Lovaduck
Sharing AirVPN connection through win 11 hotspot DHCP doesn't work, are ports 67 68 blocked?
Hi, I have been sharing my AirVPN connection through a windows mobile hotspot. It has been working fine and I could connect a few devices just fine, but recently after updating Eddie when I try to connect, the Windows DHCP server doesn't provide an address. Is Eddie blocking ports 67 and 68? Is there a way to prevent Eddie to manage those ports?
Everything works fine if I use hard coded IP addresses.
Thanks in advance!
Edited ... by Lovaduck
Eddie Network Lock explicitly allows DHCPv4 by not blocking ports 67 and 68 as well as the special IP address 255.255.255.255. Does DHCPv4 work if you keep Network Lock disabled?
Hello and thanks! Network lock was never enabled on this configuration.
