Kaappi 0 Posted ... So I forwarded a port on AirVPN and then made qBittorrent use the same port for incoming connections, bound it to the specific interface etc etc. Now the trouble I'm facing is actually getting ufw to letting traffic through. I did: sudo ufw allow qbittorrent And as it assigns a different port number compared to the one I've forwarded I went and edited the file in /etc/ufw/applications.d/ufw-bittorrent and changed the port and protocol. Afterwards I did: sudo ufw reload sudo ufw status verbose The output from the status command tells me that it didn't change the port and now I'm wondering how I could change it? Or did I do something wrong? Thanks. Quote Share this post Link to post
Staff 10377 Posted ... @Kaappi Hello! Please find the solution on ufw manual (see below for a quick rule). We want to warn you: you have forwarded only incoming UDP, while qBittorrent relies a lot on TCP. Please make sure to forward TCP too for the port you have been assigned. sudo ufw allow in on <tun interface name> from any to any port <your reserved port number> Kind regards Quote Share this post Link to post
Kaappi 0 Posted ... 5 hours ago, Staff said: @Kaappi Hello! Please find the solution on ufw manual (see below for a quick rule). We want to warn you: you have forwarded only incoming UDP, while qBittorrent relies a lot on TCP. Please make sure to forward TCP too for the port you have been assigned. sudo ufw allow in on <tun interface name> from any to any port <your reserved port number> Kind regards Thanks for the response. I wasn't sure whether or not wireguard supported TCP, but I guess I was wrong. I now have forwarded both, and at the same time I fixed the issue. Nothing on my end was listening to the port So when I opened qBittorrent it instantly started working! Quote Share this post Link to post
Staff 10377 Posted ... 1 hour ago, Kaappi said: I wasn't sure whether or not wireguard supported TCP Hello! We're glad to know the the problem is resolved. 1 hour ago, Kaappi said: I wasn't sure whether or not wireguard supported TCP WireGuard doesn't support TCP as a VPN connection protocol, but this is unrelated. When a tunnel is established over UDP, any transport layer protocol packets (TCP, UDP, RDP etc. etc.) get wrapped inside UDP. Kind regards 1 Kaappi reacted to this Quote Share this post Link to post
