hello,
I can't get online at all with or without eddie. I ran into an issue where the client was timing out on "checking authorization." I tried to quit and restart the client, but it wouldn't quit, just stalled on quitting indefinitely. I force quit, restarted my laptop, no luck. I looked up possible solutions online and tried things I found on these forums. I tried deleting DNS servers from the network settings and put 8.8.8.8 instead. I tried renewing the DHCP lease. I tried flushing DNS cache. I tried deleting my profile, now the client times out on login. even with eddie closed I can't connect (error: dns_probe_finished_no_internet), so I can't reinstall it because I have no internet access. I can't get the logs off my computer. I'm posting this from my phone. please help!!!
macbook pro 13 inch 2016
monterey 12.7.6
Please make sure that Eddie is not running, check your system DNS settings and set publicly reachable DNS servers. We usually recommend Quad9:
9.9.9.9
149.112.112.112
2620:fe::fe
for their commitment to privacy and neutrality.
How to change DNS settings on macOS:
https://support.apple.com/guide/mac-help/change-dns-settings-on-mac-mh14127/mac
9.9.9.9
149.112.112.112
2620:fe::fe
Thank you for replying. I tried this, but no luck.
FYI, when I do scutil —dns I see
Edited ... by mello-hello
Spoiler tags
