bplasky 0 Posted ... Good Morning/Afternoon/Evening. I seem to be running into a bit of an issue that I am unable to solve myself. I have AirVPN client on 3 different computers. I am running it with Tunnelbrick on a Macbook; on a Windows based Desktop PC and Laptop PC. My issue is that on my laptop PC with Windows 7 I am unable to connect to any server using the client under a udp port. My laptop is attempting to connect using a Wireless connection to my router instead of a wired connection. I can connect without an issue under tcp ports, but the connection speed is quite reduced and seems pointless to even use if I am getting less than 4 Mbps. On my Desktop PC using Windows 7(connected through a wired connection) I have no issue connecting on any udp port [or tcp port]. My Macbook which connects via wireless connection does not have any issue connecting under a udp port via Tunnelbrick. Is there a setting somewhere in Windows 7 [firewall] or on my router that would be preventing me from connecting, using the AirVPN client, under a udp port, but not the tcp port? I have connected under all 3 tcp ports - 443, 80, 53. All 3 udp ports return "Connecting...." until the client times out and starts over. Please any assistance would be appreciated. Given that I can connect on one of my Windows 7 based machines and not the other the only conclusion I can come to is it has something to do with my wireless to router connection instead of wired router connection OR there is a windows 7 setting somewhere that is not the same between machines. Thank you. Quote Share this post Link to post
pj 73 Posted ... Hello! Apparently the problem is not the wireless connection because your Mac can connect swiftly over WiFi. To begin with, can you please send us the logs of the client running in the Windows 7 machine (the one with problems)? Have you tried to disable completely the firewall on that computer to test a connection over UDP? Kind regards Quote Share this post Link to post
bplasky 0 Posted ... Ok. Sorry I haven't gotten back to you till now. I've been away from the house the past few days. Below I have the logs for every different port to elaborate on what's going on. I have turned my firewall off, removed all the outbound/inbound rules on my firewall; pretty much tried everything relating to my windows firewall. I even went as far to turn the firewall off on my router as well. The Wireless Router I am using is: Linksys E3000 Firmware Version: 1.0.04 I have wireless MAC address filtering turned on and the wireless network does not broadcast. It is a WEP2Personal setup with AES encryption. 443 udp Protocol (TIMED OUT) 1/22/2013 - 11:25 PM Contacting service... 1/22/2013 - 11:25 PM Connecting... 1/22/2013 - 11:25 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 1/22/2013 - 11:25 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:25 PM LZO compression initialized 1/22/2013 - 11:25 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:25 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:25 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:25 PM Local Options hash (VER=V4): '22188c5b' 1/22/2013 - 11:25 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/22/2013 - 11:25 PM UDPv4 link local: [undef] 1/22/2013 - 11:25 PM UDPv4 link remote: 108.59.11.194:443 1/22/2013 - 11:26 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 1/22/2013 - 11:26 PM TLS Error: TLS handshake failed 1/22/2013 - 11:26 PM TCP/UDP: Closing socket 1/22/2013 - 11:26 PM SIGUSR1[soft,tls-error] received, process restarting 1/22/2013 - 11:26 PM Restart pause, 2 second(s) 1/22/2013 - 11:26 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:26 PM LZO compression initialized 1/22/2013 - 11:26 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:26 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:26 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:26 PM Local Options hash (VER=V4): '22188c5b' 1/22/2013 - 11:26 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/22/2013 - 11:26 PM UDPv4 link local: [undef] 1/22/2013 - 11:26 PM UDPv4 link remote: 108.59.11.194:443 1/22/2013 - 11:27 PM Disconnecting... 1/22/2013 - 11:27 PM Disconnected. 443 tcp Protocol (CONNECTED) 1/22/2013 - 11:23 PM Contacting service... 1/22/2013 - 11:23 PM Connecting... 