Not connected, Your IP: 216.73.216.161
ralleyquattro
[SOLVED] Already connected, failed to start
This was using Air VPN. I also tried to do the Open VPN and got this
Tue Feb 19 17:08:50 2013 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
Tue Feb 19 17:08:50 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Tue Feb 19 17:08:50 2013 LZO compression initialized
Tue Feb 19 17:08:50 2013 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
Tue Feb 19 17:08:50 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Tue Feb 19 17:08:50 2013 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Tue Feb 19 17:08:50 2013 Local Options hash (VER=V4): '22188c5b'
Tue Feb 19 17:08:50 2013 Expected Remote Options hash (VER=V4): 'a8f55717'
Tue Feb 19 17:08:50 2013 UDPv4 link local: [undef]
Tue Feb 19 17:08:50 2013 UDPv4 link remote: 85.17.123.26:443
Tue Feb 19 17:08:50 2013 TLS: Initial packet from 85.17.123.26:443, sid=09f185bc 38034892
Tue Feb 19 17:08:51 2013 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
Tue Feb 19 17:08:51 2013 VERIFY OK: nsCertType=SERVER
Tue Feb 19 17:08:51 2013 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
Tue Feb 19 17:08:53 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Tue Feb 19 17:08:53 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Feb 19 17:08:53 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Tue Feb 19 17:08:53 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Feb 19 17:08:53 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Tue Feb 19 17:08:53 2013 [server] Peer Connection Initiated with 85.17.123.26:443
Tue Feb 19 17:08:55 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Tue Feb 19 17:08:56 2013 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.35.34 10.4.35.33'
Tue Feb 19 17:08:56 2013 OPTIONS IMPORT: timers and/or timeouts modified
Tue Feb 19 17:08:56 2013 OPTIONS IMPORT: LZO parms modified
Tue Feb 19 17:08:56 2013 OPTIONS IMPORT: --ifconfig/up options modified
Tue Feb 19 17:08:56 2013 OPTIONS IMPORT: route options modified
Tue Feb 19 17:08:56 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Tue Feb 19 17:08:56 2013 ROUTE default_gateway=192.168.1.1
Tue Feb 19 17:08:56 2013 There are no TAP-Win32 adapters on this system. You should be able to create a TAP-Win32 adapter by going to Start -> All Programs -> OpenVPN -> Add a new TAP-Win32 virtual ethernet adapter.
Tue Feb 19 17:08:56 2013 Exiting
I do not see option to add a new TAP-Win32 virtual ethernet adapter, I don't even know what it is...
Please help!
The problem is here:
I do not see option to add a new TAP-Win32 virtual ethernet adapter, I don't even know what it is... :(
Please help!
The TAP-Win32 adapter is the network interface used by OpenVPN. Please follow the instructions provided in the logs and make sure to launch the TAP adder script with administrator privileges.
If the above does not solve the problem, please uninstall completely OpenVPN and re-install it, making sure to authorize the installer to install all the drivers.
I'm having the same problem with the Air VPN on my computer. When I login and try to connect to a server I get "failed to start" after it tries to connect. On my laptop I got it to work by using the 32 bit one instead of the 64 bit. But I've tried both on my computer and I can't get it to work. I have NO clue how to use the Open VPN. Everytime I try it it says: "Not a vaid win32 application". Then after I did that the Air VPN also said: "Not a valid win32 application." WTF? So I uninstalled and reinstalled it and I'm still getting that message. I know nothing about this stuff and everytime I read posts on here I think will help me I get really confused. Honestly I don't even want to bother with the Open VPN, I really don't understand it at all. I just want to be able to login and connect like I can on my laptop using the Air VPN.
Can you please send us the client logs just after you get that error?
In the Air client logs are accessible by right-clicking on the Air dock icon and selecting "Logs". Click on "Copy to clipboard" and paste where appropriate.
Sorry nevermind I got it to work. I forgot I didn't try uninstalling and reinstalling the 32 bit only the 64 bit.
