I am quite new, so Im ready to be roasted for my setup.
But the short story is that I have Tailscale installed on both my servers, and my private machine so I can configure and watch media while I am at work some times. The problem is that when I enable the Network lock feature, Tailscale shits itself and Im unable to connect from my private machine to my services. These services are running on example 8080, 9443, 5055 and so on.
But as RDP and SSH works fine with this, I found out that the server itself can use the tailscale ip (100.70.***) to connect to those services. So Im a bit lost here and looking for some advice.
My allow list is the following at the moment for both incoming and outgoing:
127.0.0.0/8
192.168.0.0/16
10.0.0.0/8
100.68.****/32
172.17.0.0/16
172.18.0.0/16
172.19.0.0/16
100.64.0.0/10
Thank you ! 😀
Edited ... by FireStar281