1/22/2013 - 11:23 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 1/22/2013 - 11:23 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:23 PM LZO compression initialized 1/22/2013 - 11:23 PM Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:23 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:23 PM Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:23 PM Local Options hash (VER=V4): '958c5492' 1/22/2013 - 11:23 PM Expected Remote Options hash (VER=V4): '79ef4284' 1/22/2013 - 11:23 PM Attempting to establish TCP connection with 108.59.11.194:443 1/22/2013 - 11:23 PM TCP connection established with 108.59.11.194:443 1/22/2013 - 11:23 PM TCPv4_CLIENT link local: [undef] 1/22/2013 - 11:23 PM TCPv4_CLIENT link remote: 108.59.11.194:443 1/22/2013 - 11:23 PM TLS: Initial packet from 108.59.11.194:443, sid=1d991088 1af59c4b 1/22/2013 - 11:23 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 1/22/2013 - 11:23 PM VERIFY OK: nsCertType=SERVER 1/22/2013 - 11:23 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 1/22/2013 - 11:23 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 1/22/2013 - 11:23 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 1/22/2013 - 11:23 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 1/22/2013 - 11:23 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 1/22/2013 - 11:23 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 1/22/2013 - 11:23 PM [server] Peer Connection Initiated with 108.59.11.194:443 1/22/2013 - 11:23 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 1/22/2013 - 11:23 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.4.66 10.5.4.65' 1/22/2013 - 11:23 PM OPTIONS IMPORT: timers and/or timeouts modified 1/22/2013 - 11:23 PM OPTIONS IMPORT: LZO parms modified 1/22/2013 - 11:23 PM OPTIONS IMPORT: --ifconfig/up options modified 1/22/2013 - 11:23 PM OPTIONS IMPORT: route options modified 1/22/2013 - 11:23 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 1/22/2013 - 11:23 PM ROUTE default_gateway=192.168.1.1 1/22/2013 - 11:23 PM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{CBC26C48-A354-42DC-962B-485D720AADA4}.tap 1/22/2013 - 11:23 PM TAP-Win32 Driver Version 9.9 1/22/2013 - 11:23 PM TAP-Win32 MTU=1500 1/22/2013 - 11:23 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.5.4.66/255.255.255.252 on interface {CBC26C48-A354-42DC-962B-485D720AADA4} [DHCP-serv: 10.5.4.65, lease-time: 31536000] 1/22/2013 - 11:23 PM Successful ARP Flush on interface [18] {CBC26C48-A354-42DC-962B-485D720AADA4} 1/22/2013 - 11:23 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 1/22/2013 - 11:23 PM C:\WINDOWS\system32\route.exe ADD 108.59.11.194 MASK 255.255.255.255 192.168.1.1 1/22/2013 - 11:23 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 1/22/2013 - 11:23 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:23 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.4.65 1/22/2013 - 11:23 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/22/2013 - 11:23 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:23 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.4.65 1/22/2013 - 11:23 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/22/2013 - 11:23 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:23 PM C:\WINDOWS\system32\route.exe ADD 10.5.0.1 MASK 255.255.255.255 10.5.4.65 1/22/2013 - 11:23 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/22/2013 - 11:23 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:23 PM Initialization Sequence Completed 1/22/2013 - 11:23 PM Starting Management Interface... 1/22/2013 - 11:23 PM Checking... 1/22/2013 - 11:24 PM Retrieve statistics... 1/22/2013 - 11:24 PM Connected. 80 udp Protocol (TIMED OUT) 1/22/2013 - 11:21 PM Contacting service... 1/22/2013 - 11:21 PM Connecting... 