noonereturnsthesame 0 Posted ... Hi! I bought the year version of air vpn, so I'm really hoping someone can help me get it set up. I have a macbook air m2 2022, and I downloaded Eddie, logged in and I can't connect to anything. I'm gonna include the log so hopefully i cant get some help. I have since completely uninstalled Proton VPN, and removed it from my vpn profile under settings. Which Air vpn isnt showing up at all so I feel like thats part of the problem . Thanks in advance! Eddie_20251226_130123.txt Quote Share this post Link to post
Staff 10466 Posted ... @noonereturnsthesame Hello! A possible problem we can infer from the piece of log you kindly published is a conflict with Proton. Since we see that a Proton interface is up, it's possible that you're trying (even unintentionally) to use both AirVPN and ProtonVPN at the same time. This is possible but only with special configuration (multiple routing tables and virtual interfaces, or more trivially with virtualization) and in general it will cause conflicts. Can you please make sure that, when you are going to use AirVPN, ProtonVPN related programs and services have been already stopped? If you ascertain the above and the problem persists, please generate and send a full system report, please see here to do it: https://airvpn.org/forums/topic/50663-youve-been-asked-for-a-support-filesystem-report-–-heres-what-to-do/ Kind regards Quote Share this post Link to post
