sophia1 0 Posted ... I have 3 linux machines and they are all exhibiting the same behavior at variable rates, where it's become harder and harder to find a server that works. They always connect but websites don't work. My last machine now doesn't work as of yesterday, and coincidentally right after the time the Triangulum server went down for maintenance and came back up yesterday. Configurations: 1) Fedora machine running hummingbird/goldcrest 2) Debian 13 Machine running hummingbird/goldcrest in linux lxc container running Debian 12 (another lxc container also runs Debian 13) 3) Debian 13 Machine running hummingbird/goldcrest in linux lxc container running Debian 13 * I connect all machines using Openvpn and by default they seem to pick UDP. Symptoms: - All 3 machines connect to all airvpn servers without any error or problems. They connect quickly and reliably always. - However, most websites don't work. - Smaller websites especially ones with only text work reliably but with delay. ifconfig.io or ipchicken.com works. lite.cnn.com (text version of cnn) works, but cnn.com has problems - Airvpn.org is the most sensitive website and is the least likely to work. It just hangs as if I typed in a non-existent website url. Observations: - In the end, these last several weeks, I had to try 20+ different servers and found that only the ones in latvia worked - But this past week or two, it seems latvia servers are starting to do the same thing. - I then switched to force goldcrest to use -p tcp which made things much better but yet sometimes quirky with not loading websites -The lxc containers all have very similar if not the same configurations -I was using the older version of the airvpn suite until recently but switched to the newest one lately on many machines. It seems unrelated as my last machine was working until yesterday connecting to Triangulum in Singapore and was using the old version from 2023. - The last machine was connecting with hummingbird and automatically choosing UDP and connecting to Triangulum. It has been working for several months this way. Yesterday, it stopped working right after that server went down and had maintainence. Now I can still connect but half the websites don't work. - As a result, I tried the -P tcp trick with hummingbird, and it works better now. But other servers other than Triangulum have random websites that don't load even with the -P tcp flag. - Eddie works fine for all my machines and configurations and connects to servers and works even when hummingbird doesn't. But I want to use hummingbird. GUI is hard to work with in a LXC container and the eddie-cli doesn't seem to have the flexibility that hummingbird has. - I noticéd that Eddie uses wireguard instead of openvpn. Maybe that is what is making it work better? - I don't mind using wireguard but I get this error when I set the wireguard flag in hummingbird/goldcrest and I don't know how to fix it: ERROR: system 'modules.builtin' does not exist. ERROR: cannot load wireguard system module Is there some kind of upgrade slowly rolling out over all the airvpn servers that is somehow making my configurations incompatible? It has been slowly getting harder and harder to find a server that works and I don't know why. Quote Share this post Link to post
Staff 10427 Posted ... 17 hours ago, sophia1 said: ERROR: system 'modules.builtin' does not exist. ERROR: cannot load wireguard system module Hello! Note: Suite versions older than 2.0.0 do not support WireGuard. Note: do not try to access Debian 13 kernel modules from a Debian 12 container. It's possible that the WireGuard kernel module is not properly loaded in your Debian 13 LXC container, even though Debian 13 host includes the module. LXC containers can be restricted from accessing kernel modules even if they're available on the host. Please make sure that the container has access to the network related kernel modules by checking your LXC configuration file. If this is not possible or anyway you want to avoid it, then you need to ensure that WireGuard's kernel module is available inside the container. WireGuard kernel module (wireguard.ko or wireguard.ko.xz) should be in the following directory: /lib/modules/$(uname -r)/kernel/drivers/net/wireguard If the problem persists, can you please send us the output of the commands: uname -a lsmod | grep wireguard ls /lib/modules/$(uname -r)/kernel/drivers/net/wireguard Kind regards Quote Share this post Link to post
sophia1 0 Posted ... 5 hours ago, Staff said: Hello! Note: Suite versions older than 2.0.0 do not support WireGuard. Note: do not try to access Debian 13 kernel modules from a Debian 12 container. It's possible that the WireGuard kernel module is not properly loaded in your Debian 13 LXC container, even though Debian 13 host includes the module. LXC containers can be restricted from accessing kernel modules even if they're available on the host. Please make sure that the container has access to the network related kernel modules by checking your LXC configuration file. If this is not possible or anyway you want to avoid it, then you need to ensure that WireGuard's kernel module is available inside the container. WireGuard kernel module (wireguard.ko or wireguard.ko.xz) should be in the following directory: /lib/modules/$(uname -r)/kernel/drivers/net/wireguard If the problem persists, can you please send us the output of the commands: uname -a lsmod | grep wireguard ls /lib/modules/$(uname -r)/kernel/drivers/net/wireguard On Machine1: Linux lap1 6.12.25-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.25-1 (2025-04-25) x86_64 GNU/Linux wireguard 118784 0 libchacha20poly1305 16384 1 wireguard curve25519_x86_64 36864 1 wireguard libcurve25519_generic 45056 2 curve25519_x86_64,wireguard ip6_udp_tunnel 16384 1 wireguard udp_tunnel 32768 1 wireguard .rw-r--r-- 50,232 root 04-26 00:07 wireguard.ko.xz -------------------------------------------------------------- On Machine2: Linux pc3 6.12.38+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.38-1 (2025-07-16) x86_64 GNU/Linux -rw-r--r-- 1 root root 49K Jul 16 16:13 wireguard.ko.xz And surprisingly on machine2 lsmod | grep wireguard produces no output? I'm surprised because I tend to configure my machines in pretty much the same way, so I don't know why one machine has wireguard and the other doesn't. -------------------------------------------------------------- My LXC skills aren't as good as linux in general. When you say "Please make sure that the container has access to the network related kernel modules by checking your LXC configuration file", what do I have to put in the lxc config file to make sure the container has access to the network related kernel modules? In the case of Machine2, do I have to apt install something to get wireguard kernel modules working? I assume machine1 shows that wireguard kernel modules are available because lsmod outputted something. Also, do you have any insight as to why the number of servers that work for me using hummingbird has been slowly dwindling over the course of several months and not with Eddie? Like have you been upgrading openssl over this time or something like that? Quote Share this post Link to post
Staff 10427 Posted ... 10 hours ago, sophia1 said: When you say "Please make sure that the container has access to the network related kernel modules by checking your LXC configuration file", what do I have to put in the lxc config file to make sure the container has access to the network related kernel modules? Hello! You should modify several settings (add the mentioned host directory as an allowed mount entry point, disable apparmor limitations to load kernel modules, allow read access by the container to the proper modules) that can pose a security problem. You can find everything you need on the documentation but in your case consider to build the WireGuard kernel module locally, inside the container, if you wish to maintain strict isolation and complete compatibility. 10 hours ago, sophia1 said: do you have any insight as to why the number of servers that work for me using hummingbird has been slowly dwindling over the course of several months and not with Eddie? Like have you been upgrading openssl over this time or something like that? Upgrading servers is a constant process but configuration files have not changed in the last months. Please consider that now OpenVPN pushes IPv6 routes and configuration no matter what. The source of the problem could be that IPv6 is disabled in the container and if so you should enable it or filter out anything related to IPv6 coming from the OpenVPN server. To do so, please see here: https://airvpn.org/forums/topic/26548-linux-ip-6-addr-add-failed/?do=findComment&comment=72069 If the problem persists, allow us to examine the Hummingbird log taken after a connection attempt with OpenVPN has failed. Kind regards Quote Share this post Link to post
