pexu 0 Posted ... (edited) Hi to all! Those 2 boxes are Linux. On my Shield, Eddie for Android can't connect to Canadian server but connect easily to American. I include 2 logs because the messages are a bit different. TIA! I 2025.12.29 14:52:39 - Eddie version: 2.13.6 / linux_x64, System: Linux, Name: PCLinuxOS release 2026 (PCLinuxOS) for x86_64Kernel 5.10.45-pclos1 on an 8-processor x86_64 / \l, Version: Linux magritte.localdomain 5.10.45-pclos1 #1 SMP Fri Jun 18 05:28:17 CDT 2021 x86_64 GNU/Linux, Mono/.Net Framework: v4.0.30319 . 2025.12.29 14:52:39 - Reading options from /home/pierre/Eddie/AirVPN.xml . 2025.12.29 14:52:40 - Command line arguments (1): console.mode="none" I 2025.12.29 14:52:41 - OpenVPN Driver - Found, /dev/net/tun I 2025.12.29 14:52:41 - OpenVPN - Version: 2.4.3 - OpenSSL 1.0.2l 25 May 2017, LZO 2.10 (/home/pierre/Eddie/openvpn) I 2025.12.29 14:52:41 - SSH - Version: OpenSSH_9.8p1, OpenSSL 3.1.8 11 Feb 2025 (/usr/bin/ssh) I 2025.12.29 14:52:41 - SSL - Version: stunnel 5.40 (/home/pierre/Eddie/stunnel) I 2025.12.29 14:52:41 - curl - Version: 8.10.1 (/usr/bin/curl) I 2025.12.29 14:52:41 - Certification Authorities: /home/pierre/Eddie/cacert.pem . 2025.12.29 14:52:41 - Updating systems & servers data ... W 2025.12.29 14:52:41 - Special Christmas deal: save up to 68% W 2025.12.29 14:52:41 - send a gift to a friend or give yourself the gift of privacy ! 2025.12.29 14:52:41 - Ready . 2025.12.29 14:52:41 - Systems & servers data update completed I 2025.12.29 14:52:45 - Checking login ... ! 2025.12.29 14:52:45 - Logged in. I 2025.12.29 14:52:49 - Session starting. I 2025.12.29 14:52:49 - Checking authorization ... ! 2025.12.29 14:52:49 - Connecting to Kornephoros (Canada, Toronto, Ontario) . 2025.12.29 14:52:49 - OpenVPN > OpenVPN 2.4.3 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Aug 9 2017 . 2025.12.29 14:52:49 - OpenVPN > library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.10 . 2025.12.29 14:52:49 - Connection to OpenVPN Management Interface . 2025.12.29 14:52:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2025.12.29 14:52:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2025.12.29 14:52:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2025.12.29 14:52:49 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]198.44.157.11:443 . 2025.12.29 14:52:49 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984] . 2025.12.29 14:52:49 - OpenVPN > UDP link local: (not bound) . 2025.12.29 14:52:49 - OpenVPN > UDP link remote: [AF_INET]198.44.157.11:443 . 2025.12.29 14:52:49 - OpenVPN > TLS: Initial packet from [AF_INET]198.44.157.11:443, sid=8ffc4ccd 9a2c9e06 . 2025.12.29 14:52:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2025.12.29 14:52:49 - OpenVPN > VERIFY KU OK . 2025.12.29 14:52:49 - OpenVPN > Validating certificate extended key usage . 2025.12.29 14:52:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2025.12.29 14:52:49 - OpenVPN > VERIFY EKU OK . 2025.12.29 14:52:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Kornephoros, emailAddress=info@airvpn.org . 2025.12.29 14:52:50 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2025.12.29 14:52:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2025.12.29 14:52:50 - OpenVPN > [Kornephoros] Peer Connection Initiated with [AF_INET]198.44.157.11:443 ! 2025.12.29 14:52:51 - Disconnecting . 2025.12.29 14:52:51 - Connection terminated. I 2025.12.29 14:52:54 - Checking authorization ... ! 2025.12.29 14:52:54 - Connecting to Paikauhale (United States, New York City) . 2025.12.29 14:52:54 - OpenVPN > OpenVPN 2.4.3 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Aug 9 2017 . 