Could someone explain to me the possible reasons why this would be happening? I get timeouts quite regularly, especially when trying to download things at high speeds such as highly seeded torrents or games from steam. I have a 1GB/s connection
Different reasons come to mind (MITM packet injection, very noisy line, MTU related problem, bugs in the system or router stack when UDP traffic flow is high). Please:
  1. set WireGuard interface MTU to 1280 bytes in Eddie's "Preferences" > "WireGuard" window;
  2. if you connect via WiFi try to get a stronger signal and verify whether it's necessary to change channel;
  3. if you connect via Ethernet, test a replacement cable;
  4. make sure that your router firmware and your network interface driver are both up to date.
