No matter what I do and no matter which server I try to connect, it gets stuck and does nothing until finally it says Wireguard Handshake Timeout. Anyone know how to fix this?
I've used Surfshark before with no issues.
My handshake is failing as well in wireguard's native client. Despite it working from my Win 11 client running Eddie.
Did you ever get this figured out? None of the servers respond to the handshake initiation despite the config generated profile.
Hi there, low level user,
Just reset my android phone, and Wireguard doesn't connect. Do I need to do something, it worked no problem last six months. Don't remember if i did anything special then.
Like the post above this might be a simple settings with the phone. Had problems last year but Airvpn worked like charm since the new year no complaints.
Just,,
26 Oct 2025 00:34:53 [Error]: VPNService.tunnelSetup() exception: VireGuardTunnel.loadProfile(): unrecognized directive '[interface]'.
Cant get passed this error message.
After resetting my phone and reloading my save on the phone, I forget if I needed to do anything to connect with wireguard?
Openvpn connects,,,but Wireguard on Eddy 3.3.0 Android version just doesn't seem to connect.
Have a Samsung Galaxy A15, i opened all notifications and sent the report below.
As a low level user I tried, adding wireguard airvpn europe profile, but i think maybe it's something simpler, maybe somebody can help me and other novices. Thx.
Log:
26 Oct 2025 00:34:53 [Info]:       Trying to quick connect AirVPN server Menkent in Alblasserdam, Hollanda -WireGuard, Protocol UDP, Port 1637
26 Oct 2025 00:34:53 [Info]:       Using user key 'Default'
26 Oct 2025 00:34:53 [Info]:       Local networks are tunneled into the VPN
26 Oct 2025 00:34:53 [Info]:       WireGuard Tunnel: successfully created a new WireGuard client
26 Oct 2025 00:34:53 [Info]:       Setting MTU to 1320
26 Oct 2025 00:34:53 [Error]:     WireGuard Tunnel.loadProfile(): unrecognized directive '[interface]'.
26 Oct 2025 00:34:53 [Error]:      VPNTunnel.loadProfileString()Exception: WireGuard Tunnel.loadProfile(): unrecognized directive '[interface]'.
26 Oct 2025 00:34:53 [Warning]:  WireGuard: Disconnecting VPN
26 Oct 2025 00:34:53 [Error]:      WireGuardTunnel.cleanup(): WireGuardClient.stop(): tunnel is not started.
26 Oct 2025 00:34:53 [Debug]:   VPNTunnel.clearContexts(): Clearing VPN contexts
26 Oct 2025 00:34:53 [Info]:       WireGuard: Successfully disconnected from VPN
26 Oct 2025 00:34:53 [Info]:       Waiting for VPN to fully disconnect before attempting reconnection.
26 Oct 2025 00:34:53 [Error]:     VPNManager: stop command ignored. Connection already stopped.
26 Oct 2025 00:34:53 [Info]: Trying to reconnect VPN. Attempt 1 out of (infinite)
https://eddie.website/report/2be6fde6/
