adriankoooo 0 Posted ... Is there any way to auto reconnect to VPN after drop connection? Unfortunatelly airvpn doesn´t seem 100% stable. Quote Share this post Link to post
adriankoooo 0 Posted ... My log is full of these messages: NL Castor - UDP 443 nm-openvpn[3502]: [server] Inactivity timeout (--ping-restart), restarting Feb 16 14:56:59 SIGUSR1[soft,ping-restart] received, process restarting Feb 16 14:57:01 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info. Feb 16 14:57:01 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Feb 16 14:57:01 Re-using SSL/TLS context Feb 16 14:57:01 LZO compression initialized Feb 16 14:57:01 UDPv4 link local: [undef] Feb 16 14:57:01 UDPv4 link remote: [AF_INET]95.211.x.x:443 Feb 16 14:58:01 [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 16 14:58:01 SIGUSR1[soft,ping-restart] received, process restarting Feb 16 14:58:03 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info. Feb 16 14:58:03 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Feb 16 14:58:03 Re-using SSL/TLS context Feb 16 14:58:03 LZO compression initialized Feb 16 14:58:03 UDPv4 link local: [undef] Feb 16 14:58:03 UDPv4 link remote: [AF_INET]95.211.x.x:443 Feb 16 14:59:03 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Feb 16 14:59:03 TLS Error: TLS handshake failed Feb 16 14:59:03 SIGUSR1[soft,tls-error] received, process restarting Feb 16 14:59:05 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info. Feb 16 14:59:05 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Feb 16 14:59:05 Re-using SSL/TLS context Feb 16 14:59:05 LZO compression initialized Feb 16 14:59:05 UDPv4 link local: [undef] Feb 16 14:59:05 UDPv4 link remote: [AF_INET]95.211.x.x:443 Feb 16 15:00:05 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Feb 16 15:00:05 TLS Error: TLS handshake failed Feb 16 15:00:05 SIGUSR1[soft,tls-error] received, process restarting Feb 16 15:00:07 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info. Feb 16 15:00:07 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Feb 16 15:00:07 Re-using SSL/TLS context Feb 16 15:00:07 LZO compression initialized Feb 16 15:00:07 UDPv4 link local: [undef] Feb 16 15:00:07 UDPv4 link remote: [AF_INET]95.211.x.x:443 Feb 16 15:01:07 [uNDEF] Inactivity timeout (--ping-restart), restarting Quote Share this post Link to post
Staff 10298 Posted ... Hello! Apparently there's a communication problem between your system and the server you're trying to connect to (unfortunately you deleted the IP address so we don't know whether you're pointing to the correct address). Can you please check that your firewall or any other program is blocking OpenVPN and/or UDP packets to outbound port 443? Do you get those logs with every server on port 443 UDP you try to connect to? Have you tested different ports? What is your OS and which client are you using? If it's network-manager, please make sure that you generate (in our configuration generator) .ovpn configuration files NOT embedded with certificates and key, because unfortunately network-manager does not support them. Kind regards Quote Share this post Link to post
adriankoooo 0 Posted ... "Apparently there's a communication problem between your system and the server you're trying to connect to (unfortunately you deleted the IP address so we don't know whether you're pointing to the correct address). Can you please check that your firewall or any other program is blocking OpenVPN and/or UDP packets to outbound port 443?" The server is not behind a firewall. If there was a firewall that blocks 443 port I think I could not connect at all. I am able to connect, but sometimes the connection is lost (2-3/day). "Do you get those logs with every server on port 443 UDP you try to connect to? Have you tested different ports? What is your OS and which client are you using? If it's network-manager, please make sure that you generate (in our configuration generator) .ovpn configuration files NOT embedded with certificates and key, because unfortunately network-manager does not support them." I tried only this server, no other port. I think all server has same configuration, I don't see much sense to try different servers. Ubuntu 12.10, network manager, .ovpn generated with your generator, got certificates. The problem is not that, that I cannot connect, but the connection is dropped a few times per day. I am thinking in a script which scan connection, and If there no VPN connection, immediately reconnects VPN connection. But no dropped connection would be the best. Best Regards Quote Share this post Link to post
Staff 10298 Posted ... Hello!The reason of the disconnection is that there's no communication between your system and Castor. Maybe it happens 2-3 times a day.See here:Feb 16 14:59:05 UDPv4 link remote: [AF_INET]95.211.x.x:443Feb 16 15:00:05 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)and here:Feb 16 14:58:01 [uNDEF] Inactivity timeout (--ping-restart), restartingOur configuration files already order OpenVPN to retry connection. network-manager ignores also "explicit-exit-notify" directive (so even when the client disconnects "cleanly" our servers do not get notified of it by the client).Can you please try a connection directly with OpenVPN to make a comparison test?Kind regards Quote Share this post Link to post
adriankoooo 0 Posted ... Thank you very much, I try to run openvpn as service mode and I write the result here. I moved all my files to /etc/openvpn/ and renamed .ovpn to .ovpnf.conf. I hope this is the right way to run OpenVPN directly. Quote Share this post Link to post
