Nasheayahu 3 Posted ... I have no session running on my systems and I keep getting active session automatically appearing in the Client Area, that is running up my allowed connection. What goes on and I get a tech to view thus immediately please? I have turned off all my systems with Eddie except this one I'm using to post. I used the appimage version to initiate eddie. Thanks!... P.S. How can I manual block eddie from connecting using this site until this is fixed? I already changed my password. Share this post Link to post
Staff 10489 Posted ... 8 hours ago, Nasheayahu said: I have no session running on my systems and I keep getting active session automatically appearing in the Client Area, that is running up my allowed connection. Hello! Please make sure that Eddie is not configured to connect automatically at startup on "Preferences" > "General" window. If the problem persists and you do not recognize the session(s) it is necessary to keep into consideration a possible unauthorized use of your account. Please change your AirVPN user password (pick a strong password you do not use anywhere else) and renew your keys to cut out any potential fraudulent user, please see here: https://airvpn.org/forums/topic/26209-how-to-manage-client-certificatekey-pairs/ Kind regards Share this post Link to post
Nasheayahu 3 Posted ... 7 hours ago, Staff said: Please change your AirVPN user password (pick a strong password you do not use anywhere else) Changed it three (3) times (40 length pass phrase) using a length and the same connection locations appear right after I disconnect them via client area. Eddie is not running on any of my systems nor in background process. I use Proton Pass to keep and generate my passwords. I just changed my Proton Account password (to 30 length) added Two-factor authentication using Microsoft Authenticator app. Everything changed and instantly the connections reappear. What goes on? 7 hours ago, Staff said: renew your keys to cut out any potential fraudulent user Don't have this, but will added it as well. P.S. Can I just (1) delete this account, (2) transfer remaining time to a new account? UPDATE: I just deleted my "Your VPN devices" and so far the connections has not reappeared. So how did this happen, that my "VPN device" (same since 2022) was "hijacked" or "kept in session" like this and Is this where I need to "renew" often? Share this post Link to post
Nasheayahu 3 Posted ... FINAL UPDATE: I just woke up and after doing a system check, which includes my pfSense "Service Status"; I found the three (3) repeated connections. 🤕 It was my uncompleted "pfSense baseline guide with VPN, Guest and VLAN support" project. Being so busy with my other projects, I forgot about this one. 😂😵 Thanks AirVPN Team. 😊 Share this post Link to post
