Lollygag
MacOS 15.2 connection issues after sleeping
So I am using Eddie (2.24.6 ARM) GUI to connect to AirVPN. I use it with network lock, some DNS ad blockers turned on in AirVPN web client and port forwarding.
It works well until computer goes to sleep. When it wakes up the following happens:
  1. Network is blocked as it should due to network lock;
  2. Eddie is trying to connect to VPN but never manages to (stuck at either flushing DNS or checking ipv4);
  3. If I try to disable network lock I get "object reference not set to an instance of an object" error and cannot do anything;
  4. I have to quit and reopen Eddie to be able to connect back to VPN or use internet.
Any ideas why this could be happening?