adriankoooo 0 Posted ... Seems to be stable. I had one disconnect today at 14:45. I checked Your Details in member area and there was a big yellow warning: disconnectet REASON: SERVER DOWN. Here is my log, disconnect was around 14:40: Feb 18 08:22:22 ovpn-air.ovpn[1145]: TLS: soft reset sec=0 bytes=21472801/0 pkts=23559/0 Feb 18 08:22:22 ovpn-air.ovpn[1145]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Feb 18 08:22:22 ovpn-air.ovpn[1145]: VERIFY OK: nsCertType=SERVER Feb 18 08:22:22 ovpn-air.ovpn[1145]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Feb 18 08:22:22 ovpn-air.ovpn[1145]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 08:22:22 ovpn-air.ovpn[1145]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 08:22:22 ovpn-air.ovpn[1145]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 08:22:22 ovpn-air.ovpn[1145]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 08:22:22 ovpn-air.ovpn[1145]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Feb 18 09:22:22 ovpn-air.ovpn[1145]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Feb 18 09:22:22 ovpn-air.ovpn[1145]: VERIFY OK: nsCertType=SERVER Feb 18 09:22:22 ovpn-air.ovpn[1145]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Feb 18 09:22:22 ovpn-air.ovpn[1145]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 09:22:22 ovpn-air.ovpn[1145]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 09:22:22 ovpn-air.ovpn[1145]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 09:22:22 ovpn-air.ovpn[1145]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 09:22:22 ovpn-air.ovpn[1145]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Feb 18 10:22:22 ovpn-air.ovpn[1145]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Feb 18 10:22:22 ovpn-air.ovpn[1145]: VERIFY OK: nsCertType=SERVER Feb 18 10:22:22 ovpn-air.ovpn[1145]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Feb 18 10:22:22 ovpn-air.ovpn[1145]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 10:22:22 ovpn-air.ovpn[1145]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 10:22:22 ovpn-air.ovpn[1145]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 10:22:22 ovpn-air.ovpn[1145]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 10:22:22 ovpn-air.ovpn[1145]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Feb 18 11:22:22 ovpn-air.ovpn[1145]: TLS: soft reset sec=0 bytes=638083/0 pkts=4191/0 Feb 18 11:22:23 ovpn-air.ovpn[1145]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Feb 18 11:22:23 ovpn-air.ovpn[1145]: VERIFY OK: nsCertType=SERVER Feb 18 11:22:23 ovpn-air.ovpn[1145]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Feb 18 11:22:23 ovpn-air.ovpn[1145]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 11:22:23 ovpn-air.ovpn[1145]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 11:22:23 ovpn-air.ovpn[1145]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 11:22:23 ovpn-air.ovpn[1145]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 11:22:23 ovpn-air.ovpn[1145]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Feb 18 12:22:22 ovpn-air.ovpn[1145]: TLS: tls_process: killed expiring key Feb 18 12:22:23 ovpn-air.ovpn[1145]: TLS: soft reset sec=0 bytes=660390/0 pkts=4235/0 Feb 18 12:22:23 ovpn-air.ovpn[1145]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Feb 18 12:22:23 ovpn-air.ovpn[1145]: VERIFY OK: nsCertType=SERVER Feb 18 12:22:23 ovpn-air.ovpn[1145]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Feb 18 12:22:24 ovpn-air.ovpn[1145]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 12:22:24 ovpn-air.ovpn[1145]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 12:22:24 ovpn-air.ovpn[1145]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 12:22:24 ovpn-air.ovpn[1145]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 12:22:24 ovpn-air.ovpn[1145]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Feb 18 13:22:23 ovpn-air.ovpn[1145]: TLS: tls_process: killed expiring key Feb 18 13:22:24 ovpn-air.ovpn[1145]: TLS: soft reset sec=0 bytes=589191/0 pkts=4008/0 Feb 18 13:22:24 ovpn-air.ovpn[1145]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Feb 18 13:22:24 ovpn-air.ovpn[1145]: VERIFY OK: nsCertType=SERVER Feb 18 13:22:24 ovpn-air.ovpn[1145]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Feb 18 13:22:24 ovpn-air.ovpn[1145]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 13:22:24 ovpn-air.ovpn[1145]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 13:22:24 ovpn-air.ovpn[1145]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 13:22:24 ovpn-air.ovpn[1145]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 13:22:24 ovpn-air.ovpn[1145]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Feb 18 13:27:50 ovpn-air.ovpn[1145]: [server] Inactivity timeout (--ping-restart), restarting Feb 18 13:27:50 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 13:27:50 ovpn-air.ovpn[1145]: /sbin/route del -net 10.4.0.1 netmask 255.255.255.255 Feb 18 13:27:50 ovpn-air.ovpn[1145]: /sbin/route del -net 95.211.169.3 netmask 255.255.255.255 Feb 18 13:27:50 ovpn-air.ovpn[1145]: /sbin/route del -net 0.0.0.0 netmask 128.0.0.0 Feb 18 13:27:50 ovpn-air.ovpn[1145]: /sbin/route del -net 128.0.0.0 netmask 128.0.0.0 Feb 18 13:27:50 ovpn-air.ovpn[1145]: Closing TUN/TAP interface Feb 18 13:27:50 ovpn-air.ovpn[1145]: /sbin/ifconfig tun0 0.0.0.0 Feb 18 13:27:52 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 13:27:52 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 13:27:54 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 13:27:54 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 13:27:54 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 13:27:54 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 13:27:54 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 13:27:54 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 13:27:54 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 13:27:54 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 13:27:54 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 13:28:55 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 13:28:55 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 13:28:55 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 13:28:55 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 13:28:57 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 13:28:57 