Rajappan Kunna 0 Posted ... (edited) https://www.reddit.com/r/AirVPN/comments/1mue8iw/cant_connect/ Basically the first error is "Checking route IPv4 failed, last reason: Fetch url error: SSL peer certificate or SSH remote key was not OK." Edited ... by Rajappan Kunna Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... In the Devices config in the client area, renew the key you are using to connect, then log out of Eddie and login again. Try a connection. If this doesn't work still, provide a system report immediately after that try:. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Rajappan Kunna 0 Posted ... I tried creating a new key and tried logging in again. Still didn't fix it, here's the log s.txt Quote Share this post Link to post
go558a83nk 380 Posted ... do you have some 3rd party security, antivirus, antimalware, etc. on your system? Quote Share this post Link to post
Rajappan Kunna 0 Posted ... 23 hours ago, go558a83nk said: do you have some 3rd party security, antivirus, antimalware, etc. on your system? Yes I do have Kaspersky but I did try to connect while disabling it and it didn't work. Quote Share this post Link to post
