Not connected, Your IP: 216.73.216.9
kingdave
Air VPN over virtual machine
When I use Airvpn in a virtual machine the DNS leaks. Airvpn does not leak in host system.
I use Win 7 with VMplayer
The VM is Win 8
The player defaults to NAT connection.
I new to virtual machines so any advice, thanks!
Still problem with 1,8 client.
Login and connection successful with Airvpn in guest system.
AirVPN 1,8 client in in guest system says MY IP changed to AirVPN IP
However, Airvpn website "not connected" and displays MYIP
Other website same: MYIP
Airvpn connect good (no leak) in host system
Therefore it appears to be some problem in the VM and/or how the VM connects to the host: is it behind a NAT or does it access directly the host network card (bridge mode)? Also, do the logs (of the client running in the guest OS) suggest something useful? Can you please send them to us?
Hello hello
Yes, I have NAT. I try bridge connection in guest=same
Airvpn log no errors.
Can you please send us the client logs?
AirVPN client log:
AirVPN client version: 1.8
- Reading options from
- OpenVPN bundle version: OpenVPN 2.3.0
- OpenVPN current version: OpenVPN 2.3.0
- Ready.
- Login...
- Login success.
- Contacting service...
- Connecting...
- OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013
- NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
- Socket Buffers: R=[65536->65536] S=[65536->65536]
- Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050
- TCP connection established with [AF_INET]127.0.0.1:9050
- TCPv4_CLIENT link local: [undef]
- TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9050
- TLS: Initial packet from [AF_INET]127.0.0.1:9050, sid=2b6b60e0 aee1e5bd
- VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
- VERIFY OK: nsCertType=SERVER
- VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
- Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
- Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
- Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
- Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
- Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
- [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9050
- SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
- PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.1.2 10.5.1.1'
- OPTIONS IMPORT: timers and/or timeouts modified
- OPTIONS IMPORT: LZO parms modified
- OPTIONS IMPORT: --ifconfig/up options modified
- OPTIONS IMPORT: route options modified
- OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
- do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
- open_tun, tt->ipv6=0
- TAP-WIN32 device [Local Area Connection] opened:
- TAP-Windows Driver Version 9.9
- Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.1.2/255.255.255.252 on interface [DHCP-serv: 10.5.1.1, lease-time: 31536000]
- Successful ARP Flush on interface [17]
- TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
- Route: Waiting for TUN/TAP interface to come up...
- AirVPN Windows 8 Interface Hack executed (Interface: 'Local Area Connection').
- TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
- C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255
- ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
- Route addition via IPAPI succeeded [adaptive]
- C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.1.1
- ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
- C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.1.1
- C:\Windows\system32\route.exe ADD 10.5.0.1 MASK 255.255.255.255 10.5.1.1
- Initialization Sequence Completed
- Starting Management Interface...
- Checking...
- Retrieve statistics...
- Connected.
Tor.
Load Tor ,load AirVPN
In guest machine
When you perform the IP test, are you using the TOR browser, or a browser configured to connect over TOR? This would explain why you appear on the Internet with an IP address which is not the Air server exit-IP address. The logs look fine.
Tor.
In guest machine
I see.
Load Tor, Load Airvpn
but
TOR browser gives me TOR IP.
Normal browser gives me AirVPN IP.
So which is truth?
It seems wrong that two different browser give me two different IP for same network interface.
once again I dumb :-(
Tor.
In guest machine
I see.
but
So which is truth?
It's absolutely correct.
When you use a browser that is configured to connect over TOR, your last exit node is a TOR node. When you use a browser not configured to connect over TOR, your last exit is the exit-IP address of the AirVPN server.
If you wish to connect over OpenVPN over TOR you just have to connect to TOR, then connect AirVPN over TOR https://airvpn.org/tor and finally browse with a browser NOT configured to connect over TOR, so that the browser will be tunneled over Air over TOR (browser->TOR network->VPN).
