 9.9.9.9#dns.quad9.net
Link 2 (enp12s0)
       DNS Servers: 9.9.9.9 192.168.0.1 2606:4700:4700::1111 2a02:8070:d483:bf20:2e00:abff:fe88:c64
     Default Route: yes
Link 4 (wlan0)
     Default Route: no
Then I used Eddie to connect (as you mention, regardless of Network Lock, so I did not lock this time):
$ resolvectl
Global
Link 2 (enp12s0)
     Default Route: no
Link 4 (wlan0)
     Default Route: no
Link 5 (Eddie)
    Current Scopes: DNS
     Default Route: no
Then I exit Eddie:
$ resolvectl
Global
Link 2 (enp12s0)
     Default Route: yes
Link 4 (wlan0)
     Default Route: no
Here I do not have resolving. Eddie did not reinstate 9.9.9.9 to my interfaces. If I restart systemd-resolved:
$ resolvectl
Global
Link 2 (enp12s0)
     Default Route: yes
Link 4 (wlan0)
     Default Route: no
this works again.
This suggests a bug when Eddie handles stub based systemd-resolved configuration, no? Could Eddie simply restart systemd-resolved at exit? It has root permission. Would it be a possible solution?
Note I also try to define a file:
/etc/systemd/resolved.conf.d/dns_servers.conf
[Resolve]
DNS=1.1.1.2
Although this works without VPN, then when I try to connect to a server with Eddie, then it fails at "Checking DNS" step and tries to reconnect indefinitely.
I created a log when it cannot check the VPN, when systemd-resolved uses the file /etc/systemd/resolved.conf.d/dns_servers.conf I just described above:
eddie-log-20260124.txt
Your /etc/resolv.conf file is not a symlink according to Eddie. Question: in NetworkManager configuration, do you have something like:
[main]
dns=systemd-resolved
If you set DNS directly via NetworkManager and NM is not configured as above, NM overwrites /etc/resolv.conf file (this would explain why it's not a symlink when you run Eddie). At the next systemd-resolved (re)start, it is over-written again as a symlink (this would explain why you see it as a symlink in your initial report and you need to re-start systemd-resolved each time).
You should manage DNS either through NetworkManager only,  systemd-resolved only (explicit delegation to systemd-resolved must be enforced on NM if you need to run it for other reasons), or by getting rid of Windows-like DNS management (go back to /etc/resolv.conf rock solid, old school management, optionally having NM manage resolv.conf directly). (*)  Avoid any hodgepodge of different DNS managements, they come from Windows-style duct-taped DNS management jumble that have caused decades of huge problems including DNS leaks (we remember well svchost.exe DNS leaks disasters).
(*) Should you decide to disable systemd-resolved completely remember to stop, disable and mask it, otherwise it may (will) be re-enabled and re-started without your knowledge by systemd.
Maybe not, see here:
Quote
. 2026.01.24 10:13:39 - DNS of the interface 'enp12s0' restored to '9.9.9.9 192.168.0.1 2606:4700:4700::1111 2a02:8070:d483:bf20:2e00:abff:fe88:c64' - via systemd-resolved
Note how Eddie restores the previous DNS on enp12s0 correctly, and the previous resolv.conf backed up file that was not a symlink but contained the VPN DNS possibly for the reason previously explained or maybe for a mixture of NM / systemd-resolved concurrent usage. Try to delete the resolv.conf backup file and follow the previous suggestions, in particular make sure your system relies on a clean DNS management, then feel free to let us know whether the problem gets resolved.
Quote
That's fine and expected, it's a safety feature of Eddie. If you want to prevent Eddie from managing DNS you have to disable this check by unticking "Check Air VPN DNS" in "Preferences" > "DNS" window.
Hi, this is weird:
$ ls -l /etc/resolv.conf
lrwxrwxrwx 1 root root 39 22 janv. 20:03 /etc/resolv.conf -> ../run/systemd/resolve/stub-resolv.conf
It is indeed a link. So Eddie does not detect it correctly?
Tomorrow I will test on a fresh Archlinux install if I can reproduce the problem. But I am using a symlink, for sure.
