Not connected, Your IP: 216.73.216.139
DimaRadist
Eddie: None of the protocols connect
All of the protocols and servers get stuck on IP connection (?). I tried all of the protocol types and almost all of the ports. It's probably not the servers that cause this problem but my connection settings, I have no idea what to do. Below are my logs for every protocol type.
SSL>TCP 28439
! 2025.04.04 13:19:02 - Disconnecting
. 2025.04.04 13:19:02 - Sending soft termination signal
. 2025.04.04 13:19:05 - Sending hard termination signal
. 2025.04.04 13:19:05 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2025.04.04 13:19:05 - Routes, delete 46.183.218.147/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2025.04.04 13:19:05 - Routes, skipped for 2a02:4840:2:237:b0bd:6f2c:c975:5bf0 : IPv6 blocked.
. 2025.04.04 13:19:05 - IPv6 restored with packet filtering.
. 2025.04.04 13:19:05 - Collect network information
. 2025.04.04 13:19:05 - Connection terminated.
I 2025.04.04 13:19:07 - Cancel requested.
. 2025.04.04 13:19:07 - Deactivation of Network Lock
! 2025.04.04 13:19:08 - Session terminated.
UDP 443
! 2025.04.04 13:22:42 - Connecting to Phact (Latvia, Riga)
. 2025.04.04 13:22:42 - Routes, add 46.183.218.148/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2025.04.04 13:22:43 - OpenVPN > Note: '--allow-compression' is not set to 'no', disabling data channel offload.
. 2025.04.04 13:22:43 - OpenVPN > OpenVPN 2.6.12 [git:v2.6.12/038a94bae57a446c] Windows [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] [DCO] built on Jul 18 2024
. 2025.04.04 13:22:43 - OpenVPN > Windows version 10.0 (Windows 10 or greater), amd64 executable
. 2025.04.04 13:22:43 - OpenVPN > library versions: OpenSSL 3.3.1 4 Jun 2024, LZO 2.10
. 2025.04.04 13:22:43 - OpenVPN > DCO version: N/A
. 2025.04.04 13:22:43 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]46.183.218.148:443
. 2025.04.04 13:22:43 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2025.04.04 13:22:43 - OpenVPN > UDPv4 link local: (not bound)
. 2025.04.04 13:22:43 - OpenVPN > UDPv4 link remote: [AF_INET]46.183.218.148:443
. 2025.04.04 13:23:44 - OpenVPN > [UNDEF] Inactivity timeout (--ping-restart), restarting
. 2025.04.04 13:23:44 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2025.04.04 13:23:44 - OpenVPN > Restart pause, 1 second(s)
! 2025.04.04 13:23:44 - Disconnecting
Nope, don't opinionate your log pastes; in the sense of, don't just post what you think is important. You're neglecting to tell us 95% of the vital info about your setup. Close Eddie, reopen and try a connection once, then:
But luckily there's a hint that you're still using an old Eddie version as the Radmin interface is tried to be used. Please update first to the latest stable.
Alright, thanks! The system report is attached. Also I already updated the thing and those logs are from a new version(2.24.6 - thats the latest stable ver I can download).
sysrep.txt
Ah. This. Follow these instructions to force Eddie to use the Eddie network interface it creates:.
