HUHHII
Review of AirVPN after a year of use
After a year of using AirVPN I'm very happy with the product. Website has no bloat whatsoever and it's super easy to find what you are looking for. A huge plus goes out for having an active forum available! Much better option compared to social media idiocies. Also port forwarding has been executed greatly - many other VPN services miss that altogether but even those which support it can't match AirVPN's easy-to-use robust system. Config generator is a great plus too since I'm using both WireGuard app and WireSock depending on the situation and needs. Both run just fine and very few VPN's could match this level of usability.
I sometimes have dissapointing speeds with P2P, but usually a simple server change fixes it.
Overall very happy customer. Please have a beer AirVPN staff, you've deserved it!
Same here, over 6 months of use now and it has been the best VPN service i have used (and i have used many) i will certainly be renewing my subscription before my year is up.
