mb12345
BootVPNActivity intent removed?
BootVPNActivity seems to have been removed
I've been using Tasker to automatically reconnect AIRVPN in the background 30 minutes after I've manually disabled but it seems that this class/intent has been removed.
Is there another way to launch Eddie in the background to reconnect?
From changelog:
Quote
BootVPNActivity.java
 - [ProMIND] class renamed to BootVPNConnector. It does not extend Activity class anymore
Maybe you can somehow send the BOOT_COMPLETED intent which might get picked up by org.airvpn.eddie? Though maybe you should limit this somehow to Eddie itself, otherwise all apps will react.
That's an interesting approach.
The Android SDK says BOOT_COMPLETED "s a protected intent that can only be sent by the system"
I've tested it with Tasker and nothing happens.
Ahh, unfortunate. I remember that one can send very specific intents with data and whatnot via ADB, including BOOT_COMPLETED, and even limit them to certain packages, so I thought this'd be possible with Tasker, too, since it can execute ADB commands. But while researching this a bit more I found that sometimes adb shell examples use su.
Does Tasker support Shizuku? Maybe something might be possible using that, rootless.