1/22/2013 - 11:21 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 1/22/2013 - 11:21 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:21 PM LZO compression initialized 1/22/2013 - 11:21 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:21 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:21 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:21 PM Local Options hash (VER=V4): '22188c5b' 1/22/2013 - 11:21 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/22/2013 - 11:21 PM UDPv4 link local: [undef] 1/22/2013 - 11:21 PM UDPv4 link remote: 108.59.11.194:80 1/22/2013 - 11:22 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 1/22/2013 - 11:22 PM TLS Error: TLS handshake failed 1/22/2013 - 11:22 PM TCP/UDP: Closing socket 1/22/2013 - 11:22 PM SIGUSR1[soft,tls-error] received, process restarting 1/22/2013 - 11:22 PM Restart pause, 2 second(s) 1/22/2013 - 11:22 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:22 PM LZO compression initialized 1/22/2013 - 11:22 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:22 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:22 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:22 PM Local Options hash (VER=V4): '22188c5b' 1/22/2013 - 11:22 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/22/2013 - 11:22 PM UDPv4 link local: [undef] 1/22/2013 - 11:22 PM UDPv4 link remote: 108.59.11.194:80 1/22/2013 - 11:22 PM Disconnecting... 1/22/2013 - 11:22 PM Disconnected. 80 tcp Protocol (CONNECTED) 1/22/2013 - 11:11 PM Login... 1/22/2013 - 11:11 PM Login success. 1/22/2013 - 11:11 PM Contacting service... 1/22/2013 - 11:11 PM Connecting... 1/22/2013 - 11:11 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 1/22/2013 - 11:11 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:11 PM LZO compression initialized 1/22/2013 - 11:11 PM Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:11 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:11 PM Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:11 PM Local Options hash (VER=V4): '958c5492' 1/22/2013 - 11:11 PM Expected Remote Options hash (VER=V4): '79ef4284' 1/22/2013 - 11:11 PM Attempting to establish TCP connection with 108.59.11.194:80 1/22/2013 - 11:11 PM TCP connection established with 108.59.11.194:80 1/22/2013 - 11:11 PM TCPv4_CLIENT link local: [undef] 1/22/2013 - 11:11 PM TCPv4_CLIENT link remote: 108.59.11.194:80 1/22/2013 - 11:11 PM TLS: Initial packet from 108.59.11.194:80, sid=6976d2de e027cadd 1/22/2013 - 11:11 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 1/22/2013 - 11:11 PM VERIFY OK: nsCertType=SERVER 1/22/2013 - 11:11 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 1/22/2013 - 11:11 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 1/22/2013 - 11:11 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 1/22/2013 - 11:11 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 1/22/2013 - 11:11 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 1/22/2013 - 11:11 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 1/22/2013 - 11:11 PM [server] Peer Connection Initiated with 108.59.11.194:80 1/22/2013 - 11:11 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 1/22/2013 - 11:11 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.7.0.1,comp-lzo no,route 10.7.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.7.2.66 10.7.2.65' 1/22/2013 - 11:11 PM OPTIONS IMPORT: timers and/or timeouts modified 1/22/2013 - 11:11 PM OPTIONS IMPORT: LZO parms modified 1/22/2013 - 11:11 PM OPTIONS IMPORT: --ifconfig/up options modified 1/22/2013 - 11:11 PM OPTIONS IMPORT: route options modified 1/22/2013 - 11:11 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 1/22/2013 - 11:11 PM ROUTE default_gateway=192.168.1.1 1/22/2013 - 11:11 PM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{CBC26C48-A354-42DC-962B-485D720AADA4}.tap 1/22/2013 - 11:11 PM TAP-Win32 Driver Version 9.9 1/22/2013 - 11:11 PM TAP-Win32 MTU=1500 1/22/2013 - 11:11 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.7.2.66/255.255.255.252 on interface {CBC26C48-A354-42DC-962B-485D720AADA4} [DHCP-serv: 10.7.2.65, lease-time: 31536000] 1/22/2013 - 11:11 PM Successful ARP Flush on interface [18] {CBC26C48-A354-42DC-962B-485D720AADA4} 1/22/2013 - 11:11 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 1/22/2013 - 11:11 PM C:\WINDOWS\system32\route.exe ADD 108.59.11.194 MASK 255.255.255.255 192.168.1.1 1/22/2013 - 11:11 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 1/22/2013 - 11:11 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:11 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.7.2.65 1/22/2013 - 11:11 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/22/2013 - 11:11 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:11 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.7.2.65 1/22/2013 - 11:11 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/22/2013 - 11:11 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:11 PM C:\WINDOWS\system32\route.exe ADD 10.7.0.1 MASK 255.255.255.255 10.7.2.65 1/22/2013 - 11:11 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/22/2013 - 11:11 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:11 PM Initialization Sequence Completed 1/22/2013 - 11:11 PM Starting Management Interface... 