noroku64
Qbittorrent/Gluetun not working
I need some help. I can't get Qbittorrent to download when set behind Gluetun. When I put the qbittorrent into bridge mode it can download torrents just fine. When I put Qbittorrent into the gluetun container it does nothing.
1. I have setup Port Forwarding in Airvpn client area
2. In Qbittorrent I have added that port to the listening port configuration.
3. In Qbittorrent I have the network interface to Tun0
4. I have removed all ports in Qbittorrent
5. I have set the Qbittorrent Network to go through container Gluetun
6. I setup port 8080, and the forwarded port onto Gluetun
7. FIREWALL_VPN_INPUT_PORTS is set to that port under Gluetun
8. TORRENTING_PORT is set in Qbittorrent to the forwarded port
9. I have verified that the qbittorrent container is going through the VPN using CLI command: curl ifconfig.io
10. on Client area under forwared port when I do a test. It times out.
11. When I add a torrent to Qbittorrent it doesn't do anything.
12. When I move Qbittorent back to bridge mode with the ports 8080 and same port it downloads
What am I doing wrong here? I'm using wireguard config file instead of OPENVPN. I haven't tried OPENVPN but everything I have seen and read said to go with wireguard configuration.
Please help. I've been at this for 2 weeks looking up youtube videos, forums and such and nothing seems to work.
services:
  gluetun:
    cap_add:
      - NET_ADMIN
    deploy:
      resources:
        limits:
          cpus: '1'
          memory: 512m
    environment:
      - VPN_SERVICE_PROVIDER=airvpn
      - VPN_TYPE=wireguard
      - WIREGUARD_PRIVATE_KEY=...
      - WIREGUARD_PRESHARED_KEY=...
      - WIREGUARD_PUBLIC_KEY=...
      - SERVER_COUNTRIES=Netherlands
      - WIREGUARD_ADDRESSES=...
      - WIREGUARD_MTU=1320
      - FIREWALL_OUTBOUND_SUBNETS= # Optional, access to local subnet. Adjust to your network
      - FIREWALL_VPN_INPUT_PORTS=51820
    image: qmcgaw/gluetun:latest
    ports:
      - '38080:38080' # qBittorrent WebUI
      - '39696:9696' # Prowlarr WebUI
      - '30014:8686' # Lidarr WebUI
      - '30027:8989' # Sonarr WebUI
      - '30025:7878' # Radarr WebUI
      - '30055:30055' # Sabnzbd WebUI
    restart: unless-stopped
    volumes:
      - /mnt/apps/appdata/warez/gluetun:/gluetun
  qbittorrent:
    container_name: qbittorrent
    depends_on:
      gluetun:
        condition: service_healthy
    deploy:
      resources:
        limits:
          cpus: '1'
          memory: 1g
    environment:
      - PUID=568
      - PGID=568
      - TZ=Europe/London
      - WEBUI_PORT=38080
      - TORRENTING_PORT=54811
    image: lscr.io/linuxserver/qbittorrent:latest
    network_mode: service:gluetun
    volumes:
      - /mnt/apps/appdata/warez/qbittorrent:/config
      - /mnt/zfspool/downloads/torrents:/downloads/torrents/
I'm attaching a snippet from my docker compose yaml which works every time, even when the tunnel reconnects.
I hope it will you some troubleshooting ideas.
