nishworks 0 Posted ... Hey i just test my AirVPN speed on speedtest.net as http://www.speedtest.net/result/2489234713.png (~1.5 Mbps) But my real ISP speed is here http://www.speedtest.net/result/2489238261.png (~20 Mbps) But AirVpn claims a minimum of 4 Mbps,Kindly help in choosing the server. Quote Share this post Link to post
Staff 10415 Posted ... Hey i just test my AirVPN speed on speedtest.net as http://www.speedtest.net/result/2489234713.png (~1.5 Mbps)But my real ISP speed is here http://www.speedtest.net/result/2489238261.png (~20 Mbps)But AirVpn claims a minimum of 4 Mbps,Kindly help in choosing the server.Hello!Please note that 4 Mbit/s is the minimum guaranteed allocated bandwidth per each user, please see here for more details:https://airvpn.org/faq#speedIn order to pick the server which can provide you with the best performance please:- connect to various server which are NOT at 100% capacity on different ports (in particular try 443 UDP, 53 UDP and 80 TCP)- perform the internal speed test on different times for each connection to every server, every port and every protocol, so that results are not biased by further, external servers and time fluctuations: http://speedtest.airKind regards Quote Share this post Link to post
