corrupted
ANSWERED No internet when connected to AirVPN through wireguard on linux
Hey, I just got AirVPN and I imported the wireguard configs into NetworkManager on my Linux box. I can connect to the servers fine, but they do not have any internet access. I do however get internet access on my phone when connected to the servers. Is there any reason for this? I have the theory that my IP was flagged for exceeding the maximum 5 concurrent connections (they weren't really concurrent and only lasted a few seconds though, NetworkManager just auto-connected after the import of each profile for some reason). It was working earlier for me though.
I have confirmed this is not an issue on AirVPN's side. I have installed the Eddie client and everything works very smoothly (very fast too!). I would still like to use NetworkManager's built-in WireGuard capability though, so if anyone has a solution for this please let me know :)
SOLVED: I needed to enable systemd-resolved. It was a DNS issue. If you also have this problem, try running "systemctl start systemd-resolved.service" and "systemctl enable systemd-resolved.service". Thanks to nicehand90210 on the Arch Linux forums.
13 minutes ago, OpenSourcerer said:
You need openresolv for Wireguard to make DNS changes on connect.
Be careful, you may have inadvertently made it possible for DNS leaks to occur.
I ran an extended leak test just there, all's clear! I believe it's the only resolver I have on my system now (I was using dnscrypt-proxy beforehand).
Alright, enjoy :)
