Vwsplitty1980
Port Forwarding Errors
Hi there
just wanted to ask your advise over a port forwarding issuse im having. it seems that no matter which port i generate via leaving the port field selection blank i get the following message when checking it, should it not be turning green what am i doing wrong?
Not reachable on server IP over the external port 16050, tcp protocol. Error : 110 - Connection timed out
if it helps im using:
airvpn cilent on tcp53
DDwrt on my router
Zonealarm
avast
Thanks...
Hi there
DDwrt on my router
Zonealarm
avast
Thanks...
Did you forward the port 16050 to the appropriate router client and port (DNAT)? This is only necessary if you connect to the VPN through the router, in which case the port is correctly forwarded remotely, but it needs an additional forward from your router to the final client since no TUN interface is running on the final client, but only on the router.
Please see here:
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=2849&Itemid=142#4695
