osalj
ANSWERED Gluetun VPN - connection issue
I use AirVPN on a Windows virtual machine to download files via Qbittorrent.
A few days ago I set up Docker in LXC and on it the entire SERVARR, including Gluetun VPN and Qbittorrent.
Docker configuration:
networks:
  servarrnetwork:
    ipam:
      config:
        - subnet: 172.18.0.0/24
services:
  gluetun:
    image: qmcgaw/gluetun
    container_name: gluetun
    cap_add:
      - NET_ADMIN
    devices:
      - /dev/net/tun:/dev/net/tun # If running proxmox see readme for more info.
    networks:
      servarrnetwork:
        ipv4_address: 172.18.0.2
    ports:
      - 8080:8080 # qbittorrent web interface
      - 12789:12789 # qbittorrent torrent port
      - 6789:6789 # nzbget
      - 9696:9696 # prowlarr
      - 5800:5800 # firefox
    volumes:
      - /docker/gluetun:/gluetun
    environment:
      - VPN_SERVICE_PROVIDER=airvpn
      - VPN_TYPE=wireguard
      - FIREWALL_VPN_INPUT_PORTS=12789
      - WIREGUARD_PRIVATE_KEY=___KEY___
      - WIREGUARD_PRESHARED_KEY=____KEY____
      - WIREGUARD_ADDRESSES=10.166.233.17/32
      - SERVER_COUNTRIES=UNITED KINGDOM
      - SERVER_CITIES=LONDON
      - HEALTH_VPN_DURATION_INITIAL=120s
      - WIREGUARD_PERSISTENT_KEEPALIVE_INTERVAL=15s
#      - VPN_PORT_FORWARDING=on
#      - TORRENTING_PORT=2207
    healthcheck:
      test: ping -c 1 www.google.com || exit 1
      interval: 60s
      timeout: 20s
      retries: 5
    restart: unless-stopped
# This is a new addition since creating the tutorial video on this stack.
# See the 'qBittorrent Stalls with VPN Timeout' section for more information.
  deunhealth:
    image: qmcgaw/deunhealth
    container_name: deunhealth
    network_mode: none
    environment:
      - LOG_LEVEL=info
      - HEALTH_SERVER_ADDRESS=127.0.0.1:9999
      - TZ=Europe/London
    restart: always
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
# Healthcheck was added to work with deunhealth to restart container
# on unhealthy status. labels allows deunhealth to monitor.
  qbittorrent:
    image: lscr.io/linuxserver/qbittorrent:latest
    container_name: qbittorrent
    labels:
      - deunhealth.restart.on.unhealthy=true
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=Europe/London
      - WEBUI_PORT=8080
      - TORRENTING_PORT=12789
    volumes:
      - /docker/qbittorrent:/config
      - /data:/data
    depends_on:
      - gluetun
    network_mode: service:gluetun
    healthcheck:
        interval: 60s
        retries: 3
        start_period: 20s
        timeout: 10s
Gluetun connects without a problem, Qbittorrent works correctly, port forwarding too.
I only have a problem, because when I check the connection status on the AirVPN website it shows me that the connection is not active.
When I check this connection inside the Qbittorrent or GlueTun container via the command wget -qO- https://ipinfo.io I get:
"ip": "217.151.98.163",
"city": "London",
"region": "England",
"country": "GB",
"loc": "51.5085,-0.1257",
"org": "AS9009 M247 Europe SRL",
"postal": "E1W",
"timezone": "Europe/London",
"readme": "https://ipinfo.io/missingauth"
So the connection works.
Why does the AirVPN website show me that the connection is not active?
TIA! Edited ... by osalj
According to the ticket the problem could not be reproduced anymore after the initial event. If it was a glitch of the account panel, apparently it was momentary.