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 13:28:57 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 13:28:57 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 13:28:57 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 13:28:57 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 13:28:57 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 13:28:57 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 13:28:57 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 13:29:34 ovpn-air.ovpn[1145]: TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=27f48abb d640c550 Feb 18 13:29:57 ovpn-air.ovpn[1145]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Feb 18 13:29:57 ovpn-air.ovpn[1145]: TLS Error: TLS handshake failed Feb 18 13:29:57 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 13:29:57 ovpn-air.ovpn[1145]: SIGUSR1[soft,tls-error] received, process restarting Feb 18 13:29:57 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 13:29:59 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 13:29:59 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 13:29:59 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 13:29:59 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 13:29:59 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 13:29:59 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 13:29:59 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 13:29:59 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 13:29:59 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 13:30:01 ovpn-air.ovpn[1145]: TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=1226ccbc 61cd7e24 Feb 18 13:30:59 ovpn-air.ovpn[1145]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Feb 18 13:30:59 ovpn-air.ovpn[1145]: TLS Error: TLS handshake failed Feb 18 13:30:59 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 13:30:59 ovpn-air.ovpn[1145]: SIGUSR1[soft,tls-error] received, process restarting Feb 18 13:30:59 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 13:31:01 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 13:31:01 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 13:31:01 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 13:31:01 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 13:31:01 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 13:31:01 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 13:31:01 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 13:31:01 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 13:31:01 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 13:31:19 ovpn-air.ovpn[1145]: TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=e0ad99e6 abc43f4e Feb 18 13:32:02 ovpn-air.ovpn[1145]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Feb 18 13:32:02 ovpn-air.ovpn[1145]: TLS Error: TLS handshake failed Feb 18 13:32:02 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 13:32:02 ovpn-air.ovpn[1145]: SIGUSR1[soft,tls-error] received, process restarting Feb 18 13:32:02 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 13:32:04 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 13:32:04 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 13:32:04 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 13:32:04 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 13:32:04 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 13:32:04 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 13:32:04 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 13:32:04 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 13:32:04 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 13:33:04 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 13:33:04 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 13:33:04 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 13:33:04 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 13:33:06 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 13:33:06 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 13:33:06 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 13:33:06 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 13:33:06 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 13:33:06 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 13:33:06 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 13:33:06 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 13:33:06 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 13:33:15 ovpn-air.ovpn[1145]: TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=67f08599 17c9e233 Feb 18 13:33:17 ovpn-air.ovpn[1145]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Feb 18 13:33:17 ovpn-air.ovpn[1145]: VERIFY OK: nsCertType=SERVER Feb 18 13:33:17 ovpn-air.ovpn[1145]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Feb 18 13:33:18 ovpn-air.ovpn[1145]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 13:33:18 ovpn-air.ovpn[1145]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 13:33:18 ovpn-air.ovpn[1145]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 13:33:18 ovpn-air.ovpn[1145]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 13:33:18 ovpn-air.ovpn[1145]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Feb 18 13:33:18 ovpn-air.ovpn[1145]: [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443 Feb 18 13:33:21 ovpn-air.ovpn[1145]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Feb 18 13:33:22 ovpn-air.ovpn[1145]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.48.14 10.4.48.13' Feb 18 13:33:22 ovpn-air.ovpn[1145]: OPTIONS IMPORT: timers and/or timeouts modified Feb 18 13:33:22 ovpn-air.ovpn[1145]: OPTIONS IMPORT: LZO parms modified Feb 18 13:33:22 ovpn-air.ovpn[1145]: OPTIONS IMPORT: --ifconfig/up options modified Feb 18 13:33:22 ovpn-air.ovpn[1145]: OPTIONS IMPORT: route options modified Feb 18 13:33:22 ovpn-air.ovpn[1145]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Feb 18 13:33:22 ovpn-air.ovpn[1145]: ROUTE default_gateway=193.1.1.17 