dukenduke
Airvpn has stopped working
This is the error that i have when i try to run airvpn. How to fix it?
Can you please check that the .NET framework 2.0 is installed in your system? Is there any additional detail in the error message?
.NET framework 4.0 is installed on my win7 64 bit system and no other error message.
You need the .NET framework 2.0, or alternatively you can download the following client specifically compiled for 64 bit systems and .NET framework 4 (you will find OpenVPN 2.3_rc1 in the package as well):
https://airvpn.org/repository/air_windows8_x86_64.zip
We'll soon rationalize packages because OpenVPN 2.3 stable version has been released two days ago.