2025.12.29 14:52:54 - OpenVPN > library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.10 . 2025.12.29 14:52:54 - Connection to OpenVPN Management Interface . 2025.12.29 14:52:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2025.12.29 14:52:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2025.12.29 14:52:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2025.12.29 14:52:54 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]198.44.136.251:443 . 2025.12.29 14:52:54 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984] . 2025.12.29 14:52:54 - OpenVPN > UDP link local: (not bound) . 2025.12.29 14:52:54 - OpenVPN > UDP link remote: [AF_INET]198.44.136.251:443 . 2025.12.29 14:52:54 - OpenVPN > TLS: Initial packet from [AF_INET]198.44.136.251:443, sid=f2f5462a 4c274693 . 2025.12.29 14:52:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2025.12.29 14:52:54 - OpenVPN > VERIFY KU OK . 2025.12.29 14:52:54 - OpenVPN > Validating certificate extended key usage . 2025.12.29 14:52:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2025.12.29 14:52:54 - OpenVPN > VERIFY EKU OK . 2025.12.29 14:52:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Paikauhale, emailAddress=info@airvpn.org . 2025.12.29 14:52:54 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2025.12.29 14:52:54 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2025.12.29 14:52:54 - OpenVPN > [Paikauhale] Peer Connection Initiated with [AF_INET]198.44.136.251:443 . 2025.12.29 14:52:55 - OpenVPN > SENT CONTROL [Paikauhale]: 'PUSH_REQUEST' (status=1) . 2025.12.29 14:52:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.71.0.1,dhcp-option DNS6 fde6:7a:7d20:4300::1,tun-ipv6,route-gateway 10.71.0.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4300::1006/64 fde6:7a:7d20:4300::1,ifconfig 10.71.0.8 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2025.12.29 14:52:55 - OpenVPN > Note: option tun-ipv6 is ignored because modern operating systems do not need special IPv6 tun handling anymore. . 2025.12.29 14:52:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2025.12.29 14:52:55 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2025.12.29 14:52:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2025.12.29 14:52:55 - OpenVPN > OPTIONS IMPORT: route options modified . 2025.12.29 14:52:55 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2025.12.29 14:52:55 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2025.12.29 14:52:55 - OpenVPN > OPTIONS IMPORT: peer-id set . 2025.12.29 14:52:55 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2025.12.29 14:52:55 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2025.12.29 14:52:55 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2025.12.29 14:52:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key . 2025.12.29 14:52:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key . 2025.12.29 14:52:55 - OpenVPN > ROUTE_GATEWAY 192.168.2.1/255.255.255.0 IFACE=wlan2 HWADDR=80:3f:5d:21:2e:a4 . 2025.12.29 14:52:55 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2025.12.29 14:52:55 - OpenVPN > GDG6: NLSMG_ERROR: error -101 . 2025.12.29 14:52:55 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2025.12.29 14:52:55 - OpenVPN > TUN/TAP device tun0 opened . 2025.12.29 14:52:55 - OpenVPN > TUN/TAP TX queue length set to 100 . 2025.12.29 14:52:55 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2025.12.29 14:52:55 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500 . 2025.12.29 14:52:55 - OpenVPN > /sbin/ip addr add dev tun0 10.71.0.8/24 broadcast 10.71.0.255 . 2025.12.29 14:52:55 - OpenVPN > /sbin/ip -6 addr add fde6:7a:7d20:4300::1006/64 dev tun0 . 2025.12.29 14:52:55 - OpenVPN > RTNETLINK answers: Permission denied . 