1/22/2013 - 11:11 PM Checking... 1/22/2013 - 11:12 PM Retrieve statistics... 1/22/2013 - 11:12 PM Connected. 53 udp Protocol (TIMED OUT) 1/22/2013 - 11:12 PM Login... 1/22/2013 - 11:12 PM Login success. 1/22/2013 - 11:12 PM Contacting service... 1/22/2013 - 11:12 PM Connecting... 1/22/2013 - 11:12 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 1/22/2013 - 11:12 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:12 PM LZO compression initialized 1/22/2013 - 11:12 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:12 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:12 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:12 PM Local Options hash (VER=V4): '22188c5b' 1/22/2013 - 11:12 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/22/2013 - 11:12 PM UDPv4 link local: [undef] 1/22/2013 - 11:12 PM UDPv4 link remote: 108.59.11.194:53 1/22/2013 - 11:13 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 1/22/2013 - 11:13 PM TLS Error: TLS handshake failed 1/22/2013 - 11:13 PM TCP/UDP: Closing socket 1/22/2013 - 11:13 PM SIGUSR1[soft,tls-error] received, process restarting 1/22/2013 - 11:13 PM Restart pause, 2 second(s) 1/22/2013 - 11:13 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:13 PM LZO compression initialized 1/22/2013 - 11:13 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:13 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:13 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:13 PM Local Options hash (VER=V4): '22188c5b' 1/22/2013 - 11:13 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/22/2013 - 11:13 PM UDPv4 link local: [undef] 1/22/2013 - 11:13 PM UDPv4 link remote: 108.59.11.194:53 1/22/2013 - 11:14 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 1/22/2013 - 11:14 PM TLS Error: TLS handshake failed 1/22/2013 - 11:14 PM TCP/UDP: Closing socket 1/22/2013 - 11:14 PM SIGUSR1[soft,tls-error] received, process restarting 1/22/2013 - 11:14 PM Restart pause, 2 second(s) 1/22/2013 - 11:14 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:14 PM LZO compression initialized 1/22/2013 - 11:14 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:14 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:14 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:14 PM Local Options hash (VER=V4): '22188c5b' 1/22/2013 - 11:14 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/22/2013 - 11:14 PM UDPv4 link local: [undef] 1/22/2013 - 11:14 PM UDPv4 link remote: 108.59.11.194:53 1/22/2013 - 11:14 PM Disconnecting... 1/22/2013 - 11:14 PM Disconnected. 53 tcp Protocol (CONNECTED) 1/22/2013 - 11:14 PM Login... 1/22/2013 - 11:14 PM Login success. 1/22/2013 - 11:14 PM Contacting service... 1/22/2013 - 11:14 PM Connecting... 1/22/2013 - 11:14 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 1/22/2013 - 11:14 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/22/2013 - 11:14 PM LZO compression initialized 1/22/2013 - 11:14 PM Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ] 1/22/2013 - 11:14 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/22/2013 - 11:14 PM Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ] 1/22/2013 - 11:14 PM Local Options hash (VER=V4): '958c5492' 1/22/2013 - 11:14 PM Expected Remote Options hash (VER=V4): '79ef4284' 1/22/2013 - 11:14 PM Attempting to establish TCP connection with 108.59.11.194:53 1/22/2013 - 11:14 PM TCP connection established with 108.59.11.194:53 1/22/2013 - 11:14 PM TCPv4_CLIENT link local: [undef] 1/22/2013 - 11:14 PM TCPv4_CLIENT link remote: 108.59.11.194:53 1/22/2013 - 11:14 PM TLS: Initial packet from 108.59.11.194:53, sid=193b1b24 ffd1a799 1/22/2013 - 11:14 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 1/22/2013 - 11:14 PM VERIFY OK: nsCertType=SERVER 1/22/2013 - 11:14 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 1/22/2013 - 11:14 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 1/22/2013 - 11:14 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 1/22/2013 - 11:14 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 1/22/2013 - 11:14 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 1/22/2013 - 11:14 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 1/22/2013 - 11:14 PM [server] Peer Connection Initiated with 108.59.11.194:53 1/22/2013 - 11:15 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 1/22/2013 - 11:15 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.9.0.1,comp-lzo no,route 10.9.