Feb 18 13:33:22 ovpn-air.ovpn[1145]: TUN/TAP device tun0 opened Feb 18 13:33:22 ovpn-air.ovpn[1145]: TUN/TAP TX queue length set to 100 Feb 18 13:33:22 ovpn-air.ovpn[1145]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 Feb 18 13:33:22 ovpn-air.ovpn[1145]: /sbin/ifconfig tun0 10.4.48.14 pointopoint 10.4.48.13 mtu 1500 Feb 18 13:33:22 ovpn-air.ovpn[1145]: /sbin/route add -net 95.211.169.3 netmask 255.255.255.255 gw 193.1.1.17 Feb 18 13:33:22 ovpn-air.ovpn[1145]: /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.48.13 Feb 18 13:33:22 ovpn-air.ovpn[1145]: /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.48.13 Feb 18 13:33:22 ovpn-air.ovpn[1145]: /sbin/route add -net 10.4.0.1 netmask 255.255.255.255 gw 10.4.48.13 Feb 18 13:33:22 ovpn-air.ovpn[1145]: Initialization Sequence Completed Feb 18 14:31:47 ovpn-air.ovpn[1145]: [server] Inactivity timeout (--ping-restart), restarting Feb 18 14:31:47 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:31:47 ovpn-air.ovpn[1145]: /sbin/route del -net 10.4.0.1 netmask 255.255.255.255 Feb 18 14:31:47 ovpn-air.ovpn[1145]: /sbin/route del -net 95.211.169.3 netmask 255.255.255.255 Feb 18 14:31:47 ovpn-air.ovpn[1145]: /sbin/route del -net 0.0.0.0 netmask 128.0.0.0 Feb 18 14:31:47 ovpn-air.ovpn[1145]: /sbin/route del -net 128.0.0.0 netmask 128.0.0.0 Feb 18 14:31:47 ovpn-air.ovpn[1145]: Closing TUN/TAP interface Feb 18 14:31:47 ovpn-air.ovpn[1145]: /sbin/ifconfig tun0 0.0.0.0 Feb 18 14:31:47 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:31:47 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:31:49 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:31:49 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:31:49 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:31:49 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:31:49 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:31:49 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:31:49 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:31:49 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:31:49 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:32:49 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:32:49 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:32:49 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:32:49 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:32:51 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:32:51 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:32:51 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:32:51 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:32:51 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:32:51 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:32:51 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:32:51 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:32:51 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:33:51 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:33:51 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:33:51 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:33:51 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:33:53 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:33:53 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:33:53 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:33:53 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:33:53 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:33:53 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:33:53 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:33:53 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:33:53 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:34:53 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:34:53 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:34:53 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:34:53 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:34:55 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:34:55 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:34:55 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:34:55 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:34:55 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:34:55 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:34:55 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:34:55 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:34:55 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:35:55 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:35:55 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:35:55 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:35:55 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:35:57 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:35:57 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:35:57 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:35:57 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:35:57 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:35:57 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:35:57 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:35:57 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:35:57 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:36:57 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:36:57 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:36:57 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:36:57 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:36:59 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:36:59 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:36:59 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:36:59 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:36:59 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:36:59 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:36:59 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:36:59 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:36:59 