Walking_cat
ANSWERED Loss packet 100%, but connect with server is there, and IP is received.
Hello.
I encountered the following situation: my entire network accesses the Russian Internet through computer under FreeBSD + pfSense 2.8.1. An OpenVPN in pfSense is configured to connect to AirVPN server and block IPv6 traffic and allow only IPv4 traffic.
Until 07:37 on 01/01/2026 everything was working (sometimes the connection dropped, sometimes packet loss increased up to 20%, but it still worked). However, after that time (7:30, 01.01.2026) the connection was interrupted and packet loss reached 100%.
In all subsequent attempts, the situation did not change.
At the moment, nothing has changed (I tried different AirVPN servers in Latvia): the connection is established, but no traffic passes through (100% packet loss).
What could this be related to? (As you can understand, I did not change any settings, since at 7:37 AM on January 1st I was asleep 🙂)
Part of Gateways System Log in attachment.
Thank you.
System_Gateways_Log.txt
The standard IT crowd suggestion: Have you tried turning it off and on again?
