b33uxdly9fa1
Any way to fix viewing sites that block vpn's?
Automatic is difficult because most sites and providers do not block VPNs based on data traffic but on an IP list. You can try selecting OPENVPN over SSL as the protocol. However, it is significantly slower than Wireguard. Otherwise, the only option is to manually switch servers yourself and make a note of which ones worked. I have opened a separate topic for this. It would be great if you could write down the sites you are having problems with and the servers you were able to solve the problem with there.