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.9.0.238 10.9.0.237' 1/22/2013 - 11:15 PM OPTIONS IMPORT: timers and/or timeouts modified 1/22/2013 - 11:15 PM OPTIONS IMPORT: LZO parms modified 1/22/2013 - 11:15 PM OPTIONS IMPORT: --ifconfig/up options modified 1/22/2013 - 11:15 PM OPTIONS IMPORT: route options modified 1/22/2013 - 11:15 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 1/22/2013 - 11:15 PM ROUTE default_gateway=192.168.1.1 1/22/2013 - 11:15 PM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{CBC26C48-A354-42DC-962B-485D720AADA4}.tap 1/22/2013 - 11:15 PM TAP-Win32 Driver Version 9.9 1/22/2013 - 11:15 PM TAP-Win32 MTU=1500 1/22/2013 - 11:15 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.9.0.238/255.255.255.252 on interface {CBC26C48-A354-42DC-962B-485D720AADA4} [DHCP-serv: 10.9.0.237, lease-time: 31536000] 1/22/2013 - 11:15 PM Successful ARP Flush on interface [18] {CBC26C48-A354-42DC-962B-485D720AADA4} 1/22/2013 - 11:15 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 1/22/2013 - 11:15 PM C:\WINDOWS\system32\route.exe ADD 108.59.11.194 MASK 255.255.255.255 192.168.1.1 1/22/2013 - 11:15 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 1/22/2013 - 11:15 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:15 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.0.237 1/22/2013 - 11:15 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/22/2013 - 11:15 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:15 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.0.237 1/22/2013 - 11:15 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/22/2013 - 11:15 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:15 PM C:\WINDOWS\system32\route.exe ADD 10.9.0.1 MASK 255.255.255.255 10.9.0.237 1/22/2013 - 11:15 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/22/2013 - 11:15 PM Route addition via IPAPI succeeded [adaptive] 1/22/2013 - 11:15 PM Initialization Sequence Completed 1/22/2013 - 11:15 PM Starting Management Interface... 1/22/2013 - 11:15 PM Checking... 1/22/2013 - 11:15 PM Retrieve statistics... 1/22/2013 - 11:15 PM Connected. Quote Share this post Link to post
Staff 10427 Posted ... Hello! At a first glance, it might appear that your ISP blocks outbound UDP ports. However, the block toward 53 UDP is strange, because it would block DNS queries. So, maybe SSL/TLS negotiations are disrupted when performed through UDP (it would be very strange anyway). Maybe there's still some program in your system that blocks OpenVPN outbound UDP packets. Try to determine if UDP packets are blocked only for OpenVPN or for any application. Kind regards Quote Share this post Link to post
bplasky 0 Posted ... I'm fairly to messing around with a VPN or protocols. Any suggestions on a program that uses udp with which I could test this theory? Quote Share this post Link to post
bplasky 0 Posted ... Below is a log from my Desktop PC. It is running the same updated version of Windows 7. Desktop PC: Connected via LAN Laptop PC: Connected via WLAN Both computers are connecting through the same Linksys router. And my Macbook has no issues connecting through Tunnelbrick via the same router. This is why I ruled out that wireless connection had something to do with it. But I'll let you look at this log of a connection via port 443 udp. I had no issues and it only took less than 1 minute to connect. 1/24/2013 - 4:07 PM Contacting service... 1/24/2013 - 4:07 PM Connecting... 