raptor2003
ANSWERED Netherlands servers IP weirdness
When using servers from the Netherlands, it seems that the IP reported to the outside world is sometime completely different from the server's IP. I have seen that behaviour on multiple of them.
I switched to Sweden servers, and I don't have that "issue".
Why would that be ?
Why would that be ?
It is related to the geo-routing feature:
https://airvpn.org/faq/routingtable/
You can disable this feature from your AirVPN account DNS panel by changing the setting of the "AirVPN anti geo-location system" combo box. Please note that if the forced routing was implemented in order to bypass a block, you will have that block again when you disable the routing.
