bubbba 3 Posted ... I purchased the monthly plan so that I could test your service as I did with 3 other services. After testing the 4 services I have decided to go with AirVPN but have a question. I won't list the services that I tested, but if you would like to know which ones they are I will certainly share this with you. Is it possible to apply my monthly plan to the yearly plan. In other words, if I would have went with the annual plan to start with I could have saved some money. Is it possible to still take advantage of this savings in some way? Hope this is not a confusing question... Best Regards, Bubbba Quote Share this post Link to post
Staff 10407 Posted ... I purchased the monthly plan so that I could test your service as I did with 3 other services. After testing the 4 services I have decided to go with AirVPN but have a question. I won't list the services that I tested, but if you would like to know which ones they are I will certainly share this with you.Is it possible to apply my monthly plan to the yearly plan. In other words, if I would have went with the annual plan to start with I could have saved some money. Is it possible to still take advantage of this savings in some way?Hope this is not a confusing question...Best Regards, BubbbaHello!Please feel free to use the "Contact us" form (menu "Support") for the above request at your earliest convenience.Kind regards Quote Share this post Link to post
bubbba 3 Posted ... I have sent this via the contact support as suggested. Just wanted to make one more point, about why I chose AirVPN over the others. Once I got OpenVPN working with my iDevices it was a no-brainer. The support here is by FAR the best of any of the others. It is rare that I have seen anyone here being treated as if they were stupid, you simply help and answer their questions. That is not the case with other services I have tried. Since VPN is new to me, I am stupid, but that is where everyone starts out until they are no longer a NooB. So, thank you for all your help. Best Regards, Bubbba Quote Share this post Link to post