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:38:00 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:38:00 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:38:00 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:38:00 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:38:02 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:38:02 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:38:02 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:38:02 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:38:02 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:38:02 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:38:02 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:38:02 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:38:02 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:39:02 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:39:02 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:39:02 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:39:02 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:39:04 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:39:04 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:39:04 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:39:04 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:39:04 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:39:04 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:39:04 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:39:04 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:39:04 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:40:04 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:40:04 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:40:04 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:40:04 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:40:06 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:40:06 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:40:06 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:40:06 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:40:06 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:40:06 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:40:06 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:40:06 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:40:06 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:41:06 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:41:06 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:41:06 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:41:06 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:41:08 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:41:08 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:41:08 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:41:08 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:41:08 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:41:08 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:41:08 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:41:08 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:41:08 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:42:08 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:42:08 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:42:08 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:42:08 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:42:10 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:42:10 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:42:10 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:42:10 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:42:10 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:42:10 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:42:10 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:42:10 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:42:10 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:43:10 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:43:10 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:43:10 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:43:10 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:43:12 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:43:12 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:43:12 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:43:12 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:43:12 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:43:12 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:43:12 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:43:12 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:43:12 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:44:12 ovpn-air.ovpn[1145]: [uNDEF] Inactivity timeout (--ping-restart), restarting Feb 18 14:44:12 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:44:12 ovpn-air.ovpn[1145]: SIGUSR1[soft,ping-restart] received, process restarting Feb 18 14:44:12 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:44:14 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:44:14 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:44:14 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:44:14 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:44:14 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:44:14 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:44:14 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:44:14 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:44:14 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:45:02 ovpn-air.ovpn[1145]: TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=4bcb61f3 5b029814 Feb 18 14:45:14 ovpn-air.ovpn[1145]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Feb 18 14:45:14 ovpn-air.ovpn[1145]: TLS Error: TLS handshake failed Feb 18 14:45:14 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:45:14 ovpn-air.ovpn[1145]: SIGUSR1[soft,tls-error] received, process restarting Feb 