fakename1234 0 Posted ... Connection fails during IPV4 route check with the error message Fetch url error:SSL peer certificate or SSH remote key was not OK. Based on another thread I found, I tried refreshing my keys and it still does not work. Windows 11 25H2. Eddie version 2.24.6. Log attached. . 2025.11.19 181333 - Eddie version.txt Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... 7 hours ago, fakename1234 said: I tried refreshing my keys and it still does not work. And you logged out of Eddie, then logged in again after the refresh? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
fakename1234 0 Posted ... 16 hours ago, Tech Jedi Alex said: And you logged out of Eddie, then logged in again after the refresh? Multiple times. Just tried it again. Still the same result. Connection works fine when using the WireGuard client. It will not connect with Eddie. Quote Share this post Link to post
Staff 10466 Posted ... On 11/21/2025 at 12:20 AM, fakename1234 said: Multiple times. Just tried it again. Still the same result. Connection works fine when using the WireGuard client. It will not connect with Eddie. Hello! Can you please try to delete Eddie's configuration file while Eddie is NOT running? At the next run, Eddie will re-create the configuration file with default settings (you will need to re-enter your AirVPN account credentials). In order to locate Eddie's configuration file please see here: https://eddie.website/support/data-path/ If the problem is caused by a corrupt configuration file, the above procedure will solve it. Kind regards Quote Share this post Link to post
udp_monkey33 0 Posted ... On 11/28/2025 at 11:09 AM, Staff said: Hello! Can you please try to delete Eddie's configuration file while Eddie is NOT running? At the next run, Eddie will re-create the configuration file with default settings (you will need to re-enter your AirVPN account credentials). In order to locate Eddie's configuration file please see here: https://eddie.website/support/data-path/ If the problem is caused by a corrupt configuration file, the above procedure will solve it. Kind regards Hello, I have started encountering this issue as well and even deleted the config file but the issue still persists. Quote Share this post Link to post
EMULE 18 Posted ... Hello! I've also frequently encountered this problem. The connection often fails during the IPv4 check step, and I don't know what causes it. However, I can connect normally after disabling the IPv4 check step. I don't know if this is correct, but it does solve my connection problem. Eddie-Preferences-Advanced-Check if the tunnel works, uncheck. Eddie-Preferences-DNS-Check AirVPN DNS, uncheck. Will there be any potential problems with my settings? Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... 8 minutes ago, EMULE said: Will there be any potential problems with my settings? Make sure you check yourself whether your traffic is routed via VPN. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
EMULE 18 Posted ... Just now, Tech Jedi Alex said: Make sure you check yourself whether your traffic is routed via VPN. I think so. My VPN functions the same as before, and I'm able to connect to blocked websites. 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