1/24/2013 - 4:07 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 1/24/2013 - 4:07 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/24/2013 - 4:07 PM LZO compression initialized 1/24/2013 - 4:07 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 1/24/2013 - 4:07 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/24/2013 - 4:07 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 1/24/2013 - 4:07 PM Local Options hash (VER=V4): '22188c5b' 1/24/2013 - 4:07 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/24/2013 - 4:07 PM UDPv4 link local: [undef] 1/24/2013 - 4:07 PM UDPv4 link remote: 108.59.11.194:443 1/24/2013 - 4:07 PM TLS: Initial packet from 108.59.11.194:443, sid=22689d4d 4fcb8d5c 1/24/2013 - 4:07 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 1/24/2013 - 4:07 PM VERIFY OK: nsCertType=SERVER 1/24/2013 - 4:07 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 1/24/2013 - 4:07 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 1/24/2013 - 4:07 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 1/24/2013 - 4:07 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 1/24/2013 - 4:07 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 1/24/2013 - 4:07 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 1/24/2013 - 4:07 PM [server] Peer Connection Initiated with 108.59.11.194:443 1/24/2013 - 4:07 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 1/24/2013 - 4:07 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.18.46 10.4.18.45' 1/24/2013 - 4:07 PM OPTIONS IMPORT: timers and/or timeouts modified 1/24/2013 - 4:07 PM OPTIONS IMPORT: LZO parms modified 1/24/2013 - 4:07 PM OPTIONS IMPORT: --ifconfig/up options modified 1/24/2013 - 4:07 PM OPTIONS IMPORT: route options modified 1/24/2013 - 4:07 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 1/24/2013 - 4:07 PM ROUTE default_gateway=192.168.1.1 1/24/2013 - 4:07 PM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{3979ED8B-D038-418A-93D2-2D10F8092887}.tap 1/24/2013 - 4:07 PM TAP-Win32 Driver Version 9.9 1/24/2013 - 4:07 PM TAP-Win32 MTU=1500 1/24/2013 - 4:07 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.18.46/255.255.255.252 on interface {3979ED8B-D038-418A-93D2-2D10F8092887} [DHCP-serv: 10.4.18.45, lease-time: 31536000] 1/24/2013 - 4:07 PM Successful ARP Flush on interface [14] {3979ED8B-D038-418A-93D2-2D10F8092887} 1/24/2013 - 4:07 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 1/24/2013 - 4:07 PM C:\WINDOWS\system32\route.exe ADD 108.59.11.194 MASK 255.255.255.255 192.168.1.1 1/24/2013 - 4:07 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 1/24/2013 - 4:07 PM Route addition via IPAPI succeeded [adaptive] 1/24/2013 - 4:07 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.18.45 1/24/2013 - 4:07 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/24/2013 - 4:07 PM Route addition via IPAPI succeeded [adaptive] 1/24/2013 - 4:07 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.18.45 1/24/2013 - 4:07 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/24/2013 - 4:07 PM Route addition via IPAPI succeeded [adaptive] 1/24/2013 - 4:07 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.18.45 1/24/2013 - 4:07 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 1/24/2013 - 4:07 PM Route addition via IPAPI succeeded [adaptive] 1/24/2013 - 4:07 PM Initialization Sequence Completed 1/24/2013 - 4:07 PM Starting Management Interface... 1/24/2013 - 4:07 PM Checking... 1/24/2013 - 4:07 PM Retrieve statistics... 1/24/2013 - 4:07 PM Connected. If this is helpful please let me know. If not, can you offer another alternative? Thank you for any assistance it is greatly appreciated by my moderate tech savvyness. Quote Share this post Link to post
Staff 10427 Posted ... Below is a log from my Desktop PC. It is running the same updated version of Windows 7. Desktop PC: Connected via LANLaptop PC: Connected via WLANBoth computers are connecting through the same Linksys router. And my Macbook has no issues connecting through Tunnelbrick via the same router. This is why I ruled out that wireless connection had something to do with it. But I'll let you look at this log of a connection via port 443 udp. I had no issues and it only took less than 1 minute to connect.Hello!The last logs you published show no problem at all. So it's definitely something in your laptop or router (only in WiFi) that blocks outbound UDP packets. First, please make a test with the laptop, but connected via cable, not wireless.If the problem persists, check for antivirus, firewall, PeerBlock, PeerGuardian, Malwarebytes and any smilar program. Make sure to disable them one by one and perform a connection test on an UDP port each time. If the problem still persists, make sure that you have no malware in the system.Please feel free to let us know at your convenience the outcome of the tests.Kind regards Quote Share this post Link to post
