mfjones 0 Posted ... Just curious, do you ever rotate your outbound IPs (change the web-facing address for each or specific servers)? If so, is that done on a regular basis or just randomly? Thank you Quote Share this post Link to post
Staff 10386 Posted ... Just curious, do you ever rotate your outbound IPs (change the web-facing address for each or specific servers)? If so, is that done on a regular basis or just randomly?Thank youHello!No, the exit-IP address is changed only under exceptional circumstances.Kind regards Quote Share this post Link to post
lulzec123 0 Posted ... So my question is does Air VPN changes you ip adress every sencond minutes ect does it bounce your ip every around the wrold from different locations Quote Share this post Link to post
Staff 10386 Posted ... So my question is does Air VPN changes you ip adress every sencond minutes ect does it bounce your ip every around the wrold from different locationsHello!No, the VPN servers exit-IP address is changed only under exceptional circumstances.Kind regards Quote Share this post Link to post
