Staff 10459 Posted ... Hello! Starting from version 2.3, firewalld by default owns exclusively nftables tables generated by itself, thus preventing Eddie, Bluetit and Hummingbird Network Lock related operations. If you want to have Network Lock enabled and firewalld running at the same time, then you must configure firewalld by setting the following option: NftablesTableOwner=no in firewalld's configuration file, usually /etc/firewalld/firewalld.conf . After you have edited the configuration file with any text editor with root privileges, reload firewalld configuration or restart firewalld, and only then (re)start Bluetit, Hummingbird or Eddie. Additional insights: https://discussion.fedoraproject.org/t/firewalld-add-flags-owner-persist-in-fedora-42/148835 https://forums.rockylinux.org/t/rocky-9-5-breaks-netfilter/16551 Kind regards 1 2 Infradragon, 0bacon and fsy reacted to this Quote Share this post Link to post
rickytan78 0 Posted ... Been running for a year before I saw this. Might be worth mentioning in the linux install instructions. Quote Share this post Link to post