18 14:45:14 ovpn-air.ovpn[1145]: Restart pause, 2 second(s) Feb 18 14:45:16 ovpn-air.ovpn[1145]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 14:45:16 ovpn-air.ovpn[1145]: LZO compression initialized Feb 18 14:45:16 ovpn-air.ovpn[1145]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 14:45:16 ovpn-air.ovpn[1145]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 14:45:16 ovpn-air.ovpn[1145]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 14:45:16 ovpn-air.ovpn[1145]: Local Options hash (VER=V4): '22188c5b' Feb 18 14:45:16 ovpn-air.ovpn[1145]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 14:45:16 ovpn-air.ovpn[1145]: UDPv4 link local: [undef] Feb 18 14:45:16 ovpn-air.ovpn[1145]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 14:45:45 ovpn-air.ovpn[1145]: TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=b6b70e2c db241aba Feb 18 14:45:46 ovpn-air.ovpn[1145]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Feb 18 14:45:46 ovpn-air.ovpn[1145]: VERIFY OK: nsCertType=SERVER Feb 18 14:45:46 ovpn-air.ovpn[1145]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Feb 18 14:45:53 ovpn-air.ovpn[1145]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 14:45:53 ovpn-air.ovpn[1145]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 14:45:53 ovpn-air.ovpn[1145]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 14:45:53 ovpn-air.ovpn[1145]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 14:45:53 ovpn-air.ovpn[1145]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Feb 18 14:45:53 ovpn-air.ovpn[1145]: [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443 Feb 18 14:45:55 ovpn-air.ovpn[1145]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Feb 18 14:45:56 ovpn-air.ovpn[1145]: AUTH: Received AUTH_FAILED control message Feb 18 14:45:56 ovpn-air.ovpn[1145]: SIGTERM received, sending exit notification to peer Feb 18 14:46:00 ovpn-air.ovpn[1145]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Feb 18 14:46:00 ovpn-air.ovpn[1145]: AUTH: Received AUTH_FAILED control message Feb 18 14:46:00 ovpn-air.ovpn[1145]: TCP/UDP: Closing socket Feb 18 14:46:00 ovpn-air.ovpn[1145]: SIGTERM[soft,auth-failure] received, process exiting Feb 18 16:24:43 ovpn-air.ovpn[5648]: OpenVPN 2.2.1 i686-linux-gnu [sSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110424-2 (2.2RC2)] built on Oct 8 2012 Feb 18 16:24:43 ovpn-air.ovpn[5648]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 18 16:24:43 ovpn-air.ovpn[5648]: LZO compression initialized Feb 18 16:24:43 ovpn-air.ovpn[5648]: Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Feb 18 16:24:43 ovpn-air.ovpn[5648]: Socket Buffers: R=[163840->131072] S=[163840->131072] Feb 18 16:24:43 ovpn-air.ovpn[5648]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Feb 18 16:24:43 ovpn-air.ovpn[5648]: Local Options hash (VER=V4): '22188c5b' Feb 18 16:24:43 ovpn-air.ovpn[5648]: Expected Remote Options hash (VER=V4): 'a8f55717' Feb 18 16:24:43 ovpn-air.ovpn[5649]: UDPv4 link local: [undef] Feb 18 16:24:43 ovpn-air.ovpn[5649]: UDPv4 link remote: [AF_INET]95.211.169.3:443 Feb 18 16:24:43 ovpn-air.ovpn[5649]: TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=e5d0432f 994d0f3c Feb 18 16:24:43 ovpn-air.ovpn[5649]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Feb 18 16:24:43 ovpn-air.ovpn[5649]: VERIFY OK: nsCertType=SERVER Feb 18 16:24:43 ovpn-air.ovpn[5649]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Feb 18 16:24:43 ovpn-air.ovpn[5649]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 16:24:43 ovpn-air.ovpn[5649]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 16:24:43 ovpn-air.ovpn[5649]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Feb 18 16:24:43 ovpn-air.ovpn[5649]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Feb 18 16:24:43 ovpn-air.ovpn[5649]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Feb 18 16:24:43 ovpn-air.ovpn[5649]: [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443 Feb 18 16:24:46 ovpn-air.ovpn[5649]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Feb 18 16:24:46 ovpn-air.ovpn[5649]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.48.14 10.4.48.13' Feb 18 16:24:46 ovpn-air.ovpn[5649]: OPTIONS IMPORT: timers and/or timeouts modified Feb 18 16:24:46 ovpn-air.ovpn[5649]: OPTIONS IMPORT: LZO parms modified Feb 18 16:24:46 ovpn-air.ovpn[5649]: OPTIONS IMPORT: --ifconfig/up options modified Feb 18 16:24:46 ovpn-air.ovpn[5649]: OPTIONS IMPORT: route options modified Feb 18 16:24:46 ovpn-air.ovpn[5649]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Feb 18 16:24:46 ovpn-air.ovpn[5649]: ROUTE default_gateway=193.1.1.17 Feb 18 16:24:46 ovpn-air.ovpn[5649]: TUN/TAP device tun0 opened Feb 18 16:24:46 ovpn-air.ovpn[5649]: TUN/TAP TX queue length set to 100 Feb 18 16:24:46 ovpn-air.ovpn[5649]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 Feb 18 16:24:46 ovpn-air.ovpn[5649]: /sbin/ifconfig tun0 10.4.48.14 pointopoint 10.4.48.13 mtu 1500 Feb 18 16:24:46 ovpn-air.ovpn[5649]: /sbin/route add -net 95.211.169.3 netmask 255.255.255.255 gw 193.1.1.17 Feb 18 16:24:46 ovpn-air.ovpn[5649]: /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.48.13 Feb 18 16:24:46 ovpn-air.ovpn[5649]: /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.48.13 Feb 18 16:24:46 ovpn-air.ovpn[5649]: /sbin/route add -net 10.4.0.1 netmask 255.255.255.255 gw 10.4.48.13 Feb 18 16:24:46 ovpn-air.ovpn[5649]: Initialization Sequence Completed Is this log OK? Is there any way to check server's uptime? Which is the most reliable? Quote Share this post Link to post
Staff 10298 Posted ... Is this log OK? Is there any way to check server's uptime? Which is the most reliable?Hello!Unfortunately there's no general rule, and a server may have an uptime of years although the provider lines have been temporarily down, anyway you can have hints on the table "Top 10 Users Session Time" in the servers status monitorhttps://airvpn.org/statusKind regards Quote Share this post Link to post
