tmalik73 0 Posted ... Tried starting airvpn client and all of a sudden it started saying "failed to start" and wont connect to a server. 1/5/2013 - 1:42 PM AirVPN client version: 1.7 1/5/2013 - 1:42 PM Reading options from C:\Users\doodoo\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 1/5/2013 - 1:42 PM OpenVPN bundle version: OpenVPN 2.2.2 1/5/2013 - 1:42 PM OpenVPN current version: OpenVPN 2.2.2 1/5/2013 - 1:42 PM Login... 1/5/2013 - 1:42 PM Already connected. 1/5/2013 - 1:44 PM Login... 1/5/2013 - 1:44 PM Login success. 1/5/2013 - 1:44 PM Contacting service... 1/5/2013 - 1:44 PM Connecting... 1/5/2013 - 1:44 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 1/5/2013 - 1:44 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/5/2013 - 1:44 PM LZO compression initialized 1/5/2013 - 1:44 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 1/5/2013 - 1:44 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/5/2013 - 1:44 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 1/5/2013 - 1:44 PM Local Options hash (VER=V4): '22188c5b' 1/5/2013 - 1:44 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/5/2013 - 1:44 PM Attempting to establish TCP connection with 127.0.0.1:9050 1/5/2013 - 1:44 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:44 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:44 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:44 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:44 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:44 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:45 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:45 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:45 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:45 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:45 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:45 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:45 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:45 PM Disconnecting... 1/5/2013 - 1:45 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 1/5/2013 - 1:45 PM Disconnected. 1/5/2013 - 1:45 PM Login... 1/5/2013 - 1:45 PM Login success. 1/5/2013 - 1:45 PM Contacting service... 1/5/2013 - 1:45 PM Connecting... 1/5/2013 - 1:45 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 1/5/2013 - 1:45 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 1/5/2013 - 1:45 PM LZO compression initialized 1/5/2013 - 1:45 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 1/5/2013 - 1:45 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 1/5/2013 - 1:45 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 1/5/2013 - 1:45 PM Local Options hash (VER=V4): '22188c5b' 1/5/2013 - 1:45 PM Expected Remote Options hash (VER=V4): 'a8f55717' 1/5/2013 - 1:45 PM Attempting to establish TCP connection with 127.0.0.1:9050 1/5/2013 - 1:45 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) Quote Share this post Link to post
Staff 10565 Posted ... Tried starting airvpn client and all of a sudden it started saying "failed to start" and wont connect to a server.1/5/2013 - 1:44 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)Hello!Your proxy is not running or it is refusing connections on port 9050. Please make sure that it is running and listening to port 9050. If you don't have a proxy, you need to bring back to default the option "Proxy"-->"Type". Set it to "None" in the Air client "Preferences" window. You can open the Preferences window by right-clicking on the Air dock icon and selecting "Preferences".Kind regards Quote Share this post Link to post
