pablitojr
FAIL TOR + AIRVPN
help
tor + airvpn = Fail
jap +airvpn = Fail
always fails error in the proxy that comes to be?
jap tor and care before and always put the right settings
have to use that port? tcp? can be automatic?
help
tor + airvpn = Fail
jap +airvpn = Fail
Sorry, the account is not authorized to access any Air VPN server because it is not subscribed to any plan. Please subscribe to a plan in order to use our service.
Hi, there is connection for airvpn over TOR, epecially after changing configuration to
SocksPort 127.0.0.1:9150 PreferSOCKSNoAuth
 as outlined here
https://airvpn.org/topic/10599-airvpn-over-tor-issue/
However, it sends no data , nor ping to yahoo over tunnel link. I tried with different ports for server connection..but after  a min or 2 disconnects (due to inactivity?)
Here is the output ..
$ sudo openvpn AirVPN_Europe_TCP-2018.ovpn
Fri Mar 14 14:12:06 2014 OpenVPN 2.2.1 x86_64-linux-gnu [sSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110424-2 (2.2RC2)] built on Jun 18 2013
Fri Mar 14 14:12:06 2014 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri Mar 14 14:12:06 2014 WARNING: file 'user.key' is group or others accessible
Fri Mar 14 14:12:06 2014 LZO compression initialized
Fri Mar 14 14:12:06 2014 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
Fri Mar 14 14:12:06 2014 Socket Buffers: R=[87380->131072] S=[16384->131072]
Fri Mar 14 14:12:06 2014 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
Fri Mar 14 14:12:06 2014 Local Options hash (VER=V4): '958c5492'
Fri Mar 14 14:12:06 2014 Expected Remote Options hash (VER=V4): '79ef4284'
Fri Mar 14 14:12:06 2014 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9150 [nonblock]
Fri Mar 14 14:12:06 2014 TCP connection established with [AF_INET]127.0.0.1:9150
Fri Mar 14 14:12:06 2014 TCPv4_CLIENT link local: [undef]
Fri Mar 14 14:12:06 2014 TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9150
Fri Mar 14 14:12:07 2014 TLS: Initial packet from [AF_INET]127.0.0.1:9150, sid=000bd150 82e9c5a2
Fri Mar 14 14:12:12 2014 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
Fri Mar 14 14:12:12 2014 VERIFY OK: nsCertType=SERVER
Fri Mar 14 14:12:12 2014 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
Fri Mar 14 14:12:22 2014 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri Mar 14 14:12:22 2014 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Mar 14 14:12:22 2014 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri Mar 14 14:12:22 2014 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Mar 14 14:12:22 2014 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Fri Mar 14 14:12:22 2014 [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9150
Fri Mar 14 14:12:24 2014 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Fri Mar 14 14:12:25 2014 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.50.0.1,comp-lzo no,route 10.50.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.50.0.62 10.50.0.61'
Fri Mar 14 14:12:25 2014 OPTIONS IMPORT: timers and/or timeouts modified
Fri Mar 14 14:12:25 2014 OPTIONS IMPORT: LZO parms modified
Fri Mar 14 14:12:25 2014 OPTIONS IMPORT: --ifconfig/up options modified
Fri Mar 14 14:12:25 2014 OPTIONS IMPORT: route options modified
Fri Mar 14 14:12:25 2014 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Fri Mar 14 14:12:25 2014 ROUTE default_gateway=192.168.1.1
Fri Mar 14 14:12:25 2014 TUN/TAP device tun0 opened
Fri Mar 14 14:12:25 2014 TUN/TAP TX queue length set to 100
Fri Mar 14 14:12:25 2014 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Fri Mar 14 14:12:25 2014 /sbin/ifconfig tun0 10.50.0.62 pointopoint 10.50.0.61 mtu 1500
Fri Mar 14 14:12:25 2014 /sbin/route add -net 127.0.0.1 netmask 255.255.255.255 gw 192.168.1.1
Fri Mar 14 14:12:25 2014 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.50.0.61
Fri Mar 14 14:12:25 2014 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.50.0.61
Fri Mar 14 14:12:25 2014 /sbin/route add -net 10.50.0.1 netmask 255.255.255.255 gw 10.50.0.61
Fri Mar 14 14:12:25 2014 Initialization Sequence Completed
^CFri Mar 14 14:13:02 2014 event_wait : Interrupted system call (code=4)
Fri Mar 14 14:13:02 2014 TCP/UDP: Closing socket
Fri Mar 14 14:13:02 2014 /sbin/route del -net 10.50.0.1 netmask 255.255.255.255
Fri Mar 14 14:13:02 2014 /sbin/route del -net 127.0.0.1 netmask 255.255.255.255
Fri Mar 14 14:13:02 2014 /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
Fri Mar 14 14:13:02 2014 /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
Fri Mar 14 14:13:02 2014 Closing TUN/TAP interface
Fri Mar 14 14:13:02 2014 /sbin/ifconfig tun0 0.0.0.0
Fri Mar 14 14:13:02 2014 SIGINT[hard,] received, process exiting
