tigleo31
[SOLVED] Problem reaching this site when connected to VPN
Hello
I've been using this service for some months now and have had no problems what-so-ever until recently. For the last couple of days when I connect over Air I am unable to connect to this site but am able when not. Any particular reasons or suggestions as to, or how I could fix this. I usually connect to the servers in the Netherlands region.
Thanks in advance for any replies.
Hello
Are you referring to airvpn.org? If so, that's quite odd. While you are connected to an Air VPN server, can you please send us the output of the commands:
ping airvpn.org
traceroute airvpn.org (replace "traceroute" with "tracert" if you're running Windows).
Feel free to delete sensitive information from the traceroute output.
Well...
I'm able to access again (connected to Air). It just seemed weird not being able to access this site. I'm sorry for any inconvenience this has caused you. Whatever the problem was (probably me) seems fine now. Thanks for your quick reply.