2025.12.29 14:52:55 - OpenVPN > MANAGEMENT: Client disconnected . 2025.12.29 14:52:55 - OpenVPN > Linux ip -6 addr add failed: external program exited with error status: 2 . 2025.12.29 14:52:55 - OpenVPN > Exiting due to fatal error ! 2025.12.29 14:52:55 - Disconnecting . 2025.12.29 14:52:55 - Connection terminated. I 2025.12.29 14:52:58 - Checking authorization ... ! 2025.12.29 14:52:59 - Connecting to Muliphein (United States, New York City) . 2025.12.29 14:52:59 - OpenVPN > OpenVPN 2.4.3 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Aug 9 2017 . 2025.12.29 14:52:59 - OpenVPN > library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.10 . 2025.12.29 14:52:59 - Connection to OpenVPN Management Interface . 2025.12.29 14:52:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2025.12.29 14:52:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2025.12.29 14:52:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2025.12.29 14:52:59 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]198.44.136.235:443 . 2025.12.29 14:52:59 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984] . 2025.12.29 14:52:59 - OpenVPN > UDP link local: (not bound) . 2025.12.29 14:52:59 - OpenVPN > UDP link remote: [AF_INET]198.44.136.235:443 . 2025.12.29 14:52:59 - OpenVPN > TLS: Initial packet from [AF_INET]198.44.136.235:443, sid=3936b9c7 04622536 . 2025.12.29 14:52:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2025.12.29 14:52:59 - OpenVPN > VERIFY KU OK . 2025.12.29 14:52:59 - OpenVPN > Validating certificate extended key usage . 2025.12.29 14:52:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2025.12.29 14:52:59 - OpenVPN > VERIFY EKU OK . 2025.12.29 14:52:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Muliphein, emailAddress=info@airvpn.org . 2025.12.29 14:52:59 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2025.12.29 14:52:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2025.12.29 14:52:59 - OpenVPN > [Muliphein] Peer Connection Initiated with [AF_INET]198.44.136.235:443 ! 2025.12.29 14:53:00 - Disconnecting . 2025.12.29 14:53:00 - Sending management termination signal . 2025.12.29 14:53:00 - Management - Send 'signal SIGTERM' . 2025.12.29 14:53:00 - Connection terminated. I 2025.12.29 14:53:00 - Cancel requested. ! 2025.12.29 14:53:00 - Session terminated. Edited ... by pexu Quote Share this post Link to post
Tech Jedi Alex 1527 Posted ... On 12/29/2025 at 4:04 PM, pexu said: . 2025.12.29 14:52:55 - OpenVPN > Linux ip -6 addr add failed: external program exited with error status: 2 Enable IPv6 in the system, or:… Oh, wait, before even that: I 2025.12.29 14:52:39 - Eddie version: 2.13.6 / linux_x64, System: Linux, Name: PCLinuxOS release 2026 (PCLinuxOS) for x86_64Kernel 5.10.45-pclos1 on an 8-processor x86_64 / \l, Version: Linux magritte.localdomain 5.10.45-pclos1 #1 SMP Fri Jun 18 05:28:17 CDT 2021 x86_64 GNU/Linux, Mono/.Net Framework: v4.0.30319 . 2025.12.29 14:52:49 - OpenVPN > OpenVPN 2.4.3 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Aug 9 2017 . 2025.12.29 14:52:49 - OpenVPN > library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.10 Eddie 2.13.6? Kernel 5.10? OpenVPN 2.4.3 and OpenSSL 1.0.2l? Please do a system update immediately! You're running a 2017 Eddie, OpenVPN and OpenSSL version on a 2020 kernel! Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
pexu 0 Posted ... (edited) Activate IPv6 on the kernel have done the job. For the software, 10 years old boxes can't use later kernel. I plan to get new boxes in January and reinstall completely Linux. Many thanks and, happy new year! Edited ... by pexu Quote Share this post Link to post
