The cloudflare "verifying that you are human, this may take a few seconds" is displayed and never completes. The website will hang indefinitely when browsing to the following:
Example: https://1337x.to/search/ubuntu/1/
Confirmed on multiple AirVPN servers. Is this something that can be fixed?
Edited ... by atmosphere
Your example url loaded perfectly fine with the first airvpn server i tried.
I also received the endless loop of "verifying that you are human, this may take a few seconds". I found the same endless loop using the url that you left. I tried it from Chicago (Sadalsuud) and NY (Sadalmelik).
Check your browsers, people. Use clean profiles or browsers you don't use at all to check. Your addons and "hardenings" are most probably interfering with the validation.
If you're blocked, you're being told so. You're not being subjected to those endless verify loops because someone willed it.
