HHUBSS
ANSWERED Can AirVPN help to bypass CGNAT so I can access my docker containers?
My setup is that I have pfsense and Unraid. My ISP is on CGNAT and I want to access my containers, i.e. Nextcloud, immich outside my network using NGIX via domain name. Currently I'm using cloudflared to access this but Nextcloud I got error when I'm transferring large file. This is because of the limit on Cloudflare. My plan is to use AirVPN if it is possible to use instead of cloudflared.
I'm really confuse on where to start, should I use the wireguard on pfsense or should I run wireguard on Unraid itself.
I believe both work, but on *Sense you'll have to do additional configuration (forwarded/shared port and a NAT rule it was, I believe).
